Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Nov 15, 2021 at 4:30 PM
    #511
    Vizsla
    Vizsla 2 = 2.5
    Yes, he made several sets for me, and they went to few old friends. Recommend having some patience and reaching out to @papasmurf if interested in 3” SOA, be worth it if only for advice.
  2. Nov 16, 2021 at 6:16 PM
    #512
    Did you have issues with the corners of the bulge sticking up at times with those 2 end clips missing?
  3. Nov 24, 2021 at 9:37 AM
    #513
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    And then there were two
  4. Nov 24, 2021 at 9:38 AM
    #514
    Cruzer
    Cruz
    Sunnyvale, CA
    Yeah, just a little. I should’ve saved them.
  5. Nov 24, 2021 at 9:47 AM
    #515
    There was no way of keeping mine...they kept hitting the bar. Still researching the leaf springs. I'm still thinking Alcan over Deaver. The forum is so back and forth on spring opinions.
  6. Nov 24, 2021 at 9:56 AM
    #516
    Cruzer
    Cruz
    Sunnyvale, CA
    So I met a guy at T2S who was also rolling on 40s. He had Alcans with a 1000lb preload because he carried all of his tools daily for his work. I examined the springs and they were not saggy one bit. That’s when I knew Alcans were going to be my next set. My springs will have 1350lbs of preload.
  7. Nov 24, 2021 at 9:59 AM
    #517
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I need this. Link to the extensions?
  8. Nov 24, 2021 at 10:04 AM
    #518
    I think he said mine would be 200 lbs over stock weight capacity.
  9. Nov 24, 2021 at 10:10 AM
    #519
    Cruzer
    Cruz
    Sunnyvale, CA
  10. Nov 24, 2021 at 1:19 PM
    #520
    Decision was made. I ordered the Alcans about 30 minutes ago.
  11. Nov 24, 2021 at 2:30 PM
    #521
    Cruzer
    Cruz
    Sunnyvale, CA
    Did you get a military discount?
  12. Nov 24, 2021 at 2:53 PM
    #522
    Yes...50 bucks is 50 bucks. It was 924.00
  13. Nov 25, 2021 at 9:57 AM
    #523
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    so when's the 42s going on?
    Cruzer[OP] likes this.
  14. Nov 25, 2021 at 12:11 PM
    #524
    Cruzer
    Cruz
    Sunnyvale, CA
    Imma skip 42s and go 43s when someone invents a locking hub for the front passenger side wheel :cool:
    Downytide[QUOTED] and Sunnier like this.
  15. Nov 26, 2021 at 9:36 PM
    #525
    Cruzer
    Cruz
    Sunnyvale, CA
    RCV warranty has been dragging their feet on my warranty claim on the driver side that is popping so I was trying to “work” it today at the playground. Ended up busting the passenger cheapy CV axle. But no worries. The backup OEM axle I picked up from the junkyard earlier in the morning replaced it in 32 minutes.
    GodlessPro, TG705, 831Tun and 3 others like this.
  16. Nov 26, 2021 at 9:41 PM
    #526
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I will need you to show me your cv changing skills one of these days :bowdown:
    TG705, 831Tun, Sunnier and 1 other person like this.
  17. Nov 26, 2021 at 9:48 PM
    #527
    Cruzer
    Cruz
    Sunnyvale, CA
    Let’s go to Cougar Buttes in December, pretty sure I’ll show it off a couple times :D
  18. Nov 26, 2021 at 10:25 PM
    #528
    eccracer104
    San Diego, CA
    Just in time for my birthday! Let’s go!
    Sunnier likes this.
  19. Nov 27, 2021 at 7:24 AM
    #529
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I couldn't believe you changed it that fast. It took me like 3 hours to do both of mine:rofl:We went and did a few laps on that track, came back and you were done haha
  20. Nov 27, 2021 at 10:30 AM
    #530
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hey Cruz, does the PE lift pad come with a new center bolt too? I wanna convert one of my Arcan jacks. Everything is perfect except the shoulders on the head of the Arcan bolt are narrower
  21. Nov 27, 2021 at 10:59 AM
    #531
    Cruzer
    Cruz
    Sunnyvale, CA
    Does not come with a bolt. My first lift pad has an ID of 1”. The new lift pad is slightly bigger.
  22. Nov 27, 2021 at 11:00 AM
    #532
    Cruzer
    Cruz
    Sunnyvale, CA
  23. Nov 27, 2021 at 11:48 AM
    #533
    Cruzer
    Cruz
    Sunnyvale, CA
    831Tun likes this.
  24. Nov 27, 2021 at 12:25 PM
    #534
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thought about a washer, went and checked the extension and shonuf there's a nice void/hole for the bolt head should it stick up above the lift pad. Think I'm good to go but I wanna call 'em and see if I can get the bolt too.
  25. Nov 29, 2021 at 7:56 AM
    #535
    Cruzer
    Cruz
    Sunnyvale, CA
    Said I wouldn't buy another fridge and that all I needed was just ice for my brewskies but after transporting food in the cooler this weekend and having to deal with contaminated ice I gave in and bought a small Dometic CC 40. Fits 55 cans, that's enough for 4 maybe 5 days :cheers:
  26. Nov 30, 2021 at 8:55 AM
    #536
    Cruzer
    Cruz
    Sunnyvale, CA
    I was able to recover some pictures from the phone I drowned in the pool that had videos and pictures of my truck at Sand Hollow back in June:
    This guy right here is Eric, who is friends with Matt from "Matt's Off Road Recovery"
    Steering rack and CV axles were busted, and the tire came off the bead.
    Eric and his crew were able to drive my truck back to the staging area with no steering - amazing! They used the brakes when they needed to turn.
    Yes, our trucks fit in the Sand Hollow tunnel:
    And here's the Vegas pool party where my phone drowned in :rofl:
  27. Nov 30, 2021 at 10:08 AM
    #537
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Bro how do you of all people have fake beadlocks :rofl:
    wexttxco, TG705, Half Assed and 4 others like this.
  28. Nov 30, 2021 at 10:12 AM
    #538
    Cruzer
    Cruz
    Sunnyvale, CA
    :anonymous: I know I know, it's on my list :rofl:
    TG705, 831Tun, Hightide and 2 others like this.
  29. Nov 30, 2021 at 11:53 AM
    #539
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    This is a very valid point.
    I’m indifferent, however, I am surprised.:D
    831Tun likes this.
  30. Nov 30, 2021 at 1:18 PM
    #540
    Cruzer
    Cruz
    Sunnyvale, CA
    I try to do things to the truck without the :ballchain: noticing and wondering how much :spending:otherwise it'll be a lot of:angrygirl::boink::boom:
    TG705, snivilous, eccracer104 and 2 others like this.
