Lower Ball Joints are 15 years old with 100k miles but no noticeable signs of wear. Replace?
Discussion in '1st Gen Tundras (2000-2006)' started by Alltimehigh, Nov 29, 2021.
  1. Nov 29, 2021 at 1:53 PM
    Alltimehigh
    Alltimehigh [OP] New Member
    Dealer last did them through the recall in 2007. Ive done 100k miles since mostly highway driving without much towing. Ive checked for play and sounds but they still seem solid. Should I replace them anyway?
  2. Nov 29, 2021 at 1:53 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  3. Nov 29, 2021 at 3:41 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
  4. Nov 29, 2021 at 3:43 PM
    Kanobi13
    Kanobi13 New Member
    If you are already tearing suspension apart then yes if no issues no reason to change
    Sunnier and Tundra2 like this.
  5. Nov 29, 2021 at 3:51 PM
    Maybe
  6. Nov 29, 2021 at 3:53 PM
    Sunnier
    Sunny
    San Diego, CA
    Lol! You could replace the bolt, one at a time. That’s what fails in my experience….
    Darkness likes this.
  7. Nov 29, 2021 at 4:13 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Sounds like my truck. Dealer replaced at 22K, I asked my mechanic to check them at 98K, he said not dangerous but ready. And 1500 labor, with some other stuff. Did it myself, drives/fells like new, although I could not tell they were worn other than spun easier in the ball than the new ones. It’s pretty hard to see .5mm movement.
    Punk1974 likes this.
  8. Nov 29, 2021 at 4:27 PM
    Ericsopa
    Ericsopa Old man and the sea
  9. Nov 29, 2021 at 4:43 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Is failure of an lbj on this gen catastrophic (remaining suspension drops to the ground)?
    2mchfun likes this.
  10. Nov 29, 2021 at 4:54 PM
    Alltimehigh
    YES
    des2mtn and 2mchfun like this.
  11. Nov 29, 2021 at 4:56 PM
    Great party conversation, though. You get to tell everyone about that one time when a bad BJ took out your suspension, and you only aim for good BJs nowadays.
  12. Nov 29, 2021 at 5:02 PM
    AWilliams
    AWilliams New Member
    Just did mine at 173k. I've had the truck 10 years and I've put 40k on in that time. No idea if the previous owner did them at 135k. They didn't seem bad but being unsure with the mileage....$240 is piece of mind.
    des2mtn likes this.
  13. Nov 30, 2021 at 6:00 AM
    des2mtn
    Shady Grove
    Tonto cover
  14. Nov 30, 2021 at 6:07 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    This popped up on my FB feed one day, but I didn't want to be a member of this club:
  15. Nov 30, 2021 at 6:57 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    which part of the part fails on these lbj?. is it the ball or the arm or the bolts?.?
  16. Nov 30, 2021 at 7:00 AM
    des2mtn
    Shady Grove
    Tonto cover
    Post #169 covers it decently.
    Punk1974[QUOTED] likes this.
  17. Nov 30, 2021 at 7:43 AM
    A well maintained part can last a long time and need not be replaced as a preventative measure. If you inspect and maintain regularly, replace as necessary. If you do not, or cannot, and don't have anyone you can trust to do it, replacement of the LBJ's is a good preventative measure. Failure of the part causes significant damage.
    Punk1974, des2mtn and Darkness like this.
  18. Nov 30, 2021 at 7:47 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I don't know.... could you repeat the question?
  19. Nov 30, 2021 at 7:56 AM
    Punk1974
    J.P.
    nice link thank you. very informative
    FrenchToasty and des2mtn[QUOTED] like this.
  20. Nov 30, 2021 at 9:02 AM
    Sunnier
    Sunny
    San Diego, CA
    In my experience, the bolts. But if you keep them properly torqued, they’d probably not fail. We heard sounds tied to tire/wheel revolutions on the days leading up, but couldn’t find the source. Afterword, we worked out that one bolt probably loosened, leading to vibration, which caused the others to loosen. At least one sheered on the trail, found in the dirt behind the truck.
  21. Nov 30, 2021 at 10:23 AM
    Seems like this thread should have been a poll.
    bmf4069 likes this.
  22. Nov 30, 2021 at 10:28 AM
    Sunnier
    Sunny
    San Diego, CA
    Naw, it’s in the first gen section. No matter how it’s posted, we’ll participate in a contentious and unorganized fashion.
    tunyota, bmf4069, Tundra2 and 6 others like this.
  23. Nov 30, 2021 at 12:18 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    To be fair, that's not a bolt failure, that's a bolt backing out. Perhaps a result of not being torqued properly or lack of thread locker?
    Tundra2 likes this.
  24. Nov 30, 2021 at 12:27 PM
    Sunnier
    Sunny
    San Diego, CA
    Yep, that’s what I wrote. I don’t think it was the LBJ itself, and that hasn’t been replaced. We cannibalized seat bolts from several later gens to fix it on trail, which got me 500 miles home. Then we replaced with new OEM bolts.
    bmf4069 and GODZILLA like this.
  25. Nov 30, 2021 at 1:01 PM
    Interesting. I originally thought the lower ball joint was actually improved upon for the recall. Now I'm not so sure.
    It sounds more like something may have been done to make the bolts loosen less frequently. Maybe a slight taper on LBJ bolt hole threads?
    SharkDog likes this.
  26. Dec 1, 2021 at 4:39 PM
    10 blue trucks
    04 4WD RCLB
    The metalurgy/engineering had to be improved. Many joints had the ball pull passed the retaining lip, some people sheared the pin, some people had the mounting bolts rip out. Toyota admitted a problem with the balls, if they hadn't improved that part in the new design, we would still be hearing about problems, but it went away.
  27. Dec 1, 2021 at 8:46 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    You also have to watch for spacer lifts that allow extra droop that can bind the Balljoints putting extra stress on them.
