  1. Nov 29, 2021 at 1:11 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Yeah, I know for a fact mine is auto-down only on the driver's side. It would be cool if something will work for AC/ DC too.
    I just think it's weird how @shifty` 's is.
    RUSTYNUTS and shifty`[QUOTED] like this.
  2. Nov 29, 2021 at 1:14 PM
    daveeasa
    You sure he's not doing a headstand while confirming that??? :)
  3. Nov 29, 2021 at 1:15 PM
    des2mtn
    SW
    Tonto cover
    Either that, or his truck was wired at the end of someone's shift!
  4. Nov 29, 2021 at 1:37 PM
    Looks like there's an IC involved for the auto down in my 02 AC Tundra. I'm sure the Sequoia has something similar but does auto up and auto down for both windows.
    des2mtn likes this.
  5. Nov 29, 2021 at 1:44 PM
    NWPirate
    Zach
    WA
    Same here, auto up and down for driver and passenger.
    des2mtn likes this.
  6. Nov 29, 2021 at 1:46 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Even if it was a tundra with complete gray interior trim pieces?!?!?
    RUSTYNUTS, NWPirate and daveeasa like this.
  7. Nov 29, 2021 at 2:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yea no. If the cab looked like that, I wouldn’t have useable part either
  8. Nov 29, 2021 at 2:22 PM
    I believe I asked EL a while ago if the switches or relays from a newer 4runner could be swapped over(all auto up/down from driver seat) but I think he said he hadn’t seen it done yet or that it was actually possible
    NWPirate and des2mtn like this.
  9. Nov 29, 2021 at 2:32 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    it would be nice to have all 4 like that. Makes me wanna tear apart the master switch to see if you can just swap each individual switch out to an auto one...
  10. Nov 29, 2021 at 2:39 PM
    empty_lord
    05 rollover special
    The window motors to
    Make it function properly don’t exist on our trucks. The 1st gen tacomas with a lot of wiring can have it work on the passenger side due to 4runners having a motor that works
    CodyP and FrenchToasty[QUOTED] like this.
  11. Nov 29, 2021 at 2:46 PM
    I just assumed it was something mechanical in the switch, independent of the motors. That mechanical item in the switch is what gives the audible 'click' when the switch is full throw, and the resistance when the motor bottoms out trips the switch OFF.
    But I'm probably grossly misjudging how it works.
  12. Nov 29, 2021 at 2:48 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    If i need my window down, im completely capable of holding the buttons.
    RUSTYNUTS likes this.
  13. Nov 29, 2021 at 2:52 PM
    What's unique about the motors that allow it to work for auto down and up on both driver and passenger side? I thought it was all in the controls of it.
  14. Nov 29, 2021 at 2:53 PM
    Probably the Hall effect to know when it’s all the way up or down.
  15. Nov 29, 2021 at 2:53 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    but you can't drop all 4 (or two) windows with one touch and then gangster lean with one hand on the wheel and the other on the console all the while your windows are still going down.....it's truly unacceptable.
    chrisb and NWPirate like this.
  16. Nov 29, 2021 at 2:53 PM
    empty_lord
    05 rollover special
    They have extra wires that control the anti pinch and all that
  17. Nov 29, 2021 at 4:49 PM
    chrisb, NWPirate, Punk1974 and 3 others like this.
  18. Nov 29, 2021 at 8:23 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  19. Nov 29, 2021 at 8:28 PM
    empty_lord
    05 rollover special
    factory mufflers on alot of cars are setup like that internally to kill noise.. on that.. i have no clue wtf
    Darkness[QUOTED] likes this.
  20. Nov 29, 2021 at 8:32 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If the internal pipe is perforated I can't imagine the exhaust doing the loop. Maybe it acts as a resonator?
  21. Nov 29, 2021 at 9:22 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Well, when you go shopping for exhaust at wallyworld……:notsure:
  22. Nov 29, 2021 at 11:37 PM
    empty_lord
    05 rollover special
    The VFtuner coming for 05 up tundras has me digging in deeper. If our trucks can produce similar gains as the 5.7, a stock 4.7 with a tune cab eek out 20ish hp. Makes me wonder what they’ll make with a tune optimised for headers and all that hood stuff..
    dinosaur, Darkness and chrisb like this.
  23. Nov 30, 2021 at 3:33 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    dinosaur likes this.
  24. Nov 30, 2021 at 4:38 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    That is truly ugly. But would THEORETICALLY provide double the muffling without two mufflers. Or if it's really sciency/lucky, it'll put the exhaust pulses on opposite nodes and cancel the noise that way.
    Most likely it's just an ugly, heavy, largely useless 'muffler'. But you never really know.
    dinosaur and Darkness[QUOTED] like this.
  25. Nov 30, 2021 at 5:02 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Dropped the corolla off today with new regulator. Quoted $175 for labor, and the part. Haven't gotten a quote for just labor. Figuring $100-ish. Money well spent.
    They also had this in line for repairs. A modded TF out Suzuki samurai. Trail warrior!
    My favorite part? The washers on the shock bolt.
    RUSTYNUTS, bmf4069, dinosaur and 4 others like this.
  26. Nov 30, 2021 at 6:19 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Single shear because no fear.
    (the far bolt is already bent)
    RUSTYNUTS, bmf4069, NWPirate and 3 others like this.
  27. Nov 30, 2021 at 8:06 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Received offer letter today..... need to be schlump
    Looking good!
  28. Nov 30, 2021 at 8:08 AM
    Congrats! Salary range looks good for you?
    Tundra2[QUOTED] likes this.
  29. Nov 30, 2021 at 8:09 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Non-exempt, eligible for overtime. $3 more an hour than I was expecting.
    $5.57 raise.
  30. Nov 30, 2021 at 8:10 AM
    That sounds like a win-win-win to me. Time to grow! Change is good, spread those wings brother.
    RUSTYNUTS, bmf4069, dinosaur and 3 others like this.
