  1. Nov 21, 2021 at 4:31 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Best to order an elate S/C intake while you’re at it.
    Darkness, chrisb, RUSTYNUTS and 2 others like this.
  2. Nov 21, 2021 at 4:36 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Want
    alb1k likes this.
  3. Nov 21, 2021 at 4:36 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Nice 1. Looks like you have been diligent :)
    lsaami[QUOTED] likes this.
  4. Nov 21, 2021 at 4:38 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Still need someone to do a proper write up on that mod with pics and a video lol.
    Tundra2 likes this.
  5. Nov 21, 2021 at 4:46 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Whenever I get an interior to pop in the truck I’ll get photos.. for 05-06 at least it’s just one wire and a fuse tap that you need
    TRDGen[QUOTED] likes this.
  6. Nov 21, 2021 at 4:47 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    I finally got around to hammering the pinch weld on my DC today. https://youtu.be/PLHGI1_dbXw
    It's not glorious or proper, but I'll be darned if it doesn't work.
    Darkness, Punk1974 and FrenchToasty like this.
  7. Nov 21, 2021 at 4:48 PM
    alb1k
    Left Coast
    It's good
    Now that I've done it, I don't think Gen 1 owners have lived until they have pulled the bed. This is crazy talk for Gen 2+, but damn, what a rear suspension and frame insight. Note: not for DIY with custom paint jobs.....
    oscardog86, Voss, MS22 and 12 others like this.
  8. Nov 21, 2021 at 5:06 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Hows the top of the fuel tank/ particularly where bed meets cab? That's where all the crap tends to end up & start it rusting.
  9. Nov 21, 2021 at 5:11 PM
    How many people or what device did you use to lift the bed. I was in need of doing that today just to get at the rear shock bolts with a breaker bar.
  10. Nov 21, 2021 at 5:11 PM
    alb1k
    Left Coast
    It's good
    Very nice up there, considering it's my first look. I haven't been in the conditions with this truck to cause rust or bad debris. But it's all getting cleaned of course.
    NUDRAT[QUOTED] likes this.
  11. Nov 21, 2021 at 5:12 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    Frozen in Los Angeles cryogenispheric perfection.
    oscardog86, Darkness, chrisb and 2 others like this.
  12. Nov 21, 2021 at 5:17 PM
    alb1k
    Left Coast
    It's good
    The boy helped me for a hot second to get a 2X4 to another height. The rest was all me. Honestly, 3 more guys would have saved me a lot of time. I have a hard time asking for help. I recommend - unbolt, detach brake lights and fuel filler, have a place to go and three other guys to get there. I'll put it back that way. But, I felt like a boss driving out from under it.
    Darkness, chrisb, Tundra2 and 4 others like this.
  13. Nov 21, 2021 at 5:17 PM
    alb1k
    Left Coast
    It's good
    exactly.
  14. Nov 21, 2021 at 5:43 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    I'll be here. :D
  15. Nov 21, 2021 at 5:48 PM
    alb1k
    Left Coast
    It's good
    I should add, if it's just shock bolt clearance, you can do that by yourself. Just blocks between the frame and bed. But, If you are replacing, cut those fuckers out.
  16. Nov 21, 2021 at 6:48 PM
    Openbaffle
    Openbaffle New Member
    Man, those archive garage leaf springs and flipped u-bolts are really nice!
    Got the rest of the Torch add-a-leaf in. Got the shims in. Got the new u-bolts in and torqued. Drove it around the block a couple of times. Will check torque tomorrow after 10 miles or so.
    Voss, alb1k[QUOTED] and FrenchToasty like this.
  17. Nov 21, 2021 at 7:39 PM
    empty_lord
    05 rollover special
    found a use for some body plugs i've had laying around that i used to plug the rocker holes before... less shit can get in the bed now.
    [​IMG] [​IMG]
    Voss, chrisb, RUSTYNUTS and 3 others like this.
  18. Nov 21, 2021 at 8:01 PM
    alb1k
    Left Coast
    It's good
    I'm guessing that is damn near perfect.
  19. Nov 21, 2021 at 8:14 PM
    empty_lord
    05 rollover special
    anyone with an 05-06. have you removed the secondary filter on the airbox? im debating it.. just because i know its dyno proven on some cars to improve power by a cunt hair.
    Localsnap88 and FrenchToasty like this.
  20. Nov 21, 2021 at 8:19 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Nope.
    Considered it, maybe if I get an extra lid one day.
  21. Nov 21, 2021 at 8:23 PM
    empty_lord
    05 rollover special
    i may do it tonight. i mean.. it doesnt hurt anything for me. if theres a chance of gains. meh why not
    RUSTYNUTS likes this.
  22. Nov 21, 2021 at 9:22 PM
    gumbytron
    gumbytron New Member
    2007 Tundra 2WD SRS
    I bought this $15 cupholder cell phone mount from Amazon and modified it so it would mount to the space where the coin holder normally is (only on 2WDs). Only the top part was used, not the part that goes in the cup holder. I mounted it to a scrap piece of 1/4" Delrin that I cut into a round disc, but it could have also been plywood or something else.
    oscardog86 likes this.
  23. Nov 21, 2021 at 9:31 PM
    MHulsebos
    MHulsebos New Member
    Arizona
    2000 Tundra AC 4x4
    Replaced my steering rack and tie rods with brand new OEM replacements direct from Toyota. Also installed poly bushings in the new rack.
    Play in the old rack
    Old/New
    Oem bushings vs poly
    Poly installed and warranty voided lol
    Installed
    oscardog86, Voss, NUDRAT and 10 others like this.
  24. Nov 21, 2021 at 9:54 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    https://youtu.be/F1JmOKKAgyQ
    Engineering Explained
    This is the only video I've watched on it but it's been a while.
  25. Nov 21, 2021 at 10:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Voss, NUDRAT, Darkness and 5 others like this.
  26. Nov 21, 2021 at 10:25 PM
    alb1k
    Left Coast
    It's good
    Yew!
    Tundra2[QUOTED] likes this.
  27. Nov 21, 2021 at 10:35 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    @bmf4069
    bmf4069 and CodyP like this.
  28. Nov 21, 2021 at 10:46 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I love it…it almost like watching a mouse lick the peanut butter off the trap and then…SNAP! #thisis1stgen
    TRDGen, chrisb and RUSTYNUTS[QUOTED] like this.
  29. Nov 21, 2021 at 10:49 PM
    alb1k
    Left Coast
    It's good
    nailed it, lol @Tundra2
    FrenchToasty, Darkness and Tundra2 like this.
  30. Nov 21, 2021 at 10:52 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I did the whole ‘powerwash your seatbelt so it’ll retract like new’ deal, and it made zero difference. I have not yet hit it with silicone spray, so I’ll try that tomorrow before I give up on it.
    Oh yea,…. I also DIY’d truck bed coating
    oscardog86, shifty`, Darkness and 3 others like this.
