Looking for a Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by merv101, Nov 10, 2021.
  1. Nov 10, 2021 at 10:03 AM
    merv101
    merv101 [OP] New Member
    Grayson
    Hey all. I'm sure there's a thread on this already so maybe you can point me there. What should I be looking for in a 1st gen Tundra (things you like, things you don't like, things I should look for when buying one)?
    https://cars.ksl.com/listing/7522069
    The price on this one seems high, even in today's market, but it seems nice.
  2. Nov 10, 2021 at 10:30 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Damn that's expensive.
    You need to see the undercarriage. Frame rust?
    Damn that's a fucked up steering wheel for only 95k miles.
    Multiple blemishes on the interior.
    No floormats? Is that standard?
    Check the carfax. Service records? Timing belt/water pump/etc. done?
  3. Nov 10, 2021 at 10:34 AM
    merv101
    Grayson
    Super expensive. I wasn't sure if frame rust was an issue on these too. I have a Tacoma currently, and its good for now (California truck most of its life) but being in Utah now, I'm confident it'll get worse.
    Thanks for the insight!
  4. Nov 10, 2021 at 2:39 PM
    Look for any signs of rust under the truck, on the frame, period. Especially above and around the spare tire.
    Check the front suspension parts for worn/blown rubber stuff, leaks, tears.
    Make sure the timing belt has been changed within the last 8-10 years and/or 80-100k miles, else you're instantly putting yourself out $1,200-1,500 if you're paying someone else to do it.
    If 4WD, start the truck, tap the 4HI button while rolling in a straight line, make sure the light goes solid. Stop. Shift to Neutral. Press the 4LO button to engage 4LO. Make sure that engages before shifting into D and rolling in a straight line a couple feet. Disengage 4WD after. This could save you hundreds to thousands of dollars.
    Make sure it doesn't smoke on startup.
    If more than 150k, I'd hope the radiator has been replaced to avoid risk of pink milkshake (google it).
    Outside of that, smell the fluids.
    Oh - and that truck you linked is probably too expensive, although I'll admit, it's got almost every premium option my truck has, and it's 4WD. I could see paying up to 18 for it, out the door, if it's truly mint, no rust, never been in a rust state, fully serviced, with all the records.
    Seems y'all UT, north CA, and OR/WA folks pay a premium for whatever reason. The closer you get to Seattle, the worse and worse it gets.
    Lupe likes this.
  5. Nov 10, 2021 at 4:17 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama) and good luck with your search!
  6. Nov 10, 2021 at 5:12 PM
    SeanL
    SeanL New Member
    2002 Supercharged Beauty
    Welcome to the Shitpost bureau!
    Jesus seeing the prices of some of these trucks makes me want to put mine up for sale xD. 65000mile Supercharged 2002......... tempting.
  7. Nov 10, 2021 at 6:15 PM
    Retroboy1989
    Northern Utah
    That's crazy money. Someone would have to want that truck so bad to pay that much.
  8. Nov 10, 2021 at 7:00 PM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    Market is crazy and honestly you can most likely talk them down more
  9. Nov 10, 2021 at 8:13 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Feel like there needs to be a sticky thread of things to look for when buying a 1st gen.
    shifty`[QUOTED], w666 and bmf4069 like this.
  10. Nov 10, 2021 at 8:23 PM
    jamal4005
    jamal4005 New Member
    That truck has odometer rollback in the carfax
    w666 and shifty` like this.
  11. Nov 10, 2021 at 8:25 PM
    I was contemplating doing a write-up.
  12. Nov 10, 2021 at 9:36 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Dealers here in CA are selling beat trucks with 200k for 20k all day long.
    trueblue1981 likes this.
  13. Nov 11, 2021 at 7:16 PM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    I would say that is definitely priced too high. I have seen newer trucks priced close to that. If the mileage is actually correct and the underside is clean I would maybe make an offer but keep looking as well. The one thing with the 4.7 liters is they need to have the timing belt, water pump changed out at 100,000 miles per Toyota service recommendations. Also check the frame over very well, they have had frame issues in the 1st edition tundras. Check the fuel tank straps as well. You don't want them giving way when driving down the road. Good luck in your search.
  14. Nov 12, 2021 at 1:51 PM
    Retroboy1989
    Northern Utah
  15. Nov 12, 2021 at 2:51 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome
