2011 Tundra cigarette lighter 12 volt power not working? Changed fused.Not working. Inline fuse?
Discussion in '2nd Gen Tundras (2007-2013)' started by JGLogistics, Dec 1, 2021.
  1. Dec 1, 2021 at 1:21 PM
    JGLogistics
    JGLogistics [OP] New Member
    Jared
    2011 Toyota Tundra
    Level Kit. bigger rims
    Somebody please help. The two power sources under the dash and the one in the back seat do not work. The fuse looks good I've changed it twice.
  2. Dec 1, 2021 at 1:46 PM
    JGLogistics
    Jared
    2011 Toyota Tundra
    I guess I didn't know that there was a second fuse box. Inside the cab right under the dash.
  3. Dec 1, 2021 at 3:25 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    If your Tundra is like my Sequoia and you have two outlets, there are two fuses. Most people don’t realize this.
    One may be labeled CIG and the other PWR OUTLET.
    The owners manual has the fuse information you need, knowing now that it could be one of two fuses that need replacement.
    Greg
