Ironman sliders aren't bolt on for 21 models
Discussion in '2.5 Gen Tundras (2014-2021)' started by wexttxco, Nov 8, 2021.
  1. Nov 8, 2021 at 5:07 AM
    wexttxco
    wexttxco [OP] New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    The geniuses at ironman 4x4 thought it was good business practice to sell a product (rock sliders) with no instructions (as in, figure it out yourself but we promise we'll a YouTube video on it one day), and sell something that needs cutting and grinding and drilling as something that doesn't need cutting or grinding or drilling and is "bolt on" . It is far from it. Be warned. Might as well buy a pair that also requires drilling your frame but isn't dishonest about it. Not Ironman.
    And customer service won't do anything about it. I wish I had never given them my money, I would recommend that you don't. They'll email you a few times "tech is looking at it, cheers" and that is all they will do for you so buyer beware. Spent 1600 with them and they give zero f*cks about trying to make it right.
    Disregard on frame rivets!
    Ironman made it right after some nasty reviews and a few weeks.
  2. Nov 8, 2021 at 5:10 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I wouldn't touch those. They are rivets holding your frame together.
    Return the sliders there are a dozen other options that are much easier to work with.
  3. Nov 8, 2021 at 5:13 AM
    wexttxco
    21 SR5 DC 4x4
    It would cost 200 bucks or more to ship these back unfortunately
  4. Nov 8, 2021 at 5:15 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    A new frame is $3k+
    Just my .23cents
    Black Wolf, Mike59, Darkness and 4 others like this.
  5. Nov 8, 2021 at 5:26 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Don't cut into those. They should be 100% bolt-on. Unless they sent you the wrong ones. Do you have a picture of the sliders? There are no holes to accommodate those?
  6. Nov 8, 2021 at 5:26 AM
    wexttxco
    21 SR5 DC 4x4
  7. Nov 8, 2021 at 5:27 AM
    wexttxco
    21 SR5 DC 4x4
    That's how they seemed to bolt up but I'll flip it around and try the other one.
    Blue Thunder and Saltyhero13 like this.
  8. Nov 8, 2021 at 5:27 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Looks like they should bolt right on, have you tried it on both sides? And they still don't line-up?
    Darkness and wexttxco[OP] like this.
  9. Nov 8, 2021 at 5:31 AM
    18" TRD Off Road Wheels
    Those rivets go in the circled holes. You're bolts will go where the arrows are.
  10. Nov 8, 2021 at 5:36 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Different brand, but just as @AzureNightmare said above. See the rivets sit in those large holes.
  11. Nov 8, 2021 at 5:42 AM
    wexttxco
    21 SR5 DC 4x4
    Thanks for the info fellas, one moment and I'll swap them around and see what it looks like
  12. Nov 8, 2021 at 7:37 AM
    wexttxco
    21 SR5 DC 4x4
    Got them held in place.
    Turns out you have to drill into the frame at 6 spots. In spite of what the description says. Assholes. Screenshot_20211108-092650_Firefox~2.jpg
    diablodalton and Darkness like this.
  13. Nov 8, 2021 at 7:38 AM
    wexttxco
    21 SR5 DC 4x4
    And one of the ones that would have lined up, without drilling, does not.
    Don't buy sliders from ironman. They don't answer the phone, either.
  14. Nov 8, 2021 at 7:40 AM
    I think, and I may be wrong, that where the frame holes are has changed mildly on the 2020+ trucks. My brain is sleep deprived goo, so I might be remembering incorrectly, but I could swear somebody had similar issues with another manufacturer's sliders because they had built them off the older trucks and the holes were slightly different.
    Darkness and Saltyhero13 like this.
  15. Nov 8, 2021 at 7:46 AM
    MadMaxCanon
    My cali raised sliders fit on my 21 with no issues. When i ordered from cali, their website did not specify year of truck, only the gen.
  16. Nov 8, 2021 at 7:46 AM
    wexttxco
    21 SR5 DC 4x4
  17. Nov 8, 2021 at 7:47 AM
    Well, I may well be confused then. Certainly wouldn't surprise me. :rofl:
    MadMaxCanon[QUOTED] likes this.
  18. Nov 8, 2021 at 7:47 AM
    wexttxco
    21 SR5 DC 4x4
    Not only do you have to drill, the contour isn't even right so I have to grind the sliders if I even want to drill.
    Darkness likes this.
  19. Nov 8, 2021 at 7:47 AM
    It could also be that you do not have to use all the holes in the slider. I know some have optional drillable holes for super heavy duty use, but they are not required.
  20. Nov 8, 2021 at 7:49 AM
    wexttxco
    21 SR5 DC 4x4
    Screenshot_20211108-094635_Firefox.jpg only states 2014+ here. They screwed this up. 2 days before my trip with no time to fuck around with it because they were "bolt on"
  21. Nov 8, 2021 at 7:49 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Agreed, with above. Not ever hole needs a bolt. Count how many bolts came with the sliders, and see if the amount of bolts you have matches up with the amount of holes that can accept a nut and bolt on both sides.
    Tundra18overland and Saltyhero13 like this.
  22. Nov 8, 2021 at 7:50 AM
    wexttxco
    21 SR5 DC 4x4
    There are no holes on the bottom, so any upwards pressure on the sliders would try to peel away from the frame and shear the bolts unfortunately. No holes on the bottom work.
  23. Nov 8, 2021 at 7:51 AM
    wexttxco
    21 SR5 DC 4x4
    Most holes and bolts match up. Bolting to the frame from the sides sides zero holes on the bottom in the frame (4 were supposed to bolt to the bottom of the frame).
    AZTundra likes this.
  24. Nov 8, 2021 at 7:51 AM
    MadMaxCanon
    stupid question but did you see an install video on these on the site? They usually have good install vids on suspension at least.
  25. Nov 8, 2021 at 7:52 AM
    wexttxco
    21 SR5 DC 4x4
    No install video, no instructions. They told me to figure it out for myself and in the future they would release a YouTube video for it.
  26. Nov 8, 2021 at 7:59 AM
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Can you take some more photos of them on the truck?
    I do agree that my 2021 only has 1 hole (passenger side) toward the rear - in the bottom of the frame.
    However, any sliders (other brands) all are 2014+
  27. Nov 8, 2021 at 8:00 AM
    The low price, lack of pics, and no instructions makes me suspect if these would hold up as a slider in the first place. You cannot tell how they attach or how many supports they have on the website. Also, you cannot see how the supports attach to the plate you are mounting to your frame in any pictures. I'm not sure I would trust these to protect from anything.
    wexttxco[OP] likes this.
  28. Nov 8, 2021 at 8:02 AM
    Seems like it may be a bit of sleazy marketing. They "bolt on" just fine, but won't actually function as a slider without drilling.
  29. Nov 8, 2021 at 8:05 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I would return it. You have them on the hook based on website description. If not and hopefully you used your credit card, go through your credit card.
  30. Nov 8, 2021 at 8:06 AM
    MadMaxCanon
    im wondering if they accidentally sent you the sliders for a CM instead of a DC
    Saltyhero13 likes this.
