Kayak Transportation Idea
Discussion in 'Towing & Hauling' started by contenderv07, Nov 16, 2021.
  1. Nov 16, 2021 at 5:25 AM
    contenderv07
    contenderv07 [OP] New Member
    Will
    Hey everyone, I'm looking to be able transport 2 fishing kayaks (probably under 12 feet). My wife and I go fishing and the spot is only about 5-8 miles away so we don't need it to be super construction. A low profile rack system is in the works for longer hauls, but I had an idea and wanted to run it across yall.. I was wanting to get 2 cargo bars, mount them almost to the floor of the truck bed, then add the kayaks mounts too that bar. Would that be too much weight on those bars? If i put them on the bed of the truck it won't be such a hassle getting them down. If this is way or or you have any other ideas, let me know too! Thanks!
  2. Nov 16, 2021 at 5:29 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I'm guessing those bars won't handle it. Are the cargo bars load bearing?
    At 5-8 miles....lower the tailgate (or maybe even leave up, so the kayaks are angled out the back), strap the crap out of them and drive slow.
  3. Nov 16, 2021 at 5:39 AM
    contenderv07
    Will
    not sure about loadbearing but I could try to find some that are. Maybe I just strap the crap out of them and use the money for a lo-pro rack
    Tundra2 likes this.
  4. Nov 16, 2021 at 5:41 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Ther is no way those bars will hold. I have toyed with the idea of the following:
    1. buy galvanized pipe from big box hardware store and cut to width of utility track system.
    2. weld plate onto each end of pipe
    3. Drill hole in plate to match the t-slot nut that fits into utility track
    4. Bolt cross bar / plate to t nut.
    I am just learning how to weld and thinking of ideas but this has been one on my mind for awhile. I think it could work and be a cheap and functional alternative
    contenderv07[OP] likes this.
  5. Nov 16, 2021 at 5:47 AM
    contenderv07
    Will
    Another idea was to get some yakima (or whatever brand) mounts and try to bold them to the bed of the truck, but that would leave holes unless I could add rubber grommet to cover it. Sorry just thinking out loud
  6. Nov 16, 2021 at 6:03 AM
    shawn474
    MoCo, Maryland
    yeah I am always nervous about drilling through the bed / truck in areas that there aren’t already holes!
    looks to be 63” from track to track. If there was a way to thread the ends of the pipe, you could even screw the premise flanges onto each and. Then thread a bolt through the flange into a t nut in the track. Would make a for a very easy install and removal without having to break the entire thing down each time. Unbolt and slide the whole thing out of the track and store…..
  7. Nov 16, 2021 at 6:09 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Do you have a DC or Crew? I have a Crew and carry two ten footers. If I am only carrying them I just strap then in the bed with tailgate down- fits well. If I am towing something or need to use the bed to carry other items too- I use this rack a made. Rack has double duty as a kayak rack for storage of them when not used to haul them.
  8. Nov 16, 2021 at 6:15 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Those hitch extention brackets are pretty slick and they arent too expensive. A heavy duty one may be able to handle 2 stacked. I got mine for like 60 bucks from Lowes, more than sturdy enough to handle my 2 man kayak.
  9. Nov 16, 2021 at 6:22 AM
    contenderv07
    Will
    I've been looking at those too but I need to measure the width. I didn't make the mistake of getting a double person kayak for my wife and I;). especially for fishing, as soon as she hooked in to one, I 'd be in the water
  10. Nov 16, 2021 at 6:27 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    If your kayaks are worth any amount of money....don't risk them falling out the back and damaging or worse...causing an accident to vehicles following you.
    Buy a Rhino, Thule or something removable. My Thule comes on and off in under 2 minutes for my canoe. When it's not in use, it sits in my shop.
  11. Nov 16, 2021 at 6:31 AM
    18" TRD Off Road Wheels
    Bad idea. Don't weld galvanized steel.
  12. Nov 16, 2021 at 6:36 AM
    MadMaxCanon
    Yeah the double man kayak isnt my ideal, but it was 100% free so i cant argue with that. That picture is similar to what im talking about but it looks flimsier than the square tubed one I got. I think its rated for 300lbs but I got the "junior" one. I think the beefier one is rated to like 500 lbs which should be plenty for 2 singles.
    Edit: I guess that is a square one.
  13. Nov 16, 2021 at 6:44 AM
    2mchfun
    Just grind off the galvanizing compound in the weld area, weld, chip, grind, apply spray on cold galvanizing compound. I do this a few times every single month. Rust free construction.
  14. Nov 16, 2021 at 6:45 AM
    contenderv07
    Will
    actually found a guy on Amazon with a tundra and review, only $80 too
  15. Nov 16, 2021 at 6:45 AM
    MadMaxCanon
    Nice, cant beat that price.
  16. Nov 16, 2021 at 2:51 PM
    shawn474
    MoCo, Maryland
    good to know; as I said I am novice welder. Learned something new today. Guess I would use regular pipe then…..
  17. Nov 17, 2021 at 2:16 AM
    Retired...finally
    Ask for mechanical tubing. It's for structural applications.
    shawn474 likes this.
  18. Nov 17, 2021 at 5:26 AM
    Retired...finally
    Best option yet. Will look manly too.:militarypress:
  19. Nov 22, 2021 at 11:37 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I put my 11' in my crewmax straight in the bed, then run a strap from anchor point to anchor point around the end of the kayak. Ain't going anywhere.
