Strange vibration
Discussion in '2nd Gen Tundras (2007-2013)' started by sameguy, Nov 7, 2021.
  1. Nov 7, 2021 at 2:42 PM
    sameguy
    sameguy [OP] New Member
    Pete
    2012 SR5 4x4 DC
    BDS 7" lift on 35's, regear, lockers, ARB Twin, Rock Slide Aluminum front bumper, Smitty H20 10k, Second battery, Snugtop, Yakima Megawarrior rack
    So stupidly I did 2 things at once, or almost at once. I got new tires, 37" Falkan wild peak AT trail. The guys putting on the tires said I had a pinion seal leak in my rear dif, just a few drops but I wanted to take care of it straight away. Literally drove across town (never got over 35mph) to another shop who was doing doing my brakes and added replacing the pinion seal to their work. Couple days later they finished but mentioned a strange vibration at around 45mph. Sure enough there now seems to be a growly vibration at around 45-60 mph, then dies down above that. It's not a terrible vibration but it is there for sure. Second shop thought it was the new tires but the tire shop (who is excellent) never mentioned any vibration and I know they drove it a good deal as they did an alignment, drove, it tweaked their settings drove it again a few times etc.
    SO.... I am wondering if the guys who replaced pinion seal maybe didn't get the drive shaft back on in phase or flipped on the yoke causing the vibration. I have never had this kind of vibration before so not sure if tires could cause this or what.
  2. Nov 7, 2021 at 5:53 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Probably time to get the rear axle in the air and traction control turned off, then run those wheels up and see what's vibrating. What you're describing is exactly what I experienced when I had a bad wheel bearing, but having this mysteriously appear after getting some work done is definitely suspicious.
  3. Nov 7, 2021 at 6:52 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Try unboting the wheels and reseating them and manually torquing them to spec. Just to eliminate the chance of a wonky seat on the hub centric.
    Ely010606 likes this.
  4. Nov 7, 2021 at 8:54 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    ^^^X2
