Demello Hybrid Rock Sliders Install
Discussion in '2nd Gen Tundras (2007-2013)' started by SanDiegoSlovak, Dec 4, 2021.
  1. Dec 4, 2021 at 9:27 AM
    SanDiegoSlovak
    SanDiegoSlovak [OP] Learning Thru Mods
    San Diego, CA
    2008 Double Cab SR5 4x4
    3" lift, 35" tires, hi-clearance bumpers + more!
    I am working on installing some Demello Hybrid Rock Sliders. I got the side bolts all snuggled up nicely. I was going to drill the holes on the bottom of the frame and noticed the bracket closest to the front of the truck isn't flush with the frame. From the looks of it the reason could be there is a frame weld that is on the way.
    For others who have installed the Demello hybrid rock sliders, have you faced the same situation? Did you just drill through the frame weld?
  2. Dec 4, 2021 at 10:46 AM
    Black
    2014 Tundra Limited CrewMax
    I can’t help other than saying my buddy got Demello sliders for his Tacoma and the fit was terrible he ended up having to modify them quite a bit to work.
  3. Dec 4, 2021 at 12:41 PM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    That weld doesn't seem to be touching the slider. Looks like the problem might be further back.
  4. Dec 4, 2021 at 1:03 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Just get several grade 8 washers to fill that gap between the frame and sliders.
