Removal Front Passenger Seat
Discussion in '1st Gen Tundras (2000-2006)' started by kb7, Dec 6, 2021.
  1. Dec 6, 2021 at 1:17 PM
    kb7
    kb7 [OP] New Member
    USA
    2003 Tundra SR5 TRD 4x4
    Rookie question for you experts. Is it difficult to remove the front passenger seat? There are some electrical wires that run under the seats and I'm not sure what they operate. I was hoping it would be some simple ratchet wrench work.
    For reference, I am going on a 9-10 hour drive with momma and baby and wanted to give her leg room while sitting in the back of the cab.
    Picture shows what I'm trying to take out.
    Thanks.
  2. Dec 6, 2021 at 1:23 PM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    I have the bucket seats, but should be close to same. It would be 4 bolts on the floor and easily done. Not sure what wiring is under the seat, but it should be an easy wire harness that can be unclipped. No cutting wires.
    IMO it would be way more comfortable to sit in the front seat with it all the way back they taking out and sitting in back seat. Might be kind of dangerous if an accident too - but might be misunderstanding the goal.
    kb7[OP] likes this.
  3. Dec 6, 2021 at 1:28 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    easy. couple of bolts and some connections clips need uncliped.
    scooterprint, kb7[OP] and Tundra2 like this.
  4. Dec 6, 2021 at 1:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Had mine out multiple times. Four 14mm bolts. Two in front. Two in back.
    Slide seats backward. Remove bolts.
    Slide seat forwards. Remove bolts.
    Tilt seat back wards, and then unclip the seat sensor.
    That seat is HEAVY especially if the center console is full of shit like mine. May be a team lift unless you have tard strength like me.
  5. Dec 6, 2021 at 1:56 PM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
    Wiring could be for in-seat airbags too (if equipped). If airbag equipped and you remove the seat you'll have the warning light on the dash until it is replaced (I had the issue while recovering the seats, very annoying!).
    kb7[OP] likes this.
  6. Dec 6, 2021 at 2:17 PM
    Punk1974
    J.P.
    liard has this tard strangff like you. he has a perfum named cool waters because of it..
    Tundra2[QUOTED] likes this.
  7. Dec 6, 2021 at 2:18 PM
    Punk1974
    J.P.
    i remember my 2000 tunny had a key on an off switch for the pass seat warning maybe the later gens dont have??.
    daveeasa and kb7[OP] like this.
  8. Dec 6, 2021 at 2:30 PM
    kb7
    kb7 [OP] New Member
    USA
    Thanks all.
    The lady prefers to sit in the back with the baby during drives. She just wanted the front seat out so should could extend her feet throughout the drive. She's 5'2 so the size back there has never really bothered her lol.
    Punk1974 likes this.
  9. Dec 6, 2021 at 2:39 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    Do it!
    We did something similar with our rental mini-vans back in the day. Before starting our adventure I would remove the middle seat and cover the area with a piece of new scrap carpet. Traveling with two small kids, having that space for everyone to spread out, stretch out and have entertainment and snacks at the ready made the trips much more pleasant...for all of us.
    dinosaur and kb7[QUOTED][OP] like this.
  10. Dec 6, 2021 at 5:43 PM
    All the wires for my factory amp housed under the rear passenger seat, they run along the floor where the xmission tunnel meets the floorboard. Just tossing it out there.
    kb7[OP] likes this.
