Muffler swap
Discussion in 'Performance and Tuning' started by mech_engineer09, Dec 1, 2021.
  1. Dec 1, 2021 at 1:12 PM
    mech_engineer09
    mech_engineer09 [OP] Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    My dad got a hole in his 2016 tundra's muffler. He has a double cab with the 6.5' bed. I have mine sitting in the garage since i replaced it with a BAM. Mine's a 2020 platinum (crewmax 5.5' bed) my question is I would like to just give him my take off so he doesn't have to spend any money replacing his, will mine fit though? I tried looking up the part numbers for both and see that they both have 2 options for part numbers, 1 of which is the same for both but not entirely sure which one mine has.
    dirtydeeds likes this.
  2. Dec 1, 2021 at 1:26 PM
    t4r2tundra
    t4r2tundra New Member
    2019 Platinum 4x4 - Smoked Mesquite
    See sig for mods...
    If his is the same 2 in 1 out and pipe diameter is the same I don’t see why it wouldn’t. As long as it’s not a ton bigger. We put aftermarket mufflers all the time (I have one too), can’t see an issue with replace it with a stock Tundra muffler from the same gen even if it’s not exact. Just need to get it welded up
  3. Dec 1, 2021 at 1:42 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I think it is the same and will fit. Easy to check visually and you can always measure both to confirm.
    mech_engineer09[OP] likes this.
  4. Dec 1, 2021 at 2:18 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Agreed. It fits.
  5. Dec 1, 2021 at 6:41 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    It’s a direct bolt on.
  6. Dec 2, 2021 at 6:58 AM
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    Thanks! just making sure there weren't any length differences with it being a crewmax vs double cab. He'll be happy about this lol (me too because I want this thing out of my garage).
