  1. Dec 3, 2021 at 11:38 AM
  2. Dec 3, 2021 at 11:39 AM
    RobertD
    Robert
    DFW, Texas
  3. Dec 3, 2021 at 11:39 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    As mentioned, no wiring needed. The only thing I could have wired was the reverse lights but I didn't bother. If I would have opted for power-folding then I would have needed to wire that up as well since my truck wasn't originally equipped.
    Taco-Spike and RobertD like this.
  4. Dec 3, 2021 at 11:40 AM
    See post #66158 from my 2020 SR5.
    Taco-Spike likes this.
  5. Dec 3, 2021 at 11:43 AM
    Taco-Spike
    Two Trucks
    RobertD[QUOTED] likes this.
  6. Dec 3, 2021 at 11:46 AM
    redrum448
    redrum448 New Member
    anyone have a write up or link to one on how to remove the grill insert and how NOT to break tabs?
    thanks in advance!
  7. Dec 3, 2021 at 12:03 PM
    RobertD
    Robert
    DFW, Texas
  8. Dec 3, 2021 at 1:11 PM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    Which Yota LED's?
  9. Dec 3, 2021 at 1:27 PM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    this is the only pic I got of it. Thinking about running a extension port wire for the mic so I can plug it in under where the heated seat controls are.
  10. Dec 3, 2021 at 2:10 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    A couple of folks asked about this so here is more info on the RCA jack I put on the back of my truck for the trailer camera.
    The jack is an Amphenol ACJB "D" Flange Panel Mount RCA Jack with a Neutrik SCD-W Sealing Cap - D-Series - IP65. Just search for RCA D flange Jack as many companies sell them with both solder and barrel connectors in the back. The camera is just a regular car backup camera with wiring run to the trailer hitch which connects to the jack. With the 4 way video switch shown I can select between the truck front, truck rear, and trailer cameras to the head unit at any time, controlled by the remote control attached to the left of the HU between the vent and the 4wd switch. The wired camera is probably more reliable, and definitely much cheaper than the wireless trailer backup cameras. FYI - where I mounted the jack is supported only by plastic and there is a wiring harness behind it.
  11. Dec 3, 2021 at 3:18 PM
    biebs96
    PA
    I have a swiffer too!
    canadianguy[QUOTED] likes this.
  12. Dec 3, 2021 at 3:26 PM
    AggiePhil
    College Station, TX
    Weighed it. No passengers, no cargo, full fuel. With only 7200 lbs GVRW, there isn’t much room left for passengers, cargo, and accessories.
  13. Dec 3, 2021 at 3:27 PM
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    2019 Silver Sky Limited Crewmax
    Diamondback SE RCI skid plate Husky Mats WeatherTech bed-liner SCS Ray10's Eibach Stage 2 coilovers Toyo AT3 275/70/18 RAS HD Tuffy console safe
    I found after lifting the end tabs and moving to the long section I used and extra nylon pry tool inserted between the surround and grill as I moved down to the next tab as being super helpful, it kept the tabs from reinserting themselves
  14. Dec 3, 2021 at 3:36 PM
    DuneShoot
    DuneShoot New Member
    West Phoenix
    ‘21 Limited Cement
    Mine is 6580 with lift, tires (295/70/18), full tank, and tool box pretty full.
    HulkSmurf14 likes this.
  15. Dec 3, 2021 at 3:47 PM
    AggiePhil
    College Station, TX
    Mine’s a Platinum trim with bedliner and AMP steps but still, only 960 lbs left. :(
  16. Dec 3, 2021 at 5:33 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Looking good! Welcome to the forum and thank you for your service!
  17. Dec 3, 2021 at 8:02 PM
    Beckusmc
    Beckusmc New Member
    Black Tundra Platinum
    Baja Design sport amber wide cornering.
    Thank You!
    GELCW likes this.
  18. Dec 3, 2021 at 8:03 PM
    Beckusmc
    Beckusmc New Member
    Install some new lighting up front. Added some Yota LEDs and Baja Design sport amber wide cornering.
    Which Yota LED's?
    mgm16trdpro and diablodalton like this.
  19. Dec 3, 2021 at 8:53 PM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Decided to put some amber led lights on the step bars. Drilled and mounted, and wired to a switch.
    I wished it could've been brighter.
    Rock lights on. Amber led lights on.
    Finally, the 30" Rigid SAE light bar is hooked up.
    Blue switch for Rigid Light bar and Orange for the amber lights on step bar. Wanted a simple setup.
  20. Dec 3, 2021 at 10:25 PM
    diablodalton
    Dalton
    Oregon
    How does tire and wheel weight change the payload? I get the extra stress on gearing and axles, but I thought capacity was chassis and suspension…? Is it due to GVWR?
  21. Dec 3, 2021 at 10:37 PM
    diablodalton
    Dalton
    Oregon
    Removed Plati badge. Ordered sublimated all black us flags too.
    GAknight, Part_time, equin and 6 others like this.
  22. Dec 4, 2021 at 3:41 AM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    I finished up my weld it yourself Rough Country bumper.
    GAknight, Part_time, JH5370 and 20 others like this.
  23. Dec 4, 2021 at 5:39 AM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Just ordered my toytech parts yesterday.
  24. Dec 4, 2021 at 7:49 AM
    cowboyjack
    cowboyjack New Member
    New high clearance rear bumper from WarFab!
  25. Dec 4, 2021 at 9:28 AM
    poheller
    Scot
    2018 platinum
    Just ordered the JBA Upper Control arms. Hope they work good.
    TampaRD Pro likes this.
  26. Dec 4, 2021 at 9:29 AM
    Zachp
    Zachp New Member
    Zach
    2016 tundra SR5 TSS 5.7
    Fresh out of spray!
    Going on today!
  27. Dec 4, 2021 at 9:33 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Looks good! You putting any lights or wench on it?
  28. Dec 4, 2021 at 9:34 AM
    Zachp
    Zachp New Member
    Zach
    Yes sir-
    Waiting on the light bar BD 30inch
    And im still shopping on a wench
  29. Dec 4, 2021 at 9:42 AM
    And one is definitely more expensive than the other! :rofl:
  30. Dec 4, 2021 at 9:49 AM
    Zachp
    Zachp New Member
    Zach
    You found the wench for ive been shopping for!
    GODZILLA and NewImprovedRon like this.
