Running new dash speaker wires
Discussion in 'Audio & Video' started by PWMDMD, Dec 4, 2021.
  1. Dec 4, 2021 at 2:04 PM
    PWMDMD
    PWMDMD [OP] New Member
    Worcester, MA
    2020 Tundra Platinum
    I'm integrating a 3-way x-over into my system and need to run new speaker wires from under the passenger seat to the dash locations. Anyway to do this without pulling the entire center dash apart? I have no problem pulling panels and seats out. I'm not worried about where to run it in the cabin - just negotiating from the dash speaker down through the dash. Any help is appreciated.
  2. Dec 4, 2021 at 3:19 PM
    You should be able to drop wire down the sides to the kick panels, and the center one can be fed across near the glove box area once you pull the panel.
    PWMDMD[QUOTED][OP] and 1lowlife like this.
  3. Dec 4, 2021 at 3:34 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If the wire doesn't feed itself down to the kickplate area, tape it to a good stiff zip tie and feed it thru top to bottom.
    You can also feed wire from one footwell to the other behind the center console this way.
    I like the 3' HVAC zip ties.
    You can find them at Lowes or HD.
    I have a bunch of these that come in handy for all kinds of uses.
    Amazon.com: Malco TY34 36 in. Nylon Ties for Flex Duct Installations, 25-Pack, Multi, 25 Pack : Electronics
    PWMDMD[QUOTED][OP] likes this.
  4. Dec 4, 2021 at 3:35 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Center speaker is really easy to access with the HU out..:D
    PWMDMD[OP] likes this.
