Weird truck dies situation
Discussion in '1st Gen Tundras (2000-2006)' started by Schneider591, Nov 9, 2021.
  1. Nov 9, 2021 at 1:04 PM
    Schneider591
    Schneider591 [OP] New Member
    Picked up an 02 2wd 5speed with the 3.4 from copart hit in the passenger front. Replaced parts and drives great however when I run it through the car wash and those giant blowers start blowing motor shuts off and battery light comes on. Turn the key and truck starts right up. Strange? Any ideas. I also recreated the wind situation with coasting down a big hill in neutral did the same thing. Filter box was smashed so just put a k&n on as well as cleaned maf and throttle body
  2. Nov 9, 2021 at 1:06 PM
    18" TRD Off Road Wheels
    Is the 3.4 the V6?
    Tundra2 likes this.
  3. Nov 9, 2021 at 1:13 PM
    I'm guessing you probably have a short. Pop the hood. Start the truck. Firmly grab the fuse/relay box in the engine bay, near the battery and shake/slap it.
    If nothing happens, grab the battery cables and jiggle those really good, especially the skinny one from the + BATT terminal to that fuse/relay box.
    If still nothing, check the grounds in the engine bay area.
    If still nothing, get a leaf blower, then blow in specifically targeted areas of the engine bay until you see a repeat, then you'll maybe know where to focus.
  4. Nov 9, 2021 at 1:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Intake was sqaurshed? Did you make sure no bits and pieces got inside the engine?
    Any grounds not connected?
    Punk1974, Jack McCarthy and GODZILLA like this.
  5. Nov 9, 2021 at 1:22 PM
    You felt the disturbance in the Force when somebody mentioned a V6. :rofl: I didn't even have to tag you! :fistbump:
  6. Nov 9, 2021 at 1:34 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    How long ago? How much driving have you done since?
    Whenever I disconnect the battery and fiddle with the maf on my truck, it tends to have a hard time coming back to idle. It will die at stop signs or even if I give it a rev and let it drop to idle. Only way out of that is to drive it. I have a 4.7 and not sure if the v6 is drive by wire or by cable, if by wire thats a possible issue.
    Otherwise, a short is possible. Maybe wind is blowing the right wire around. Maybe something delicate got messed up in the accident.
    Jack McCarthy and Tundra2 like this.
  7. Nov 9, 2021 at 1:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    bmf4069 and GODZILLA[QUOTED] like this.
