Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. Nov 2, 2021 at 3:31 PM
    #421
    Robster80
    Robster80 New Member
    That is one sick lookin truck. U runnin any exhaust?
    BlueRibbon4x4[OP] and Rica25 like this.
  2. Nov 2, 2021 at 5:30 PM
    #422
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    Thanks man! I’m just running the TRD Pro exhaust, dumped after the axle.
    TRDFerguson, Rica25 and biebs96 like this.
  3. Nov 6, 2021 at 10:53 AM
    #423
    BlueRibbon4x4
    Geno
    Trimmed and redrilled the brackets that mount up the high lift jack. Now it sits higher on the driver side above the swing case, and I can install the second swing case that’s been sitting in my shop. I do need to move the locking mechanism up, hopefully I can get that done tomorrow.
    Being a carpenter, plywood is the only thing I need to haul once in a while that takes the width of the bed. Luckily the swing cases pop right off when needed. EE7E5EC9-21C4-4173-97E1-916AF2625475.jpg992D5014-650B-477B-80E6-4193DB94F93B.jpg
  4. Nov 6, 2021 at 2:44 PM
    #424
    BlueRibbon4x4
    Geno
    Second swing case installed.
    I’ve been having a lot of rattling from all the stuff in the bed. I’m missing bumpstops from the swing cases, something that’s easy to miss if you don’t know they’re supposed to be there. I got them used.
    I found this little red piece online that is used to eliminate the rattles from the ligh lift. I made one out of a little chunk of wood and some rubber door insulation. I’m sure I can find something that will work for the swing cases, but the rattle from the lift is pretty much gone altogether. 5DEB7BDD-914E-455B-9831-5FF955378A4A.jpg617E651E-0EF6-432A-BC7A-D875A685A4A2.jpg96B27C29-6863-4F94-A63E-E2903C04D24D.jpg9E8BA6AC-D3BE-4E74-8990-12B26F14919E.jpg52734CC0-0D7E-4DD6-B261-DAA8E3718D08.jpg
  5. Nov 13, 2021 at 9:05 AM
    #425
    BlueRibbon4x4
    Geno
    Color match of swing cases begins! Scuffed with red sanding pads and then Bulldog adhesive promoter. 0C987188-0818-4682-B833-6E7B1965E0E6.jpgB5573FFC-D2A7-4D69-BFB6-D1D569125BAE.jpg
  6. Nov 13, 2021 at 11:57 AM
    #426
    BlueRibbon4x4
    Geno
    Moving along. Decided to do the under seat storage as well. When my katzkins got installed, they scratched it moving the back seat in and out. 1011D695-275A-40A4-AFCB-A994E33F333D.jpgE8F88998-8B32-40B5-982E-33E446F9EDF8.jpg
  7. Nov 13, 2021 at 12:51 PM
    #427
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    When @BlueRibbon4x4 gets something for his truck that isn’t blue yet, but then the rattle can gets posted…
    GODZILLA and alwzdfiant like this.
  8. Nov 13, 2021 at 2:15 PM
    #428
    BlueRibbon4x4
    Geno
    :duel:
    GODZILLA likes this.
  9. Nov 13, 2021 at 3:33 PM
    #429
    BlueRibbon4x4
    Geno
    Done! Locks will get installed back in tomorrow. Gonna wait a few days to put the storage back in the truck. I’ll redo the black in a few days, they’re just a little used.
    B1905DF7-F6B2-4470-BF8F-0CBFC7E77DF6.jpg 2E8AC403-C24C-40F0-922D-91888DCA0D04.jpg E114CB12-DE82-4340-B029-5A33EBB0708B.jpg ABDA6E01-8B2F-4632-8CA7-6DB6E14F8C82.jpg 3774F49D-0106-43AD-BD5F-2145DB1ED707.jpg 4A1EB97C-83CC-42FA-87D7-79A5B8080599.jpg 0565B70C-0AF3-430F-B856-0A132142D250.jpg
  10. Nov 13, 2021 at 3:37 PM
    #430
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Looks great, man! Nice work as always.
  11. Nov 13, 2021 at 3:39 PM
    #431
    BlueRibbon4x4
    Geno
    Thanks Jake!
  12. Nov 13, 2021 at 3:58 PM
    #432
    BlueRibbon4x4
    Geno
    One more thing today. Grabbed a reel off Amazon for the pressure washer. Mounted a piece of plywood to the bars and the reel tomthe plywood. Now I don’t have to untangle all those damn loops from the old setup. Anything to make washing the beast an easier task. B98B5120-88C2-46F5-8CED-7C534F70A651.jpg
  13. Nov 13, 2021 at 4:01 PM
    #433
    biebs96
    PA
    I have to ask.. why the black cut out design?
  14. Nov 13, 2021 at 4:11 PM
    #434
    BlueRibbon4x4
    Geno
    They’re the manufacturer lines, so I used them. I thought just a full spray would just look monotonous, which sometimes makes things look cheap. Once thw black gets refreshed, they should pop nicely.
  15. Nov 13, 2021 at 4:14 PM
    #435
    biebs96
    PA
    I figured it was something to that effect.
    looks good as always.
  16. Nov 13, 2021 at 4:20 PM
    #436
    BlueRibbon4x4
    Geno
    Thanks!
  17. Nov 27, 2021 at 4:12 PM
    #437
    BlueRibbon4x4
    Geno
    Working on the grille light. It comes on and turns off with the puddle lights. It has a few settings, to alternate all the rgb colors, or a Knight Rider style that swings back and forth. They’re designed for the outside of headlights, so I’m installing them parallel behind the grille, so the color programs work in unison.
    I siliconed around the driver, since I think that’s what shorted the last one out. Tomorrow I’ll yank the grille and wire them up. 173E2876-1E6C-4A2E-B7D7-C120E8328150.jpg227DF1FB-C634-445E-8B8A-C333649F09D4.jpg0907A0FF-3A08-4E3B-9647-A0A420D7A4FD.jpgF7FAD2FF-F5F7-4214-933D-9D2CEEFCD6E5.jpg
  18. Nov 27, 2021 at 5:08 PM
    #438
    RobertD
    Robert
    DFW, Texas
  19. Nov 28, 2021 at 8:41 AM
    #439
    BlueRibbon4x4
    Geno
    Grille light moving along. Pulled the adhesive from them and flipped them over exposing the leds. This way they’re brighter since they’re not diffused. The grille is backlit so it won’t matter. I used Gorilla tape, I’ve used this stuff before and it works awesome. 4146F67A-F4B0-43A1-9F2A-6496033F5867.jpgE5E138F3-F90D-4C87-9288-DD903EC458F4.jpgFDB9929C-59C4-4F92-A90A-3921FE0AD75C.jpgD1A50AB1-D6F5-472C-A010-A1E470660E97.jpg3848E60F-29BF-4D86-950B-724DB48A933F.jpgFFC1347B-F8AE-4FE0-B2A9-244DD9F33B16.jpg
  20. Nov 28, 2021 at 12:20 PM
    #440
    BlueRibbon4x4
    Geno
  21. Nov 28, 2021 at 12:23 PM
    #441
    Unstable_Trip
    Unstable_Trip New Member
    Tom
    North MS
    '14 Blue Ribbon SR5 DC 4x4
    When lights do the knight rider back and forth, is it a single color or all?
  22. Nov 28, 2021 at 12:27 PM
    #442
    BlueRibbon4x4
    Geno
    Single color. But there are other animations with multiple colors that can alternate. It’s very inexpensive, so it’s not programmable or anything.
    Unstable_Trip[QUOTED] likes this.
  23. Nov 28, 2021 at 12:33 PM
    #443
    Unstable_Trip
    Tom
    North MS
    Honestly, was not expecting that answer. After I posted that I started thinking, "surely it couldn't be just a single color right? For safety and legal reasons?" Like you though, I would tap into footwell so it only does it when unlocked.
  24. Nov 28, 2021 at 12:53 PM
    #444
    BlueRibbon4x4
    Geno
    I know it’s crazy. On the sales pictures, they have all of these cars’ headlights lit up with blue and green and multiple color parking lights.
  25. Nov 28, 2021 at 5:26 PM
    #445
    BlueRibbon4x4
    Geno
    All connected. The grille comes on with the footwell light, so it’s off while driving. I always got compliments on it, and it always makes me smile when I’m unlocking my truck at night. 6995EB61-55A1-4E48-BFE2-0782F0DA1F68.jpg0E3DC7BD-FBF1-4E4A-ACA5-853F2AEA8FE8.jpgE252AE31-36A1-4839-98D1-E437B0352023.jpgE610AA0D-0EFA-477B-8180-C92EB3909585.jpgDB1C1313-A395-4168-BB8D-7B4968766BAC.jpg
    kodyquist21, GAknight, kuokoa and 4 others like this.
  26. Nov 28, 2021 at 9:42 PM
    #446
    BlueRibbon4x4
    Geno
    Been a while. Gave her a little wax job. 8295532A-CC22-4C6C-A0AB-D4B3BDE179F1.jpg
  27. Dec 11, 2021 at 2:12 PM
    #447
    BlueRibbon4x4
    Geno
    Well, got some funky noises coming from the front end. Verdict: UCAs leaking, wheel bearings are good, cv axles are good, 1 u-joint possibly shot. I get to go shopping. Kinda bittersweet. 6D248060-6111-4ED1-9559-FBA857A75AF4.jpg
  28. Dec 11, 2021 at 2:19 PM
    #448
    2mchfun
    UCA's leaking??? Like a bad ball joint boot?
  29. Dec 11, 2021 at 2:47 PM
    #449
    BlueRibbon4x4
    Geno
    Exactly
    2mchfun[QUOTED] likes this.
  30. Dec 11, 2021 at 2:51 PM
    #450
    2mchfun
    Not sure of your needs, but I have a set of oem like new in my garage. PM if you would like to make an offer.
    BlueRibbon4x4[OP] likes this.
