1st 24 hours of ownership - discovered a compost pile
Discussion in '2.5 Gen Tundras (2014-2021)' started by ronstory, Dec 2, 2021.
  1. Dec 2, 2021 at 11:47 AM
    ronstory
    ronstory [OP] New Member
    Well, less than day of ownership and was just walking around the vehicle to familiarize myself with the "Toyota Way" and noticed the door jams were rather dirty. I started to poke at the read of the front vendor and found the rubber access panel at the bottom. I pulled it back and this is what I found.
    That was about 75% of what was in there (about two cups of compost) and I got a hose to wash out the rest. The passenger side was only about half as much.
    It's going on my list of things to check when I do the oil change. YMMV.
    Thanks,
    Ron
    Darkness likes this.
  2. Dec 2, 2021 at 11:58 AM
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
  3. Dec 2, 2021 at 12:02 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yup the leaves and crap get in easily thru top area where fender meets door and windshield. Plug it somehow? Fill foam?
  4. Dec 2, 2021 at 1:17 PM
    ronstory
    Yes used, a 2016. So likely 5 years of accumulation. However it was pretty easy to clean out.
    I have ~25 years of hobby wrenching experience with land rovers. If it had been a rover, access would behind a panel with 6-8 10mm fine thread bolts with integrated washers that traps water behind it to enable "british locktite", resulting in 30% bolts shearing or thread stripping. The toyota took 15 mins to clean out, no tools and I was done.
    Also, I may have had to remove the hood on the rover too. It's tradition. I can't count how many times I've removed a LR hood. lol
    Piki, Darkness and snivilous like this.
  5. Dec 2, 2021 at 1:30 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Well you know what they say, if you want to get somewhere take a Land Rover. If you also want to get home take a Toyota :D
    Pillslinger, panicman, Kung and 5 others like this.
  6. Dec 2, 2021 at 1:40 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
  7. Dec 2, 2021 at 8:30 PM
    ronstory
    Actually the common wisdom is you just need two rovers since they create a mobile scrap yard. When you have a bad day, you can still get one functional vis cannibalizations.
    (insert emoji of Hannibal Lector here)
    snivilous likes this.
  8. Dec 2, 2021 at 8:49 PM
    Tundraction
    Tundraction New Member
    Duane
    Minnesota
    2014 SR5 DBL MGM 4x4 5.7
    Phone Charger
    Hmmm, Interesting. Ill have to check mine. Thanks for the heads up.
  9. Dec 2, 2021 at 8:55 PM
    Yota707
    Yota707 New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    I have discovered that same thing on my 2015. I have cleaned it out multiple times and it still somehow gets more in there.
  10. Dec 2, 2021 at 11:15 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It’s all the crud that falls down there from the cowl. Always a fun mess on any modern car when you need to pull a fender lol
  11. Dec 2, 2021 at 11:55 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    I've always wondered where the leaves went!
    How do I clean all that shit out, just remove the inner plastic fender?
  12. Dec 3, 2021 at 12:02 AM
    empty_lord
    05 rollover special
    Yea remove the inner fender liner and you can clean most of it out. Be warned, those clips are typically a one time use
    Dr Doobie[QUOTED] likes this.
  13. Dec 3, 2021 at 12:10 AM
    Dr Doobie
    Talkeetna,Alaska
    Cool thanks, I'll pick up replacements before I dive into it.
  14. Dec 3, 2021 at 5:33 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This has been happening in some form or fashion on my Toyotas (and a Nissan Sentra I inherited via marriage many moons ago that showed me that an actual fire ant mound/nest can take root in those spaces) for 25 years. Add it to your Spring Cleaning list.
    Ghost Rider likes this.
  15. Dec 3, 2021 at 6:05 AM
    Kung
    KG, VA
    My wife, after we bought our 2000 4Runner in 2011, wanted a Land Rover. My exact words are
    "If you want one, that's fine, but I WILL NOT cosign that loan." LOL
  16. Dec 3, 2021 at 8:11 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Don’t use spray foam! That stuff is known as DEATH FOAM in VW circles because they started using it in the 70’s to prevent moisture and exhaust gas getting through the bodies to the cabin. What the foam actually did was trap moisture and hold it, causing a phenomenal amount of rusting from the inside of the body outward. By the time you saw the paint bubbling on the outside it was too late.
    I am just pulling the thin plastic liner back and using a vacuum with a narrow attachment to clean mine, and compressed air.
  17. Dec 3, 2021 at 8:11 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    I have crap in mine all the time too!
    I thought it was a feature?
  18. Dec 3, 2021 at 8:15 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I cleaned mine monthly until covid and the trucks live in the garage.
