sway bar
Discussion in '2nd Gen Tundras (2007-2013)' started by ausei, May 22, 2015.
  1. May 22, 2015 at 9:00 AM
    ausei
    ausei [OP] New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    will a sway bar help with axel wrap? also does a lift kit effect install of sway bar?
  2. May 22, 2015 at 11:33 AM
    I may be wrong, but I would think not on the axle wrap. Can you add shims to the drive shaft?
  3. May 22, 2015 at 11:54 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    No help with axle wrap, and I would imagine the lift would affect install. The end links where the sway bar ties to frame would likely be too short
  4. May 22, 2015 at 3:18 PM
    ausei
    Ause
    Baton Rouge, LA
    i think i saw someone lower their drive shaft in another thread. im not sure though. is their real benefit to having it. i feel like it may help because my center of gravity is higher. and its relatively inexpensive and easy install. im going to have look at a few videos on install to see.
