  1. Nov 24, 2021 at 4:10 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I’m sure a lot of those are related so probably not 17 issues but an issue nonetheless
    RUSTYNUTS likes this.
  2. Nov 24, 2021 at 4:15 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    300-308 are all misfire codes. 171 and 174 are lean codes.
    I'd say you've got an o2 sensor or fuel pressure issue.
    chrisb, TRDGen, Casper421 and 2 others like this.
  3. Nov 24, 2021 at 4:16 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Or a hose with a slice in er
    chrisb and Tundra2 like this.
  4. Nov 24, 2021 at 4:21 PM
    bmf4069 Captain wtf
    There's a definite hiss from under the intake, however, there's no vacuum lines under there. And that backfire into the intake has me clueless. I reinstalled the intake with a new gasket back in 18 I think. I don't see how any of that could matter though. I'm thinking fuel as well, but it runs fine while driving. It's only at idle where it's fubar.
  5. Nov 24, 2021 at 4:23 PM
    Did you pull the negative cable? Let the ecu relearn from the fix
    RUSTYNUTS and bmf4069[QUOTED] like this.
  6. Nov 24, 2021 at 4:26 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    My guess was coil(s). Googled my thoughts and this popped up (for the record I am a internet mechanic in training) -
    What are common reasons my Toyota Tundra has a rough idle?
    While there are a variety of reasons your Toyota Tundra has a rough idle, the most common 3 are a vacuum leak, an issue with the spark plugs, or a problem with the ignition coil.
    34%
    of the time it's
    Vacuum Leak
    21%
    of the time it's
    Spark Plugs
    15%
    of the time it's
    Ignition Coil
    NUDRAT and bmf4069 like this.
  7. Nov 24, 2021 at 4:43 PM
    daveeasa
    I can't decide if I like these or not. Definitely curious if they fit our first gens though and curious about the backspacing.
    Openbaffle and 0h6SR5 like this.
  8. Nov 24, 2021 at 5:05 PM
    bmf4069 Captain wtf
    No sir. I can give that a try tomorrow. But I'm worried it's more than that since it's still hissing.
    I thought coils too back when it started, as some of them have cracks. But, it's progressed well beyond that.
  9. Nov 24, 2021 at 5:10 PM
    Openbaffle
    Openbaffle New Member
    I like them. Looks like a challenge to keep clean.
  10. Nov 24, 2021 at 5:50 PM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    Yeah looks difficult to clean but I’m digging them. Thumbs up
  11. Nov 24, 2021 at 6:49 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Multiple misfires and lean fuel. Check all the hoses and spark plugs, wires, boots. Maybe fuel pump if none of that works.
  12. Nov 24, 2021 at 6:52 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I spent a lot of time looking at those. I did't like the offset or the 7.5" width for my projected tire size. There were some knockoffs that got close, but I went to a simpler Method @ 17X8.5 @0mm
    daveeasa[QUOTED] likes this.
  13. Nov 24, 2021 at 7:14 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Aftermarket intake gasket failed?
    chrisb and Punk1974 like this.
  14. Nov 24, 2021 at 7:34 PM
    Last time I had a similar issue, it was water in the gas. Didn't show up under throttle, only idling at lights or after starting up. Couldn't hurt to put in some Heet (dry gas) and 1/2 tank of gas and see if it gets resolved.
    I didn't have the 2k jump though, so it could be something else as well.
  15. Nov 24, 2021 at 9:51 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    That 2k jump happens often with vacuum leaks.
    chrisb and Jack McCarthy[QUOTED] like this.
  16. Nov 24, 2021 at 10:58 PM
    bmf4069 Captain wtf
    I just replaced the hoses. And I don't think spark would cause multiple misfires at this point.
    I don't dknow why I quoted this. Chalk it up to beer. My bad.
    I don't see how both banks could fail, but it could be a possibility.
    I was thinking about bad gas, but this has been happening for a while now, and keeps getting worse.
  17. Nov 24, 2021 at 11:32 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    If one banks misfiring it will drag the other bank with it. 1 dead cylinder in a car can cause 6 misfires if not addressed.
    chrisb, NUDRAT, jerryallday and 2 others like this.
  18. Nov 25, 2021 at 4:10 AM
    Openbaffle
    JustJake and FrenchToasty like this.
  19. Nov 25, 2021 at 4:52 AM
    daveeasa
    I think I’m strange but I really don’t know that I like the look of any aftermarket wheels on a Toyota truck. I do like the aftermarket options on width and backspacing though, and I can see how headlocks would be useful for doing legit wheeling.
    TRDGen likes this.
  20. Nov 25, 2021 at 4:55 AM
    Openbaffle
    I would tend to say I don't like 98% of the aftermarket wheels out there. I don't like the fake beadlock look. I like the SCS stuff. I like some of the simpler method offerings and I like the 4runner wheels that I have on my truck now as well as the TRD Pros in matte black that I see a lot of people run on our trucks. Agree on the nice options for backspacing and width. I do like the original limited 17s that were on our our trucks too.
    TRDGen likes this.
  21. Nov 25, 2021 at 5:19 AM
    daveeasa
    Which ones specifically? These?
    jImmegart likes this.
  22. Nov 25, 2021 at 5:40 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    Are these type 2 clutch packs rebuildable assasin?. thanks in advance.
  23. Nov 25, 2021 at 6:44 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    The FJ trail team wheels were the best but they're hard to find now and I wish they had em in 17x8.5 and better BS/offsett
  24. Nov 25, 2021 at 8:19 AM
    Openbaffle
    Woohoo. Got my cap.
  25. Nov 25, 2021 at 8:54 AM
    alb1k
    Left Coast
    It's good
    I think I just put T10 in there.
    Openbaffle[QUOTED] likes this.
  26. Nov 25, 2021 at 8:54 AM
    alb1k
    Left Coast
    It's good
    Sweet lid!
  27. Nov 25, 2021 at 9:00 AM
    Openbaffle
    TRDGen[QUOTED] likes this.
  28. Nov 25, 2021 at 9:02 AM
    Openbaffle
    Thanks! I’m so happy. And so happy to have the logistics work out to pick it up basically locally this morning.
    NUDRAT and alb1k[QUOTED] like this.
  29. Nov 25, 2021 at 9:22 AM
    daveeasa
    Yeah, they are nice. I like the 2021's a bit better, but $168 is a pretty good price all things considered. The 7" width is the only part I'm not sure about with these.
  30. Nov 25, 2021 at 9:28 AM
    daveeasa
    Looks awesome!
