Replacing the TRD Dual exhaust mufflers only.
Discussion in 'Performance and Tuning' started by MaxYota, Aug 6, 2021.
  1. Aug 6, 2021 at 1:54 PM
    MaxYota
    MaxYota [OP] GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    I like the dual exhaust that comes with the Pro but I want something a little more aggressive. The start up rumble is OK and the sound is good when get'n on it but I also like to hear an idle rumble. Drone is no problem because I believe if you have dual exhaust and mud tires you should be able to hear both while driving.
    Has anyone swapped out only the mufflers for a different sound? If so what did you swap them out with and what was your end goal for sound? If you have sound clips that would be a plus.
    Thanks and I look forward to your responses.
  2. Aug 6, 2021 at 2:00 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    dirtydeeds likes this.
  3. Aug 9, 2021 at 9:53 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Thanks!!!
  4. Aug 9, 2021 at 9:54 AM
    dirtydeeds
    Keith
    USA
    Without an x pipe the sound of louder mufflers is very ‘glass pack’. But give a call. I can kick around ideas. And we hand build custom mufflers. Plus, I’ve tried all variations on a tundra. I’m happy to over options
    Keith 760-877-4234
  5. Nov 25, 2021 at 7:11 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    @MaxYota did you ever end up doing anything here? I'd been kicking around the idea as well. Would love to get just a little louder without purchasing an entirely new system.
  6. Dec 1, 2021 at 11:18 AM
    MaxYota
    Murf
    MS Gulfcoast
    No I've kinda put that on the back burner as of right now but I haven't forgot about it.
