Any good frame oiling recipes out there?
Discussion in '1st Gen Tundras (2000-2006)' started by Rdway60, Oct 17, 2020.
  1. Nov 30, 2021 at 6:49 AM
    #121
    tvpierce
    tvpierce Formerly New Member
    Maine
    Got it. It's not protection from CorrosionFree, it's enhanced protection for vulnerable areas. Makes sense.
  2. Nov 30, 2021 at 7:00 AM
    #122
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Shipping was already free and the bottles were $5.99 with my order, so figured I'd take a chance on them.
    I didn't spay my frame or underside with it, just some places around latches in door frames and under hood etc.
  3. Nov 30, 2021 at 7:09 AM
    #123
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    i think i’ll try this WD40 trick on my truck due to having about 7 bottles scattered all over the garage. stuff works pretty good for everything from rusty bolts to flea prevention. even repeals mosquitoes!!
    BravoDeltaRomeo likes this.
  4. Nov 30, 2021 at 7:49 AM
    #124
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    I’ve been saying wd40 2x year helps. All my jeep buddies use it on their undercarriage. Plus it’s not going to hurt anything. They use that back in the old days as wax
  5. Nov 30, 2021 at 7:59 AM
    #125
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    I got this baby from Harbor Freight along with a gallon of Woolwax:
    Going to use some kind of aerosol spray for the inside of the frame and nooks & crannies. Was planning on Fluid Film cans for that but this thread has got me thinking. I was wary of using a Cosmoline type of substance because I don't know this frame's history. As far as I know it has about 6 winters worth of salt wear and as far as I know something like Cosmoline has the potential to trap rust-causing stuff on the inside of the barrier it creates.
  6. Nov 30, 2021 at 8:00 AM
    #126
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
  7. Nov 30, 2021 at 8:01 AM
    #127
    Punk1974
    J.P.
    how you like that s&b cold air intake i bet its badass thinking of getting one..
  8. Nov 30, 2021 at 8:06 AM
    #128
    Punk1974
    J.P.
  9. Nov 30, 2021 at 8:20 AM
    #129
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  10. Nov 30, 2021 at 8:25 AM
    #130
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    I have TRD exhaust came with truck so with rubber plug on sounds same but completes the sound of the exhaust unless you lay into it. But once the rubber plug is off for extra air flow you definitely hear her. Not that it does a lot for gains but it looks badass under the hood. Nicely designed. I have sprint booster v3 too which is helps change shifts. But she definitely turns heads.
  11. Nov 30, 2021 at 8:28 AM
    #131
    Punk1974
    J.P.
    i heard the same saving for christmas for one lolz
  12. Nov 30, 2021 at 8:30 AM
    #132
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Look up Waxoyl recipes, I made some years ago for my old Scout that had some rust issues.
    Turpentine ,old motor oil and wax ( I used a couple of the wax toilet rings)
    Punk1974 likes this.
  13. Nov 30, 2021 at 8:39 AM
    #133
    Punk1974
    J.P.
    how did you apply it?..
  14. Nov 30, 2021 at 8:43 AM
    #134
    Rodtheviking
    Vancouver, WA
    Sequoia
    1 gallon pump sprayer from your local hardware store.
    Punk1974[QUOTED] likes this.
  15. Nov 30, 2021 at 7:16 PM
    #135
    Heavyopp
    Heavyopp New Member
    2000 V8 Tundra AC
    Certainly don’t want to do multiple applications per year — my initial corrosion free purchase was to include the premium application gun and a 5 gallon pail of the product — thinking I have 4 vehicles to do right away — that purchase is $500 plus
    I did overlook the buying for multiple vehicles when I suggested using wd40 would save me $475
  16. Dec 1, 2021 at 6:00 AM
    #136
    Punk1974
    J.P.
