drive train rubbing type noise proportional to speed
Discussion in '1st Gen Tundras (2000-2006)' started by frank2005sr5, Oct 25, 2021.
  1. Oct 25, 2021 at 9:35 PM
    frank2005sr5
    frank2005sr5 [OP] New Member
    Frank
    2005 Tundra sr5 4x4 4.7L AT
    This noise starts at about 30 mph ( 2 cycles per second (cps)) and increases to 4 cps at 60 mph and sounds like it is coming from the rear. It is there on engine power and drag and 2 and 4wd. It started about 3 months ago and has been getting progressively louder. The closest description I can give is the noise is similar to what I would expect from a tire momentarily rubbing on something under the vehicle. I did look and there is no such contact. I ran a test on my hoist with the wheels off the ground in 2wd only and the noise was still there. During this test both rear wheels were turning. An interesting statistic is that at 60 mph the wheels are turning at 12 rps so I have ruled out brake and tire issues. The rear diff oil is due to be changed at fall service and the level is good. Anyone have any ideas as to the cause.
  2. Oct 25, 2021 at 10:27 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've read a few threads about people changing out their gear oil for new and adding extra limited slip additive to the oil and it quiets down noises. May be the easiest thing to start with if the noise has anything to do with the differential.
    Schcoman likes this.
  3. Oct 26, 2021 at 9:28 AM
    frank2005sr5
    Frank
    Thanks for the input. I have had a dealer install the wrong oil in the past with terrible driveability consequences on turns. They even tried to charge me for removing the wrong oil I had paid them for and charge me again for the new stuff...didn't get away with it. I believe that there is a sticky dealing with the wrong oil consequence. My concern now, due to the age of the vehicle, is where the cost to cure the noise is going to lie within the price range of a wheelbarrow thru to a new truck. My plan is to take the truck in for service, find the noise, change fluids, check the noise again and move on from there. I need to solve this cause first because the truck is due for a new timing belt and radiator with the possible resulting damage to the a/c hardware attached.
  4. Dec 2, 2021 at 7:03 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    I have what seems to be the exact same noise. Keep us posted on your results and I'm off to have my diff fluid changed.
  5. Dec 2, 2021 at 7:03 PM
    frank2005sr5
    Frank
    Changing the LSD oil made no change in the problem. I have 3 possible culprits on the horizon, bad axle bearings, bad lsd differential and one or both of these interacting with the ABS system, hence proportional to speed. I hope to open the thing up next week and learn more but will disable the ABS and test before taking things apart. At 60 mph the noise is 4/sec and at 30 mph 2/sec and nothing else is turning at that rate, e.g. drive shaft about 44 and 22 rps and axle at 12 and 6 rps so I wonder about ABS and computer control. If I learn anything worthwhile I'll report.
    Schcoman, Punk1974 and w666 like this.
  6. Dec 3, 2021 at 4:54 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    is there a bearing at the slip yoke connection that could make this noise??
  7. Dec 3, 2021 at 5:23 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Drive a constant 60 mph until you hear the 4/sec noise, then disengage the overdrive. The engine RPM will increase while you hold a constant 60 mph. If the 4/sec noise remains the same, then you can eliminate transmission and transfer case. If the noise changes frequency, however, this suggests that those components are involved.
    bmf4069, dinosaur and Schcoman like this.
  8. Dec 3, 2021 at 12:48 PM
    frank2005sr5
    Frank
    Thanks for the new input. I suspect that any rear end bearing noise would by itself be too high in frequency for what I'm hearing but may interact with the LSD and maybe ABS to cause this symptom. I can confirm that the noise source lies past the transmission. The tests I ran included disengaging the overdrive at 60 mph and running down sequentially to second gear (30 mph for that one with a 2/sec noise) with no observed changes in frequency of the noise. I won't be convinced that ABS is not involved until I shut that off and retest. If I have to get into the differential the loss of a speed sensor will be a small sacrifice for knowledge gained. More to come.
  9. Dec 3, 2021 at 1:06 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    I'm totally lost as to how the ABS could cause your problem, or how disabling it would change a single moving part on your rear end. The tone rings are not physically connected to the ABS system, and cutting power to the speed sensor won't create/resolve any sounds. Do you suspect the fluid is pulsing voluntarily from the pump while you drive with your foot off the brake? And if so, wouldn't you hear it in the front? Or feel it braking?
    dinosaur likes this.
  10. Dec 3, 2021 at 1:22 PM
    10 blue trucks
    04 4WD RCLB
    What about an exhaust leak?
  11. Dec 3, 2021 at 2:36 PM
    frank2005sr5
    Frank
    Definitely not an exhaust leak. The ABS logic follows. The ABS controller operates on each wheel independently using momentary lockup seen by a speed sensor to release the brake on that wheel and reapply it. Here is where the "what-if"comes into play. With the noise under discussion at a wheel speed of about 12 rps the ABS controller (healthy or otherwise) would have to be operating every 3 wheel rotations over an unknown number of degrees of rotation. My line of thought for this is could a slight periodic braking force be enough to fool the LSD into periodic operation keyed to a wheel sensor speed output? The brakes seem to operate normally, there is no sensation on the brake pedal and no ABS warning light. Disconnecting a single sensor and doing a test run on the hoist seems like a worthwhille test before getting into the oily stuff. I guess I could pull fuses and make a bunch of other things happen at the same time. Thanks for your interest.
  12. Dec 3, 2021 at 3:28 PM
    10 blue trucks
    04 4WD RCLB
    Thats some pretty wizardly diagnostics, my mind is blown as my truck doesn't have magic independent wheel braking. I have a luddites non vsc, non lsd. None of my lsd vehicles have ever been audible when engaging.
  13. Dec 3, 2021 at 3:32 PM
    10 blue trucks
    04 4WD RCLB
    I think someone put a playing card in your spokes.
    shifty` and dinosaur like this.
  14. Dec 3, 2021 at 6:09 PM
    This was my 1st thought when I read this post not long after OP made it, but opted to keep my mouth shut because I seem to be gaining a reputation for ribbing too hard on the newbies who sign up to post their problems without any meaningful introduction. :D
    w666 likes this.
  15. Dec 3, 2021 at 6:53 PM
    10 blue trucks
    04 4WD RCLB
    Its not ribbing, its evidence of my level of understanding, but I could be wrong, might be a banana in his tailpipe causing a toot, synchronous with the pressure pulses but only under load.
    shifty` likes this.
  16. Dec 3, 2021 at 7:16 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Got an automotive stethescope? Have someone spin it up while on the hoist and pinpoint where the noise is coming from.
    I'm guessing ring and pinion/3rd member.
  17. Dec 3, 2021 at 7:30 PM
    10 blue trucks
    04 4WD RCLB
    if you calculated your axle to be spinning at 12rps, and your rear diff is geared at 3.x, your driveshaft is spinning at just under 4 rps.
    EDIT: DOH!!! False backwards math. Nevermind. carry on.
  18. Dec 3, 2021 at 7:35 PM
    10 blue trucks
    04 4WD RCLB
    if you think your lsd is locking multiple times per second, your truck won't behave well on turns. Do 60 mph full lock circles, let us know if you get wheel hop.
  19. Dec 3, 2021 at 7:42 PM
    1794TRD
    1794TRD It is, what it is!
    Little Rock, AR
    2015 Super White II TUNDRA 1794
    TRD EXHAUST TRD INTAKE Lift 3” front 1.5” rear TRD SKIDPLATE UNIFLEX TRIFOLD BED COVER UNIFLEX SWINGBOX POP & LOCK POWER TAILGATE LOCK TUNDRA BED LIGHTS LED HEADLIGHTS / FOG LIGHTS / PUDDLE LIGHTS / INTERIOR LIGHTS WHITE DOOR HANDLES WHITE MIRROR COVERS TOYTEC BOSS REAR SHOCKS CRUX AVITY-01 VIDEO INTERFACE AJT KEY FOB COVER
    Check the emergency brake pads. They are inside the hub of the rear brake rotors. One of the pads may have shifted inside and rotational force at speeds is generating a rub.
  20. Dec 3, 2021 at 7:46 PM
    10 blue trucks
    04 4WD RCLB
    are those like maxipads? we don't have maxipads or tampons in first gen rear brakes.
    bmf4069, dinosaur and shifty` like this.
  21. Dec 3, 2021 at 7:48 PM
    Definitely don't want to rub one out.
    bmf4069 likes this.
  22. Dec 3, 2021 at 7:54 PM
    1794TRD
    Little Rock, AR
    Maybe its your douche bag dragging. Good luck figuring it out then!
  23. Dec 3, 2021 at 8:00 PM
    10 blue trucks
    04 4WD RCLB
    :amen:
    If you came to be helpful, just point him to the page with the diagram of the rear disc assembly of his 2005.
  24. Dec 4, 2021 at 2:18 AM
    w666
    Maryland
  25. Dec 4, 2021 at 6:41 AM
    Sounds like a bearing. You've got carrier, rear pinion, and outboard wheel bearings as likely culprits. Carrier can be inspected visually for play and noise with the rear wheels off the ground. Pinion and outboard wheel bearings may be isolated with an auto-stethoscope. Good luck with this.
