Help with bolt and nut part numbers - 2016 Tundra Crewmax Limited
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mralfie, Nov 14, 2021.
  1. Nov 14, 2021 at 3:30 PM
    Mralfie
    Mralfie [OP] New Member
    San Diego
    Hello,
    Can anyone give me the part numbers for this bolt (tow hook bolt) and the nut (one of 8 nuts that attach the bumper bar (located just above the tow hook).
    Thanks!
  2. Nov 14, 2021 at 7:03 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I don't know the part #s but pretty sure I have those lying around. Where you located? If you're nearby you can have 'em.
  3. Nov 14, 2021 at 7:16 PM
    The part number for the tow hook bolt is not listed on Sparks but it is an M12 x1.25.
    NewImprovedRon and 831Tun like this.
  4. Nov 14, 2021 at 7:19 PM
  5. Nov 14, 2021 at 7:29 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  6. Nov 15, 2021 at 6:51 AM
    Mralfie
    San Diego
    Thanks for the help guys. I reached out to Sparks to see if they can help as the diagrams are not perfect. I was thinking of going to Depot to get the bolt but I was wondering if it is a special type of bolt designed to take the pulling force from the tow hook.
  7. Nov 15, 2021 at 2:00 PM
    Mralfie
    San Diego
    Quick update on this one-
    I just got back from the dealership and this is what I found out:
    The part number for the tow hook bolt is 90119-A0167. It comes up as a wheel bearing bolt or something but it is also the same bolt as the tow hook bolt.
    The nut I bought was 90178-A0086. It don't think that it was exactly right as the head was a little thicker than the others but it worked just fine.
    Thanks again for all of your input.
    831Tun likes this.
