What tire pressure should I be running?
Discussion in 'Wheels & Tires' started by TundrasseeMan, Dec 1, 2021.
  1. Dec 1, 2021 at 7:47 AM
    TundrasseeMan
    TundrasseeMan [OP] New Member
    Nashville, TN
    2020 Cavalry Blue Tundra
    I’m running Toyo Open Country AT 2’s 295/60/20s. Currently running 41 but curious what you all recommend
  2. Dec 1, 2021 at 8:02 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    use this to get you in the ballpark and adjust a couple lbs up or down based on how you load and drive your truck. You can also do a chalk test to confirm best pressure and footprint.
    https://www.youtube.com/watch?v=MIvbFgrH0IQ
    TundrasseeMan[OP] and Cruzer like this.
  3. Dec 1, 2021 at 8:58 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    ^^^^^^^ Yuuuup
    TundrasseeMan[OP] likes this.
  4. Dec 2, 2021 at 6:35 AM
    AJGallo41
    AJGallo41 New Member
    Aj
    MN
    2016 Tundra Crewmax 5.7
    Level Kit 275/70r18 BFG KO2's
    40psi all around, BFG Ko2s
  5. Dec 3, 2021 at 1:04 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    If stock size, follow what's on the door jam. If not, call the tire manufacturer or do the chalk test. My chalk test came within 1 psi what the tire manufacturer recommended.
