PSA - Check Your Spare Tire for Rubbing Under Bed - UPDATE
Discussion in 'General Tundra Discussion' started by t-bear, Nov 10, 2021.
  1. Nov 10, 2021 at 12:19 PM
    t-bear
    t-bear [OP] New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    Well. This was a surprise at 17,7xx miles when I went to swap out the OEM spare from under the bed for a larger tire.
    Ooof. Glad I found that and not somewhere between OK and AZ in the middle of nowhere when I needed it... Don't know if it actually affected the sidewall integrity. Doesn't make me feel comfortable.
    AZBoatHauler and BecauseRacecar like this.
  2. Nov 10, 2021 at 12:23 PM
    AZBoatHauler
    So.Arizona
    I also flipped mine around so you can check the air pressure without having to drop it.
  3. Nov 10, 2021 at 12:24 PM
    t-bear
    NE Okla
    2019 Tundra CM SR5
    Forgot to add. I'm in the search of a scrap piece of linoleum to cut out to add as barrier between the frame and my new $300 spare.
    WVI likes this.
  4. Nov 10, 2021 at 1:02 PM
    2mchfun
    Maybe do a five tire rotation about every 6k or so.
    t-bear[QUOTED][OP] likes this.
  5. Nov 10, 2021 at 1:08 PM
    t-bear
    NE Okla
    2019 Tundra CM SR5
    Yeah I already bought a cheaper mud terrain vs. the Cooper ST Maxx I upgraded to. About $60 cheaper. Should have just bought another ST Maxx.
    I'm going to need to buy a fifth rim anyways as the OEM spare rim is going to cause rubbing if I need to use it up front. Not a big deal to swap a rear to front. Just concerned if I'm in a bad spot the safety issue of trying to do dual swaps.
  6. Nov 10, 2021 at 1:13 PM
    2mchfun
    In a bad situation, not sure, but maybe you could let it rub just long enough to get to a better spot. Might also be able to keep a few washers in the truck to use as spacers for a couple of slow and gentle miles. I'm going to be in the same boat 3 days from now, so kinda thinking about options.
  7. Nov 10, 2021 at 1:20 PM
    AZTundra
    Paul
    Phoenix, AZ
    I bought myself a 5th rim and matching tire, but had fitment issues under the bed (295/70/18). Going to see if I can remove the spare tire guides this weekend to make some additional room. Had rubbing on both sides on the shackles. I drove a few miles to try it, but I could immediately tell the shackles were binding up and not freely moving.
    TRDFerguson likes this.
  8. Nov 10, 2021 at 1:22 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    The spare is a whole process, inspection & maintenance, and i prefer to have nipples accessible. I cant talk no mess because i have AAA and my spare is original with stickers and an ‘01 date. It’ll get rotated, but my michelins are 30k fresh. And the OG spare holds air.
    i blame grandpa for not having the nipple accessible.
  9. Nov 10, 2021 at 1:37 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Totally agree, having nipples accessible makes me happy :bananadance:
  10. Nov 10, 2021 at 1:48 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    rejoice!
    2mchfun and AZBoatHauler like this.
  11. Nov 10, 2021 at 2:06 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I got a used tire as a spare instead of getting another Cooper STT and had to buy a new rim for my spare off ebay.
  12. Nov 10, 2021 at 2:09 PM
    biebs96
    PA
    Just a helpful hint for you guys.. if you decide to flip the spare over, there is some room inside the dish of the rim for some stuff.
    I keep a tow chain, cable ties and a few other items that can withstand the elements in there.
  13. Nov 10, 2021 at 2:15 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thinking outside the box there... Good idea.
    WVI and biebs96[QUOTED] like this.
  14. Nov 11, 2021 at 6:50 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Yep.
    Was just gonna say that's where I tend to stash emergency fluids and gear in vehicles with trunk spare.
    Flipping the tundie spare is now on my list.
    My bimmer had an option available for a metal gass can designed to fit inside the spare wheel... Of course it would never get used and the gas would probably go bad, but I always liked that it existed.
    biebs96[QUOTED] likes this.
  15. Nov 11, 2021 at 10:47 AM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    Just bend out the brackets. My 35x12.5x18 fits perfect without rubbing at all
  16. Nov 30, 2021 at 8:28 AM
    t-bear
    NE Okla
    2019 Tundra CM SR5
  17. Nov 30, 2021 at 8:43 AM
    biebs96
    PA
  18. Nov 30, 2021 at 9:41 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Even better idea, pool noodle at dollar store, real simple.
  19. Nov 30, 2021 at 9:51 AM
    2mchfun
    I wonder about deflating the tire, then raise it up, followed by inflating to create a super tight no rub fit. Maybe, maybe not. Thoughts??
  20. Nov 30, 2021 at 9:55 AM
    t-bear
    NE Okla
    2019 Tundra CM SR5
    Not bad ideas ^. Cheaper than the $30 something I spent.
    2mchfun likes this.
  21. Nov 30, 2021 at 12:08 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I did the same many months ago, just be forewarned that if the debris makes its way between the face of the wheel and those utility mats....it will abrade at the wheel finish. Ask me how I know.... ;(
    -JS
    2mchfun likes this.
  22. Nov 30, 2021 at 12:14 PM
    t-bear
    NE Okla
    2019 Tundra CM SR5
    Ooof! Glad you mentioned that. I'll take another look, but I believe the rubber mat doesn't contact the wheel at all. Perhaps a layer of tape though along the wheel's rim...
    2mchfun likes this.
  23. Nov 30, 2021 at 12:31 PM
    2mchfun
    Maybe flip it?
  24. Nov 30, 2021 at 12:33 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    the tire hoist is designed to sit on the hub bore and flat wheel hub mating surface. flipping the spare is not possible with alloy wheels.
    -JS
  25. Nov 30, 2021 at 12:34 PM
    angkorstrong
    angkorstrong New Member
    2020 Sequoia TRD Pro
    thanks for the psa gota add this to the maintenance checklist
  26. Nov 30, 2021 at 12:34 PM
    t-bear
    NE Okla
    2019 Tundra CM SR5
    When I first tried to secure it with the chain bracket, I couldn't get the two bracket "prongs" to seat properly in the outer lug nut sockets (Method 701 wheel). I had to mount it with the inner wheel facing down.
    I'll try again though when I check it. It might have been an issue of too many beers!
  27. Nov 30, 2021 at 12:35 PM
    t-bear
    NE Okla
    2019 Tundra CM SR5
    A ha. Thanks. I was typing while you posted. That confirms what I posted above. Appreciate it.
  28. Nov 30, 2021 at 12:59 PM
    2mchfun
    I still think it can be flipped, kinda depends on the wheel and if a centercap will cover scarring. In my case, I have a steel spare and it can be flipped. Someday, I will flip it and use the well for some hidden tool storage.
  29. Nov 30, 2021 at 1:09 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    and for @t-bear, saved you the effort. lol
  30. Nov 30, 2021 at 1:16 PM
    t-bear
    NE Okla
    2019 Tundra CM SR5
    Thanks @BiggHertz I thought that was my issue and you did save me some time. I still think I will pull the spare and probably tape the upper (outer wheel rim) rim b/t mats.
