Towing Jayco Octane 222
Discussion in 'Towing & Hauling' started by FRS, Dec 5, 2021.
  1. Dec 5, 2021 at 5:35 PM
    FRS
    FRS [OP] New Member
    TRD CAI, TRD Dual Exhaust, TRD Rear Sway Bar, 3” Lift F&R, Leer 700 Tonno, Bedrug, Smittybilt 12k Winch, Warn Winch Mnt. Bumper insert, Good Year Duratrak, R5/800WDH
    About to trigger Jayco Octane 222GL…
    TT:
    UVW 6,486/GVWR 8,200
    Tongue Weight 907 w/o WDH
    TV:
    2020 1794, 5.7l, CMX, Tow pkg. 38 gal.
    Add ons: TRD Dual Ex, TRD CAI, 2” lift (f&r), Larger Duratracks, Warn Winch mount bumper insert, 12k winch, Leer 700 tonno, TRD Rr sway bar, New Brakes w/cross drilled rotors
    CAT Scale weight: w/ Me, Dog and full tank of gas - 6,740
    GVWR-TV 7,200
    Max Tow weight: 8,800
    Payload: 1,185
    WDH: R6/800
    I’ll be driving from CA to MT to pick it up in 2 weeks. Then off to Bozeman, Jackson Wyo and then back to CA.
    • Has anyone in the community pulled a 26’/ 7500 lb trailer behind a Tundra?
    • Has anyone done this in the Winter?
    Knowing that I am approaching the “Ragged-Edge” of the Truck’s capabilities from a payload limit, Any advice or suggestions welcome…other that buy a 3/4T.
    Thanks,
    FRS
  2. Dec 5, 2021 at 5:39 PM
    2mchfun
    Get yourself a Roadmaster Active Suspension HD kit at the very least.
    Rodtheviking likes this.
  3. Dec 5, 2021 at 5:44 PM
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    I have a 31' Dutchman Astoria .7500 dry and 1000 pound tongue weight.Tundra did fantastic but not great gas mileage but it towed it like a beast.I have a 2wd 2017 crew max 5.7. Tundra is amazing IMG_3721.jpg
    Dansly56 likes this.
  4. Dec 5, 2021 at 5:45 PM
    Infernotundra17
    Martin
    Las Vegas, Nevada
    Bought mine in Grand Junction Colorado ,drove from Las Vegas to pick it up then drove back over many hills.Added air bags after this picture
  5. Dec 5, 2021 at 5:49 PM
    2mchfun
    This is a great example of what is too big. Weight is fine, eventually a gust of wind will win due to the size and shape.
    Cpl_Punishment likes this.
  6. Dec 5, 2021 at 6:20 PM
    Infernotundra17
    Martin
    Las Vegas, Nevada
    And so everyone knows what are you towing with your Tundra
  7. Dec 5, 2021 at 6:21 PM
    Welcome. You will not be at the ragged edge, you will be overweight right off the bat.
    7200-6740=460 lbs of capacity. Those mods, bigger tires, and higher trim package truck really chew up the capacity really quick.
    460 lbs capacity - 907 lbs factory tongue weight= 447 lbs overwieght. A LDH doesn't take any of the weight off the hitch but distributes it more evenly to the front axle of the truck and trailer. Add the hitch weight as well.
    The weight distribution hitch you have will now work well either. You need to be into the 1000 lb bars, not 800. Good thing is you can change the bars out for the more HD ones (most likely).
    This camper is about the same as the one you want. Same gross trailer rating, a little lighter from the factory (So they said). When I took the camper to the scales, I was at 7000 lbs empty with all the options added. This didn't include my propane yet either. I had a bit more capacity than you 1325 lbs and in this picture had helwigs installed. It sucked.
    I tow in the snow all the time. Use some common sense and read road conditions and you will be just fine. I haven't been on 191 in a while. @MTgirl might be able to shine some light on those road conditions and construction.
  8. Dec 5, 2021 at 6:23 PM
    2mchfun
    20' 7k Toy hauler here is my largest load by size. Weight 9k Mini excavator and trailer.
    FRS[OP] likes this.
  9. Dec 5, 2021 at 6:30 PM
    Infernotundra17
    Martin
    Las Vegas, Nevada
    Sorry but my Tundra tows it great FRS hope this info helps you .
  10. Dec 5, 2021 at 6:35 PM
    Tows great huh? So what are you comparing it to?
    GODZILLA and Cpl_Punishment like this.
  11. Dec 5, 2021 at 6:55 PM
    Infernotundra17
    Martin
    Las Vegas, Nevada
    Got nothing to compare it to.I have had much bigger trailers that I towed behind a 7.3 Power stroke diesel that was chipped and bigger turbo and exhaust.All I am saying is the Tundra does better then expected.I know if I went any bigger then a 3/4 ton/diesel would be in order .
  12. Dec 5, 2021 at 7:00 PM
    Infernotundra17
    Martin
    Las Vegas, Nevada
    Thats a good looking trailer CJ
  13. Dec 6, 2021 at 11:25 AM
    FRS
    FRS [OP] New Member
    Thanks for your responses…
    THE net-net, I gather is that I will be about 400lbs over payload weight. So I will now look toward strategies to reduce squat and support that increased payload. My short list is as follows:
    • Sumo Springs
    • Super Springs
    • Roadmaster Active Suspension
    • Hellwig
    • Firestone “Airbags
    Knowing that there is no free lunch…I’ll need to balance between a ride that won’t beat my rig to death vs properly abating the additional weight put upon the rear springs…which means sizing correctly.
    TIA,
    FRS
    2mchfun likes this.
  14. Dec 6, 2021 at 11:28 AM
    2mchfun
    RAS is the best bang for the buck. I have sumo springs, hd leaf packs, and RAS on my truck.
  15. Dec 6, 2021 at 12:25 PM
    timsp8
    NY
    I think that 400 over was before gear, food, water, clothes, passengers. You’ll probably be a lot more over. Anything you add to help will only reduce your payload. Air bags will only transfer more weight to your rear axle causing more wear and tear or premature failure.
  16. Dec 6, 2021 at 12:29 PM
    18" TRD Off Road Wheels
    You cannot increase payload. Anything you add is still reducing it.
  17. Dec 6, 2021 at 1:23 PM
    2mchfun
    True, you can't change the numbers. However, the numbers are dust in the wind here. This guy needs suspension enhancements. E rated tires would be ideal too.
  18. Dec 6, 2021 at 1:26 PM
    timsp8
    NY
    Or a lighter trailer. Any addons will further reduce his payload. Looks like he might already have E rated tires with duratracs. I think most of those are E rated unless I missed him saying they weren’t.
    Oey12 and Cpl_Punishment like this.
  19. Dec 6, 2021 at 1:34 PM
    2mchfun
    He could have the tounge lengthened, use a TOAD, reduce truck weight, etc. and maybe squeeze by too. Sounds to me like OP is not looking for a different trailer, but help with making the best of the situation.
  20. Dec 6, 2021 at 1:40 PM
    timsp8
    NY
    Yeah he can do what he wants. My advice or suggestion was a lighter trailer. He will probably be over 8k when loaded. Any suspension enhancements won’t eliminate the trucks weak points, just put more stress on them.
  21. Dec 6, 2021 at 1:45 PM
    2mchfun
    One of the weak points happens to be the suspension and it can be beneficial to upgrade and remove that weakpoint to achieve far better handling. Especially with a heavy load and long distance.
  22. Dec 6, 2021 at 1:45 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Yeah no and if or buts about it that truck will probably be in the 8,200 range or 1,000 over, if not possibly more.
    The tongue weight listed is a bone dry trailer with nothing in it. By the one you add batteries, propane, anything else, I guaranteed that trailer will be 1,100 to 1,200 tongue weight. Or about 15% of total weight.
    Add in the WDH and suspension mods and you are putting another 300 pounds in the truck.
  23. Dec 6, 2021 at 1:52 PM
    2mchfun
    The bigger problem with this whole plan is the size of the sail. Should the wind gust in a bad way. Good Luck!!
  24. Dec 6, 2021 at 2:02 PM
    FRS
    FRS [OP] New Member
    Thanks Gents,
    I realize that short of tying helium balloons to my bumper, nothing will reduce the weight. My goal is to redistribute the weight (Aka : R6 WDH) and fortify the obvious vulnerabilities. (Cross drilled rotors all the way around to manage brake-fade and to manage the effects of gravity over the rear axle without beating it to death)…and there-in lies the question….to fortify the rear springs, with the understanding that I will be dropping a max hitch that weighs some where between 900 and 1100 lbs
    What products listed have members of the community used? What were the results? What weights/sized product did you select?
    Cheers,
    -FRS
  25. Dec 6, 2021 at 2:12 PM
    timsp8
    NY
    Look in to slotted rotors, specifically cryo slotted rotors. While cross drilled does help with brake fade by dissipating the gases, they are known to crack or warp easier. I’ve had powerstop cross drilled and now stoptech cryo slotted, and the stoptech were a huge difference for the better.
  26. Dec 6, 2021 at 2:21 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    In all honesty OP I understand your trying to distribute the weight best as possible but no matter how you slice it, you really are PUSHING the Tundra to the max and possibly past. Towing aids and suspension upgrades included… No one wants to see yourself or anyone else hurt because of it.
    But I digress…
    I have used airbags, Sumos, and Timbrens in previous trucks. They all achieved keeping the truck level with varying degrees of comfort. Unloaded airbags and Sumos made for a bumpy ride and Timbrens had this odd rebound. For their intended purposes they all worked well. But like others have said when overloaded they don’t work as well. I had to move my FIL’s 6k boat about ten blocks because his hitch snapped with my 03 Tacoma (rated for 5k). It did have HD leafs springs and Timbrens installed but it really wasn’t safe…
  27. Dec 6, 2021 at 2:27 PM
    2mchfun
    I used Dobinson's 5+2 HD leaf packs, RAS HD kit, yellow Sumo springs Bilstein 5160 shocks w/res. and BDS traction bars to minimize axle wrap. Truck drives great loaded with 2300 pounds in the bed, 1200 on the ball, empty, and anything in between.
  28. Dec 6, 2021 at 2:46 PM
    This is mostly what I've gleaned from my years browsing and reading on the forum here. This is not first hand info.
    • I know you can get add a leaf stuff like ColoradoTJ had on his, but he said it sucked, so...
    • Others use Sumo Springs or some other kind of helper spring. I've not seen anyone be particularly unhappy with them, but some have raised concerns that you are pinpointing the weight and possibly leveraging on components in the suspension.
    • Airbags are popular, but they can cause setting issued when used with a WDH. Same potential for leveraging on the suspension as Sumos.
    • The Roadmaster Active Suspension gets suggested a lot, but I've not seen a ton of documentation on results. @2mchfun has them, I think.
    • IIRC, some especially ambitious members out in California actually put in wider leaf spring mounts so a heavier duty set could be used. I want to say @fisherman951 was involved?
    • Sway bars are good for adding some stability to the truck.
    With your truck being a 2020, have you added a transmission cooler?
  29. Dec 6, 2021 at 2:49 PM
    2mchfun
    GODZILLA likes this.
  30. Dec 6, 2021 at 2:52 PM
    I wish I had enough money to hire Michael J. Fox as my truck photographer. :anonymous:
