Victory 4x4 Rear Diff cover
Discussion in 'General Tundra Discussion' started by forensictrooper530, Oct 6, 2021.
  1. Oct 6, 2021 at 5:28 PM
    forensictrooper530
    forensictrooper530 [OP] New Member
    2020 Toyota Tundra TRD 4x4
    Shift knob, skid plate transmission skid, retractable Gator bed cover
    Anyone have problems with Victory 4x4 parts not fitting their Tundra correctly? I’ve had problems with the control arm skids hitting and grinding my front rims, engine skid hitting the front diff and the rear diff skid plate bottoming out on the diff housing. The axle brackets don’t even come close to touching the axle housing. All supposed to fit 2007 to 2021. Excellent quality, just the fit is bad and not checked from year to year I guess.
  2. Oct 6, 2021 at 5:37 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome
    Kgfit85 likes this.
  3. Oct 6, 2021 at 5:37 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Lot of bad experiences from people buying/using their parts on here to the point they were removed from being an official vendor. I dont have any experience personally just giving you some insight. Search victory 4x4 and threads should come up for you. Good luck!
  4. Oct 6, 2021 at 5:41 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I have experience with the bracket coming off and getting mangled by the driveshaft. If you do get it on, check it, check it, and then check it again after every time you drive it.
    831Tun, sr5shark and joonbug like this.
  5. Oct 6, 2021 at 5:43 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It’s not from year to year. That’s how they fit on every year. Most of my buddies with the diff skid have removed them. I ruined a pair of wheels with their LCA skids too. They’re a garbage company with garbage products. Hopefully you don’t have their roof rack.
    831Tun, Uhhhh...., sr5shark and 2 others like this.
  6. Oct 6, 2021 at 5:46 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Are we still saying airbags aren’t a viable mounting point?
  7. Oct 6, 2021 at 8:57 PM
    forensictrooper530
    Thanks everyone. I figured I was not the only one. Anyone have anything good to report about RCI’s rear diff cover? Seems like it might be better.
  8. Oct 6, 2021 at 9:14 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I have the RCI, the ground clearance is better with Victory. RCI has longer wings on the sides. I tried to install the front piece at the front of the skid but it was already hitting the driveshaft bolts so I’ve been running it without it the whole time. As far as the brackets, I think that’s how it was designed, my RCI is the same way.
    joonbug likes this.
  9. Oct 6, 2021 at 9:20 PM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    RCI is the shit! As in… DOPE AF! Customer service 5 stars and quality 5 stars!
    I have had their armor and diff skid on an FJ and Taco.
    Kgfit85 and Luckydog like this.
  10. Oct 7, 2021 at 2:37 AM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    I have the victory diff skid and have not had any issues with it yet.
  11. Oct 7, 2021 at 6:26 AM
    forensictrooper530
    Not sure why the victory rear diff skid fits some and not others. Must be the tow package with the 4:30s. Toyota actually shows 3 different part numbers for the rear diff housing in 2020.
  12. Nov 8, 2021 at 7:11 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    How do control arm skids hit the wheels? Just installed some and would rather not ruin my new methods.
  13. Nov 8, 2021 at 7:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    On their very first version, at full lock the corner of the skids touched the wheels on certain offsets. They cut the corner off after that but many people got their wheels damaged.
    GodlessPro and 831Tun like this.
  14. Nov 8, 2021 at 7:56 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Victory QA dept on testing:
  15. Nov 8, 2021 at 8:15 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Joon.
    How am I gonna unload my victory diff skid now???? LOL
  16. Nov 8, 2021 at 8:21 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    When I find someone to buy my icon arms, I’ll let him know you have a diff skid for sale. :rofl:
  17. Nov 8, 2021 at 8:49 PM
    forensictrooper530
    Yup I have the lower control arm skids and diff cover for sale. Engine skid fits better with the spacers and transmission transfer case skid fits perfect. Wish the others would have worked out. My local dealer did some research and discovered Toyota has 3 different part numbers for a rear differential housing on a 2020 Tundra. Must be different suppliers for the housing and slight variations in the housings. Rear diff skid just needs a little bit more room to work.
    831Tun likes this.
