How much squat?
Discussion in 'Towing & Hauling' started by Tn_ags, Nov 6, 2021.
  1. Nov 6, 2021 at 12:04 PM
    Tn_ags
    Tn_ags [OP] New Member
    2019 2wd TSS
    Question for the experts... how much rear end “squat” is too much? 2019 SR5 TSS 2wd pulling a 25’ Airstream FC RB. About 6000 # trailer weight with +/- 820# tongue weight. Blue Ox WD hitch. Seems to squat about 4 - 5 inches, but feels OK towing. Do I need a RAS to reduce the squat?
  2. Nov 6, 2021 at 12:20 PM
    18" TRD Off Road Wheels
    I think a lot of that should be addressable by readjusting your WDH.
    Mattedfred and 2018TundraLimited like this.
  3. Nov 6, 2021 at 12:35 PM
    THORYOTA
    THORYOTA God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    In college, 525 for 1.
    These days 405 for a couple and 450 for 1.
  4. Nov 6, 2021 at 1:35 PM
    Tn_ags
    2019 2wd TSS
    The WDH was professionally installed for the specific trailer, so I assume it was done correctly.
  5. Nov 6, 2021 at 2:36 PM
    Define "professionally installed" because the place that sold it/the trailer may not know how to do it properly. I've spent the last hour trying to find the pics one of the mods put up of his tundra towing a couple trailers, and I don't think it had 4 inches of squat. I could be wrong, but I can't find the pics anyway.
    @ColoradoTJ didn't you have a couple pics of your tundra with your various trailers? I give up.
  6. Nov 6, 2021 at 2:45 PM
    The pictures are in my albums.
    https://www.tundras.com/members/coloradotj.2766/
    Nevermind those pics of the craptastic GM’s and Jeep’s.
    Black Wolf and GODZILLA[QUOTED] like this.
  7. Nov 6, 2021 at 2:51 PM
    Ah! Thank you! (Sorry I tag you in all the towing questions.) :oops:
    @Tn_ags here is the pic I was after. There is still some squat, but it's less important than the rise up front. You should measure your hub to your front wheel well without the trailer, and then with it. If you are seeing a big rise, then your WDH is likely in need of tuning.
  8. Nov 6, 2021 at 3:09 PM
    All good Adam. This is a community and we all pitch in.
    In this picture, I had Hellwig springs on and adjusted to the lightest setting. It sucked. I ended up adjusting my LDH up a little more so the back end of my truck was 1/2” less squat.
    The camper was empty and was taking it up to the mountain property for winter storage. Had it been loaded, the truck would have been on the bump stops. In this configuration. :rofl:
  9. Nov 6, 2021 at 3:57 PM
    2mchfun
    Your hitch could use adjusting and I would also suggest a RAS HD kit, nothing but good stuff. Never hear one complaint about them. Kinda nice to keep your headlights in focus.
    FlightMedicRN and ColoradoTJ like this.
  10. Nov 6, 2021 at 4:37 PM
    As @AzureNightmare said, I would look at your WDH adjustments. Do you have the paperwork for the WDH? The instructions for mine state that if adjusted properly, I should have no more than a 1 inch drop. Pics for us to look at may help as well. Are the torsion bars parallel to the ground?
  11. Nov 6, 2021 at 4:45 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    Believe or not, 25ft airstream have a heavy tongue weight. You need to load the trailer, and measure your tongue weight with a scale. My neighbor has a 25ft airstream and he complains about his weight. He has a newer f150 ford. He put helper springs on. I have a 24ft Jayco and tongue dry weight is 550 lbs. Load tongue weight is 750lb. I put on firestone air bag.
  12. Nov 7, 2021 at 3:53 AM
    Retired...finally
    It would be interesting to hear what the CAT scales tell you. The readings of the steer and drive axles can help you fine tune the WDH and load. What is the payload of your truck?
  13. Nov 7, 2021 at 12:54 PM
    Tn_ags
    2019 2wd TSS
    Payload is myself and my wife, some aluminum folding chairs (>10#), a 50A power cable and a 40 qt. Yeti. All in all, less than 500#. Trailer is not full of stuff and I keep the tanks at about 15% full, so not a lot of extra weight. AS dealer installed the WDH & the guy said he has 20+ years doing these setups. Marked the links so we could consistently latch at the same place. I don’t have a straight-on side shot, but this pic seems to show it sitting pretty level. AF0D09A2-05A2-4B0D-998D-CE015463E5F2.jpg
    Mattedfred and slowpokepete like this.
  14. Nov 7, 2021 at 2:06 PM
    Retired...finally
    Did you verify how much weight.your truck can carry by going to your Owner's Manual with the model code that's posted on the sticker inside the driver's door? From that number you must subtract the weight on the yellow sticker from the port installed options. My 2021 SR5 4x4 Crewmax with the 38 gallon tank filled only leaves me with 1217 pounds for pax, tongue weight, WDH and gear. You're 2 WD so that's in your favor.
  15. Nov 7, 2021 at 4:02 PM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    That's nice...what model/length is your Airstream?
    SPP
  16. Nov 8, 2021 at 4:15 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Nice trailer!
    The tongue weight on my trailer is about 750 lbs and I get (rough guess here) around 3-4" of squat. My front doesn't move though. My RV dealer did nothing more than throw the hitch on and claim it was set up properly. I haven't made it to the scales yet, so I set up mine using a tape measure and a level parking pad. I had to adjust it quite a bit from where the dealer had it.
  17. Nov 8, 2021 at 4:20 PM
    Tn_ags
    2019 2wd TSS
    Thanks. Your WDH definitely wasn’t set up properly if the front end did not move with the rear. Mine does move down as well, keeping the truck fairly level, it just seems to move more than I think it should. I will be doing some detailed measuring next time I hook it up.
