Bilstein 6112/5160
Discussion in 'New Member Introductions' started by BettyWhite20, Dec 2, 2021.
  1. Dec 2, 2021 at 6:00 PM
    BettyWhite20
    BettyWhite20 [OP] New Member
    2020 DC SR5 4X4
    New member here.... I have a 2020 DC SR5 4x4. Previously had a 2019 Tacoma TRD Off-Road 4x4 ACLB in Quicksand with OVT, Softopper, Powder Coated Factory TRD Off-Road Wheels wrapped in 265/75r16 Milestar Patagonia MT's. Prior to that was my first Taco, an '06 TRD Sport PreRunner ACLB that I had until '19 and actually had it and the TRD Off-Road together for a while. I was hard on the PreRunner, but almost made it 250k miles before I believe I spun a rod bearing? I called her "Black Betty". I can't complain about her one bit, great truck. I hated to let my Quicksand Tacoma go, but I needed something to handle my camper better. The Taco pulled fine, especially after the tune, just didn't have enough curb weight. Now that I have a Tundra and I want this one to live forever, and since my black Tacoma was "Black Betty" I thought "Betty White" was fitting. Sorry for the long intro.... I'm sure I'm not the only one to come from a Tacoma, wanted to let everyone know I'm a loyal Toyota owner (wife drives a Camry) and explain the handle, lol.
    I have the Bilstein 6112/5160 combo on order from Shock Surplus, pre assembled at 1.9". I'll wait and see if I want to add a CB Shackle to the rear. I'm looking for advice on how to search on the forum for similar setups, wheels and tires, etc. Any advice is appreciated. Thanks in advance.
    BillyB likes this.
  2. Dec 2, 2021 at 6:16 PM
    EZDoes It
    EZDoes It New Member
    Ed
    LSD (Lower Slower Delaware)
    2020 MGM CM SR5 TRD exhaust, TRD wheels
    Tint, tow mirrors, remote start, Razormotor taillights, Genuine trans cooler, tailgate light strip, Extang tonneau, TRD rear sway bar, trans cooler…(thanks TRD)
    Welcome from Delaware.
    BettyWhite20[OP] likes this.
  3. Dec 2, 2021 at 6:18 PM
    Vanskippy#91
    Vanskippy#91 New Member
    2017 Blue Tundra CM Platinum
  4. Dec 2, 2021 at 6:31 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    6112/5160 at 1.9”F/1” R.
  5. Dec 2, 2021 at 7:34 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Dec 2, 2021 at 8:22 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  7. Dec 2, 2021 at 8:30 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I went with a little more lift, but also with 6112/5160 combo on a '20 DC SR5.
    Front 3", top setting with Coachbuilder shims.
    Rear 1.5" with Toytec Shackles.
  8. Dec 10, 2023 at 5:33 AM
    tundramike13
    tundramike13 New Member
    Before and after with the 6112/5160 CB tie rod, CB shackles, dirt king UCA
  9. Dec 10, 2023 at 6:59 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I've got the 6112/5160 combo at 1.9" and factory rear. First picture is with 275/70r18 second picture is with 295/70r18 that I just put on a couple of weeks ago.
  10. Dec 10, 2023 at 7:01 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome from TX!
  11. Dec 10, 2023 at 7:12 AM
    BettyWhite20
    2020 DC SR5 4X4
    IMG_20220427_172759303_HDR-01.jpg Bilstein 6112/5160. Front set at 1.9" with CB shims for 2.5". CB +2 shackles in back for 1.25". Hartes Metal Hawkish 20 x 9 - 0 mm offset with 275/60r20 Nitto Ridge Grapplers. Go Rhino RB 20 Running Boards.
    kioti54 likes this.
  12. Dec 10, 2023 at 4:13 PM
    BettyWhite20
    2020 DC SR5 4X4
    How have your tires been wearing since the install? I'm thinking I may need to replace my UCA's as well, even though it's typically not recommended unless over 3" of lift. Mine should be around 2.5" but it actually raised it 3" and not from the tires because I actually had them on first while waiting on the Bilsteins. I had an alignment done at installation, and recently had another alignment after 20k miles after noticing the outside treads wearing pretty fast. Also wondering about the 1.5" lift in the back. I was thinking 1.25" was all I could go with the 5160's. I thought I'd still have a little bit of rake, but almost dead level.... only 1/8" higher in the back.
  13. Dec 10, 2023 at 6:36 PM
    Savmikey47
    Savmikey47 New Member
    Any driver lean for you?
  14. Dec 10, 2023 at 6:39 PM
    Savmikey47
    I’m waiting for my 275/70/18 wildpeaks to come in and I’ll be installing the bilstiens 1.9 in front. I think I might order the rear 5160s as well but keep in stock height for the rear
  15. Dec 10, 2023 at 7:57 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    Couldn't tell you. That truck was rear-ended and totaled out. I had about 14k miles on the tires at that point. They were wearing about what you could expect with that amount miles on them.
    You can do 1.5" with the 5160, won't be an issue.
