Power steering pressure line
Discussion in '1st Gen Tundras (2000-2006)' started by Tdog111, Nov 30, 2021.
  1. Nov 30, 2021 at 1:05 PM
    Tdog111
    Tdog111 [OP] New Member
    Central Florida
    02 Sr5 4.7L 4x4
    Hello and thanks in advance for your time and help.
    2002 Tundra sr5 access 4.7L 4x4
    I replaced my power steering pump and also had to replace the high pressure line. I replaced the Valve Assembly Air Control-part number 17630-74010.
    Putting the system back together and bleeding the lines I see fluid leaking from under the air control. I'm wondering if there is a torque specification or if there is a gasket or washer that is needed?
  2. Nov 30, 2021 at 10:06 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Isn't it a tapered thread? If brass just snug it a bit more.
    Punk1974 likes this.
  3. Dec 1, 2021 at 8:50 AM
    Tdog111
    Central Florida
    02 Sr5 4.7L 4x4
    Ok that worked. I didn't want to over tighten the bolt. That's what started the problem. I couldn't remove the union or banjo bolt because it was over tightened and had to cut the head of the bolt off.
