Load Resistor
Discussion in '1st Gen Tundras (2000-2006)' started by Mgrv, Nov 22, 2021.
  1. Nov 22, 2021 at 9:55 PM
    Mgrv
    Mgrv [OP] New Member
    2004 tundra double cab v8
    I have an 04 tundra and installed some LEDs on it. I know a common issue was trying to turn on the fog lights, but it would turn on the high beams instead. A lot of people bought a load resistor and placed it on the passenger side to fix the issue (H4-RL650-M: H4 Connection Load Resistor).
    my question is, where is the best place to mount it and how (ie. size screws, loctite glue? It’s all new to me.
  2. Nov 23, 2021 at 2:30 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  3. Nov 23, 2021 at 2:49 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Easy now.
    @Mgrv, you only need one resistor. I used two because I didn't have a definitive answer when I was installing mine.
    There's more room on the passengers side, and I used JBweld Steelstik to mount it against the engine bay wall behind the passengers side headlight. I'll get you a picture in a few minutes.
  4. Nov 23, 2021 at 5:39 AM
    Mgrv
    Punk1974 and FrenchToasty like this.
  5. Nov 23, 2021 at 2:32 PM
    Mgrv
    Do you have that picture?
