Apple CarPlay not wanting to work!!
Discussion in 'Audio & Video' started by TeamGoose, Nov 4, 2021.
  1. Nov 4, 2021 at 2:16 PM
    TeamGoose
    TeamGoose [OP] Threat Level Midnight, Michael Scarn
    Temple, TX
    2020 Tundra TSS 4x4 Cement
    OEM LED Headlights, TRD Shifter, Interior LEDs, 6112(1.9) & 5160 reg. height
    I have a 2020 Tundra and Apple CarPlay use to work just fine, but here as of recent it doesn't want to work.
    It will connect to my phone for a min or so and then disconnect and won't connect back nor will it charge. the other ports will allow me to charge my phone so I know it's not the cable. do I need to replace the USB port and if so, where do I find one?
    Anyone else having this issue?!?!?
  2. Nov 4, 2021 at 2:53 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    This is not necessarily true. The cable may not have the data pins enabled/connected. So your cable may allow power but not data. I recommend trying a different cable, I found the head unit to be particularly finicky with cables to the point I went with a wireless Carlink unit.
  3. Nov 4, 2021 at 3:10 PM
    TeamGoose
    Temple, TX
    Thanks, will give it s shot. I have an hour and forty-five minute drive to my hotel to see if I can get it to work.
  4. Nov 4, 2021 at 3:27 PM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    Whenever I have issues it is ussually due to the cable having gone bad.
  5. Nov 4, 2021 at 4:23 PM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    My 2020 did that same thing last week, had my maps up and it just disconnected and would not reconnect for anything, got to where I was going and cut truck off and restarted and it’s been fine since. Figured it was a glitch
  6. Nov 6, 2021 at 5:43 PM
    TeamGoose
    Temple, TX
    Sorry just getting back to this, changed out the cable and it was been acting right the past three days so. simple fix. thanks for all the input!!!
    KK6PD and Saltyhero13 like this.
  7. Nov 8, 2021 at 4:55 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Trying shutting your headunit off to do a restart and see if that helps.
