Gear oil
Discussion in 'Performance and Tuning' started by Hambone01, Nov 17, 2021.
  1. Nov 17, 2021 at 10:50 AM
    Hambone01
    Hambone01 [OP] New Member
    Where do you get your gear oil. All I see on shelfs is 75w90.
  2. Nov 17, 2021 at 10:57 AM
    starfish.pat
    starfish.pat New Member
    Patrick
    2008 Grey SR5 TRD Double Cab Short Bed
    I bought mine initially from AutoZone (4 individual quarts of Lucas Oil Synthetic 75W-90) , and then got the rest I need on Amazon in a 1 Gallon jug for less - www.amazon.com/dp/B000IG20RC
    I'm pretty sure for 07-13, both diffs and transfer case take 75W-90, but there are some alternatives that work. 2014 & up have something different for the transfer case.
    If you're wondering about Transmission Oil...I haven't tackled that one yet...good luck!
  3. Nov 17, 2021 at 10:59 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I order directly from Amsoil and I run 75-140
  4. Nov 17, 2021 at 11:05 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Big fan of amsoil too. Severe gear
  5. Nov 17, 2021 at 11:58 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Ordered OEM from SparkParts for a decent price a couple months back.
  6. Nov 17, 2021 at 12:45 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
  7. Nov 17, 2021 at 1:03 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
  8. Nov 17, 2021 at 6:04 PM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
  9. Nov 17, 2021 at 7:25 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    75w-90 is fine to use instead of 75W-85 in the differentials. There is only a slight viscosity difference between them, and that difference only exists for Toyota's fleet fuel economy. 75W-90 will protect better than 75W-85 as well.
    Any synthetic should be ok. I've had good luck with Mobil 1, Amsoil, and Valvoline. The Valvoline synthetic gear oil at Walmart in the Flex Fill bags (similar to the optional from Amsoil) make filling the diffs easier. I'll probably use those next time as the price is good for a quality product.
    Doxiedad likes this.
  10. Jul 14, 2024 at 8:44 AM
    Wallygator
    Red Line MT-LV 75W for transfer case
    Amsoil Severe Gear 75W90 for the diffs
    gizardlizard, FrenchToasty and 831Tun like this.
  11. Jul 16, 2024 at 3:16 PM
    luxury4play
    luxury4play New Member
    Oreilly has the squeeze pouches. makes for a easier fill in tight areas.
    Wallygator likes this.
  12. Jul 19, 2024 at 6:29 AM
    Wallygator
    Yeah I used the Amsoil squeeze pouches this last time and will never go back to the old bottle with a pump method. The pouches are way easier.
  13. Jul 19, 2024 at 6:45 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Amsoil 75-140 here
