General Supercharger Thread
  1. Nov 9, 2021 at 4:10 PM
    #781
    Saltyhero13
    Saltyhero13 Throbbing Member
    Oh so that confirms the injectors would be a factor. I figure the base ECU wouldn't know it has high flow injectors.
  2. Nov 9, 2021 at 4:11 PM
    #782
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    my MPG dash meter didn't freak out till I did the injectors. i guess it's an ECU thing?
  3. Nov 9, 2021 at 4:40 PM
    #783
    Saltyhero13
    Probably more pronounced with the bigger flow injectors, but I see it on my unwashed heathen Stage 1. The calculations are off. I'm guessing the way the ECU calculates MPGs it expects lower max flow rate.
    nobodyintexas[QUOTED] likes this.
  4. Nov 9, 2021 at 5:40 PM
    #784
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I can’t imagine how that would be. Very odd. You sure it wasn’t the emissions system doing its thing? I had noticed my wife’s 19 Rav4 makes noises 5 hours after parking it and I read it was emissions system equipment. I don’t doubt you though. The intercooler pump is surprisingly loud.
  5. Nov 10, 2021 at 3:30 AM
    #785
    nobodyintexas
    nobodyintexas What?
    South of Houston
    it was the pump - I barley cracked the reservoir cap open and it splashed.
    this morning - no problem. I may have double tapped the start button when I turned the truck off?
    or maybe it was just mad at me for ...well....nevermind.
    Vr0ck likes this.
  6. Nov 10, 2021 at 3:35 AM
    #786
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'm finally getting the chance to explore the gas pedal.
    the 1-2 shift now behaves well.
    I'll explain:
    whaaaaaaaaa.......chiiiirrppppp......whaaaaaa
    yes - the Caltrac traction bars work. I have NO wheel hop. <chef's kiss>
  7. Nov 10, 2021 at 3:42 AM
    #787
    nobodyintexas
    nobodyintexas What?
    South of Houston
    before I try this.....can 4HI handle this power?
    because I don't have the skill to do a hard 0-60 without breaking the damn tires loose.
    I've waited 50yrs to type that last line.
    Saltyhero13, Jbehredt and Vr0ck like this.
  8. Nov 10, 2021 at 4:08 AM
    #788
    nobodyintexas
    nobodyintexas What?
    South of Houston
  9. Nov 10, 2021 at 4:24 AM
    #789
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll expound on this - as I'm clearly doing nothing but posting crap this morning!
    I would do Stage 1 tune. it appeared to have everything i wanted - I never got to drive it.
    the tune fixes all the nanny crap that hinders the truck.
    and brings the TQ back onto the power band
    It's a perfect balance of safety & performance.
    Stage 2 adds a ridiculous amount of TQ to the equation. I didn't need it. I wanted it. now that I have it - I rarely- if ever - use it.
    (kinda like a Staccato XC, but I digress.)
    I don't know how TRX's (700hp!) stay on the road.
  10. Nov 10, 2021 at 4:54 AM
    #790
    snivilous
    SW UT
    300k+ Supercharged 2008
    4Hi has no issue. The front diff and tcase are phat.
  11. Nov 10, 2021 at 4:57 AM
    #791
    snivilous
    SW UT
    Stock tundra block presumably can handle 1000+. Usually the block isn't the issue, it's everything inside of it. I also take what I read with a grain of salt, just because stock internals did a 1000hp dyno pull doesn't mean it'll last at 1000hp, and drag racing which is where it seems most common to blow an engine is a lot harder and longer than a quick blip to max horsepower.
  12. Nov 10, 2021 at 4:58 AM
    #792
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    And I was going to add, just keep the steering wheel straight. It's pretty cool to feel the front suspension unload a bit.
  13. Nov 10, 2021 at 5:23 AM
    #793
    Silver17
    Eastern PA
    There is a series of videos on YouTube of a blue TRD supercharged tundra running 13.0-13.1 1/4 miles at 100+mph and he launches it every time in 4x4. He smoked all kinds of fast cars like supercharged mustangs, camaro, corvette and some tuned up diesels. He must have 50+ 4x4 launches racing the 1/4 mile. I’d say the drivetrain must be stout!
    nobodyintexas likes this.
  14. Nov 10, 2021 at 5:28 AM
    #794
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm not aware of Viktor having any supplemental modifications to the front portion of his drivetrain.
  15. Nov 10, 2021 at 7:42 AM
    #795
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Their hp claim is pretty high, but the torque is in the mid 500s, also they tend to dyno in low 500s in 2wd, which according to your latest dyno you are not that far off with almost 500whp, I've seen a crewcab 5.0 running high 12s, but I recall that thing wasn't just on the supercharge kit.
  16. Nov 10, 2021 at 4:54 PM
    #796
    boringdriver
    boringdriver New Member
    2015 LX 570
    Welp, a little hiccup today. Apparently ARH weld the incorrect flange size (too small, see pic) on the passenger side. Driver's side flange perfectly matches exhaust side flange. These are two piece headers though, the main headers + the lower piece where the high-flow cats are attached. Not sure what ARH will do at this point, but at least we won't have to uninstall the entire header, can just remove and swap the lower piece.
  17. Nov 10, 2021 at 5:42 PM
    #797
    Silver17
    Eastern PA
    That sucks. At least it’s in good hands there at Prospeed.
  18. Nov 10, 2021 at 6:11 PM
    #798
    boringdriver
    2015 LX 570
    you're right about that, they'll figure it out with ARH.
  19. Nov 11, 2021 at 3:46 AM
    #799
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed. the benefits of using a full hot-rod shop.
  20. Nov 11, 2021 at 9:12 AM
    #800
    nobodyintexas
    nobodyintexas What?
    South of Houston
    1st fillup half tank
    17.99. Mpg!
    mostly to work. So my avg stayed the same
    I had to adjust the scanguage after the fillup. It was off. Now we will if it tracks correctly
    got a 3 hour road trip today.
    I wonder why it did so good?
    Platinum714, Silver17 and Saltyhero13 like this.
  21. Nov 11, 2021 at 9:53 AM
    #801
    Silver17
    Eastern PA
    Nice I forgot about being able to recalibrate the scan gauge for your fuel usage. At least I can still use that then to track my fuel usage, mpg, range etc since the one on the truck will be deemed basically useless with the injector swap.
  22. Nov 11, 2021 at 9:59 AM
    #802
    Saltyhero13
    Looks like the blower leaches very little HP from the engine, coupled with the bypass its a great design.
  23. Nov 11, 2021 at 10:32 AM
    #803
    Downytide
    GTA
  24. Nov 11, 2021 at 4:10 PM
    #804
    nobodyintexas
    nobodyintexas What?
    South of Houston
  25. Nov 11, 2021 at 4:16 PM
    #805
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    @nobodyintexas Where’d you order your 650cc and pulley? I might as well start collecting parts so I can get mine tune lol
    Platinum714 likes this.
  26. Nov 11, 2021 at 4:25 PM
    #806
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I got from Harrop in their stage 2 pkg
    Use that part number and order from anywhere
    grippy pulley was because regular was sold out
    vq35721 likes this.
  27. Nov 11, 2021 at 4:27 PM
    #807
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed. Mind you it was all work miles. Hwy driving 90%
    Saltyhero13[QUOTED] likes this.
  28. Nov 11, 2021 at 4:44 PM
    #808
    Saltyhero13
    I'm about 60/40 Hwy/City split and usually hover around 14.5 MPG on the stock LTX tires hauling around 500lbs of gear. Lately I've been around 13.9 MPG with all the heavy stop and go traffic. We'll see what going Stage 2 and more importantly getting tuned does for me.
  29. Nov 11, 2021 at 7:30 PM
    #809
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Well guys, I got my email from Ryan @ Harrop on Tuesday and mine is due to land at his place this week or next, and said I should have it by the 19th! Said it’s already cleared customs and he doesn’t anticipate any delays…man I’m pumped!
    1UP, nobodyintexas, Silver17 and 4 others like this.
  30. Nov 11, 2021 at 7:34 PM
    #810
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    Will you be going that route? I want to go stage 2 too. Where will you be getting a tube from?
    vq35721[QUOTED] likes this.
