Toytec lift installed incorrectly?
Discussion in 'Suspension' started by CP17Tundra, Dec 2, 2019.
  1. Dec 2, 2019 at 9:46 PM
    CP17Tundra
    CP17Tundra [OP] New Member
    Clay
    Seattle
    Silver 2017 Tundra Limited
    3” lift, SCS Ray 10 wheels, Nitto Ridge Grapplers, bumper shims, interior LEDs, Baja Squadron fog lights, SPC UCAs, Bushwacker flares
    I think I may have a problem. I had a local shopinstall the Toytec Boss lift on my 2017 Tundra Crewmax today. I ordered the complete kit with UCAs, 700lb front coil overs, and rear 3 leaf AAL spring pack.
    When I picked it up, the rear looked lower than the front, but could not tell for sure - dark and the parking lot was not level.
    when I got home was poking around and it looks like the overload leaf was removed from the stock pack and the add a leaf wasinstalled directly on the spring mount pad. The description on the Toytec site says the spring pack mounts on top of the overload. Is this correct?
    in any event, didn’t get as much rear lift as expected - maybe 3/4” - 1”.
    appreciate your thoughts.
  2. Dec 2, 2019 at 10:03 PM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Yep, looks like they removed the overload spring and installed your 3 leaf aal. They probably thought the were supposed to remove the overload. I've installed aal's before and it says to remove, but now days, I don't think your supposed too. Take it back and tell them install the overload spring back on the bottom of the pack. That should give you the lift you were supposed to achieve.
  3. Dec 2, 2019 at 10:07 PM
    easleycrawler
    Travis
    The aal's I've I've installed before, was on a couple Tacoma's, they were 2" aal. Which has a good bit of arch to them, might be why those were supposed to remove the overload. I'd definitely take it back and have them reinstall the overload. Hopefully they didn't throw them away.
    CP17Tundra[OP] likes this.
  4. Dec 2, 2019 at 10:08 PM
    CP17Tundra
    Clay
    Seattle
    That’s what I was afraid of....
    thanks.
    Rica25 and easleycrawler like this.
  5. Dec 3, 2019 at 4:01 AM
  6. Dec 3, 2019 at 6:23 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    As stated above, the overload was removed.
    For the 07+ Tundra 4WD/2WD the progressive 3 pack AAL provides approximately 1.5" of lift installed on top of your overload spring.
    If you want, take some ride height measurements from center of wheel hub to edge of fender in the front / rear and let me know. My guess is that you are going to be about 25'' front and 24.5'' ish rear...
    Let us know how we can help!
    Thanks
    MS22, Rica25, T-Rex266 and 1 other person like this.
  7. Dec 3, 2019 at 6:34 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I installed the Icon pack (same 3 leaf expansion idea). They stated it would be OK to install without the overload being that I only wanted about 3/4" lif.
    ...fast forward 6 months, my leaf pack was so clapped out I was actually sitting lower than stock.
    Then I reached out asking why I lost so much height, they said why did you install without the overload? We can't warranty that.
    Always keep your conversations with companies!
    I screen shot my convos and they said.....oh, well, uhhhh - we will send you a new expansion pack. Make sure to install the overload this time..
    Rica25, TheBeast and CP17Tundra[OP] like this.
  8. Dec 3, 2019 at 6:36 AM
    CP17Tundra
    Clay
    Seattle
    I’m calling the shop that did the install this morning. More to come. Thanks for the help.
    Rica25 and TXMiamiFan like this.
  9. Dec 3, 2019 at 6:38 AM
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Hopefully it goes well!
    Rica25 and CP17Tundra[OP] like this.
  10. Dec 3, 2019 at 6:40 AM
    CP17Tundra
    Clay
    Seattle
    Everything always eventually gets solved....it’s jut a matter of how much aggravation, time, sweat, and money......
    Thanks....
    Corrosivetendency and Rica25 like this.
  11. Dec 3, 2019 at 6:45 AM
    Vizsla
    Vizsla 2 = 2.5
    FYI, ran the same pack without the overload intentionally because it rides much better. 3/4” lift after it settled in. Added 1” blocks to get the correct ride height. Worked really well.
    saybng, CP17Tundra[OP] and GHOST like this.
  12. Dec 3, 2019 at 10:56 AM
    CP17Tundra
    Clay
    Seattle
    How did it perform towing / hauling?
    I have a heavy boat and haul with some frequency.
  13. Dec 3, 2019 at 11:33 AM
    Vizsla
    Vizsla 2 = 2.5
    Noticeable improvement with weight carrying, my truck gets run hard off road loaded heavy. No towing though, think you want that overload for towing regularly.
    ZPhilip likes this.
  14. Dec 3, 2019 at 11:52 AM
    CP17Tundra
    Clay
    Seattle
    Front is 25.5 and 25.25
    Rear is 24.25 and 24.5
    TheBeast likes this.
  15. Dec 3, 2019 at 11:55 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    That is one clean undercarriage.
    Rica25, TheBeast, Pudge and 1 other person like this.
  16. Dec 3, 2019 at 11:58 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    I forgot what the thread was even about after seeing that picture.
    Rica25 and TXMiamiFan[QUOTED] like this.
  17. Dec 3, 2019 at 12:04 PM
    fliberto38
    fliberto38 New Member
    Frank
    Ft. Worth, Texas
    2019 Silver Tundra TSS Off-Road
    Toytec/Radflo coil overs, SPC UCAs, Diff drop, Toytec/Deaver AAL, Toytec Boss rear shocks
    I used the same lift and kept the overload spring in. My truck sits level
  18. Dec 3, 2019 at 12:05 PM
    fliberto38
    Frank
    Ft. Worth, Texas
    The bed also has a bunch of camping gear in it
    TXMiamiFan likes this.
  19. Dec 3, 2019 at 12:05 PM
    CP17Tundra
    Clay
    Seattle
    That’s what I’m looking for! Nice.
    Rica25 and fliberto38[QUOTED] like this.
  20. Dec 3, 2019 at 12:07 PM
    fliberto38
    Frank
    Ft. Worth, Texas
    Parked in a different spot for different ground comparison.
    Rica25 likes this.
  21. Dec 3, 2019 at 12:07 PM
    TXMiamiFan
    Jose
    OK, now you are just showing off :rofl:
    Rica25 and GODZILLA like this.
  22. Dec 3, 2019 at 12:09 PM
    fliberto38
    Frank
    Ft. Worth, Texas
    Maybe........ :)
  23. Dec 3, 2019 at 2:04 PM
    Mr_Lahey
    Mr_Lahey New Member
    SE Idaho
    2016 TRD Double Cab (Black of course)
    Once you go black you never go back.
    Wow, west Texas sure is purdy. Who'd a thunk.
    I'm trying to figure out where that's at? The pics by the river kinda looks like my neck of the woods and the bottom pic kinda looks like GTNP.
  24. Dec 3, 2019 at 2:09 PM
    fliberto38
    Frank
    Ft. Worth, Texas
    They are all at GTNP.
    Rica25 and Mr_Lahey[QUOTED] like this.
  25. Dec 3, 2019 at 4:23 PM
    CP17Tundra
    Clay
    Seattle
  26. Dec 3, 2019 at 8:05 PM
    CP17Tundra
    Clay
    Seattle
    Ok, the shop still had the overloads, going to”fix” it on Friday. PNTA , but all will be fine.
    Shoulda just done it myself.
    thanks for all the help & support. Love the forum!
    CP
  27. Dec 3, 2019 at 10:09 PM
    easleycrawler
    Travis
    Good deal, glad it's gonna work out for you.
  28. Dec 6, 2019 at 8:54 PM
    CP17Tundra
    Clay
    Seattle
    So the story ends with the overloads being replaced. Looks like I got 1 1/2” inches of rear lift and a bit more than 3” up front ( will crank it down a bit more tomorrow). Sorry, no pic, I’m scared of the dark......
    Will post one later.
    fliberto38, easleycrawler and Rica25 like this.
  29. Nov 15, 2021 at 2:06 PM
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Can you recall what the front coils were set at. I'm going Elka 2.5 fronts, setting them around 1.75", and would like to keep the rake for towing and lighter loads. How did the rear ride/handle in comparison to the factory before and after?
  30. Nov 15, 2021 at 2:09 PM
    BCTRD
    BCTRD New Member
    B.C.
    Looking for opinions on how they ride compared to stock with the overload. I was set on shackles and now considering the same leaf package.
    TFTundra likes this.
