2021 nightshade HELP
Discussion in 'Wheels & Tires' started by smitty38, Nov 18, 2021.
  1. Nov 18, 2021 at 10:47 AM
    smitty38
    smitty38 [OP] New Member
    Hello all,
    I'm having the hardest time figuring out what tires I can switch to on my 2021 tundra nightshade. I have stock on now and DO NOT want to switch the 20" rims. Whats a great tire that looks way more toothy than the stock tire on now. I was thinking
    BRIDGESTONE DUELER A/T REVO 3, but I dont know if these will even fit without a leveling kit or raising. I'm trying to do this without any additional costs, other than the tires themselves! Thank you.
  2. Nov 18, 2021 at 10:51 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    BFG KO2, Cooper STT Pro, Ridge Grapplers, Wildpeaks......there are quite a few.
    Metro14536 and Taco-Spike like this.
  3. Nov 18, 2021 at 10:52 AM
    smitty38
    thank you, which size can fit without a lift or leveling kit. Sorry, i'm a rookie.
  4. Nov 18, 2021 at 10:55 AM
    MadMaxCanon
    That question is pretty complicated to answer in black and white terms. You can fit even 37 inch tires without a lift, but you would have to trim alot. comfortably you can fit 285/70 bone stock. Depends what you are willing to do to the truck. Spacers, new wheels will both have significant effects on this question.
  5. Nov 18, 2021 at 11:06 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    285/70/18 fits on stock suspension with stock wheels. Few tires available in that size. 275/70-18 is a nice size on a stock tundra and plenty of tires available in that size.
    Here is what is available in that size at DT- https://www.discounttire.com/fitmentresult/tires/size/275-70-18
    This is how 275/70-18 look
  6. Nov 18, 2021 at 11:08 AM
    smitty38
    ok great. Thank you. have 20in stock rims. Wondering if i'll need spacers. Not really looking to get a lift. Just really need to make my tires look more toothy and rugged.
    Thank you.
  7. Nov 18, 2021 at 11:24 AM
    frichco228
    Frank
    Virginia
    If you want to keep your 20s you can, just need to keep tire size in the 33inch range, 11-11.5 wide and you will be good to go.
  8. Nov 18, 2021 at 12:58 PM
    Nightshade1970
    Nightshade1970 New Member
    2021 Tundra Nightshade Edition
    Carven Exhaust, Nitto Ridge, Bora 2" spacers, TRD Rear Sway, AFE Air Filter, LED bulbs, Truxedo Pro cover, Eibach 2.0 Coilovers, Smoked taillights, Lamin-X fogs, more mods coming
    I put on Ridge Grapplers. I like the look. These are 285/60/20.
  9. Nov 18, 2021 at 1:54 PM
    smitty38
    Ok WOW!...those are exactly what i'd like to have!I have the same rims. Did you do anything else? Spacers, lift...etc. Sorry im a rookie here. I just dont want it to rub.
  10. Nov 18, 2021 at 3:06 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    BFG KO2's, 275/65/R20. No lifts, no mods, stock rims, no rub. Stock size is 275/55/R20, increased diameter only but might be able to go wider with 285's. You can have tire discounters or discount tire check fitment for rubbing prior to deciding.
    Kratos and AGSport like this.
  11. Nov 19, 2021 at 5:24 AM
    Nightshade1970
    I do have a lift on it. More of a level right now. They are Eibach 2.0 Coilovers. Stock back for now. Spidertrax spacers are on it as well, but when I was researching on here, there were a few running the 285 with no lift or spacers. So I think for you it can be done. May need to remove the small flap in front. Let me know if you need anything else.
  12. Dec 14, 2021 at 8:55 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    Those do look good with the wheels, how do they ride and how much road noise do you get?
  13. Dec 15, 2021 at 6:01 AM
    Nightshade1970
    Thank you. Really appreciate it. They ride great. PSI is at 45. Road noise is very minimal. Slight increase from stock. Very happy with them so far.
    Kratos[QUOTED] likes this.
