Can we discuss tires yet?
Discussion in '3rd Gen Tundras (2022+)' started by Totherion, Nov 6, 2021.
  1. Nov 6, 2021 at 10:42 AM
    Totherion
    Totherion [OP] New Member
    Not even out yet and I am fretting about tires.
    The Tundra I'm after (SR-5 TRD Sport) has been seen with Bridgestone or Yokohama.
    I once had Duellers and they were soft garbage that wore out in less than 20,000 miles.
    Anyone know yet what the production Tundras will have?
    I'll need a top quality all season that is very decent in snow.
  2. Nov 6, 2021 at 11:08 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    One vid had Falken Wild peaks for the offroad, not sure what the road tire will be.
    Totherion[OP] likes this.
  3. Nov 6, 2021 at 11:11 AM
    18" TRD Off Road Wheels
    OEM tires are usually sub par regardless of what brand. You'll get a goodyear duratrac or something, but if you take the stock ones and compare them to the same tire at a tire shop you'll see that OEM tires are usually a substandard tire.
    Watch the first part of this video. It's about motorcycles, but the same stuff is done in the auto world.
    https://youtu.be/Tv97i_-V7hA
  4. Nov 6, 2021 at 11:47 AM
    Totherion
    Great video, thanks.
    I hear you on the Duratracs. My Trail Boss came with them. I was dismayed to find the OEM versions are NOT snow rated. I would have happily paid Chevrolet a few more bucks for the real deal.
    GODZILLA[QUOTED] likes this.
  5. Nov 6, 2021 at 12:00 PM
    It's just the nature of marketing. It's the art of legally lying as much as possible.
  6. Nov 6, 2021 at 12:47 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    Video was informative, well-explained and entertaining.
    Thanks for posting that.
  7. Nov 6, 2021 at 1:04 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  8. Nov 6, 2021 at 1:35 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    This is absolutely true. I operated a tire and auto store before working at a Toyota dealership. Check the tire wear index on a OE tire then compare it to the exact same tire that is sold to the public. Substantially less. This doesn't apply in every case. A vehicle manufacturer will ask a tire manufacture for a tire quote on tires at a certain price point and says they need 200K of them and they must meet a certain performance level. The tire manufacture will build the tire but some aspects of performance will suffer such as longevity.
    Black Wolf and GODZILLA[QUOTED] like this.
  9. Nov 6, 2021 at 1:37 PM
    Dav123
    Dav123 New Member
    The oem wildpeaks are gonna be P rated, which is basically a car tire. So once you put on a set of D or E rated tires,The oems probably weigh around 35 - 45 lbs. While the truck version will weigh
    55 - 70 lbs.
    Saltyhero13 likes this.
  10. Nov 6, 2021 at 1:48 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    A P rated tire can be perfectly fine for the street and that how most will actually be using the truck. Off road or heavy towing the LT is a better choice.
  11. Nov 6, 2021 at 1:50 PM
    Totherion
  12. Nov 6, 2021 at 2:01 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    The pinnacle of street all season tires….
    And I have found them to handily out perform many of the most popular AT tires on the market while driving in the rain, snow (8’ or less), and ice.
    The Defender LTX is better than the AT2 as far as daily on road driving. They do surprisingly well on dirt paths and minor off-roading (NOT IN MUD).
    frichco228 likes this.
  13. Nov 6, 2021 at 3:08 PM
    osu1978
    osu1978 New Member
    I agree. They are great in all conditions and the tread life is awesome too.
    Oey12[QUOTED] likes this.
  14. Nov 6, 2021 at 3:17 PM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Had them before my Wildpeaks. If you don't go off-road, no better choice
  15. Nov 6, 2021 at 3:20 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I wouldn't put to much weight on the fact that your Duratracs don't have the snow rating. It's really not that high of a bar to clear and it's more of a marketing gimmick. Your Duratracs will do just as well in the snow as any other Duratrac tire. As already mentioned it's for legal reasons.
  16. Nov 6, 2021 at 4:29 PM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    Why am I not surprised that this is something that all manufacturers do to pass on the cost onto the consumer. Want premium dollars for a subpar product. They act like they are giving you a top of the line vehicle, yet put crap tires on it. Buy used and let someone else take the hit.
  17. Nov 6, 2021 at 4:44 PM
    Dav123
    Dav123 New Member
    True, and the p tires will ride smoother and get better mpg, but they are more prone to flats if you use your truck for anything other than the street. If you drive a lot of gravel or dirt roads, it’s probably best to run an LT tire. Lt itirrs usually last longer too.
  18. Nov 6, 2021 at 8:48 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    Or better a c rated or higher. Man do i hate flat tires.
  19. Nov 6, 2021 at 8:59 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I believed everything you said other than that LT tires will last longer. If you're talking tread wear life tread compounds and tread pattern are the main main components that determine wear rate.
    It your saying the the LT tire would last longer because you will destroy your P tires off road then I agree. :thumbsup:
  20. Nov 7, 2021 at 4:40 AM
    Tundra4Runner
    Tundra4Runner New Member
    2015 4Runner TRD PRO
    I've gotten very solid use out of Falken Wildpeaks and Nitto TerraGrapplers on my 4Runners. I rotate every 5000 miles and I get 80,000 miles out of them and I live in MN with ice/snow half the year.
  21. Nov 7, 2021 at 6:48 AM
    Toyota1234
    Jack
    So more like 40’000 miles then
  22. Nov 7, 2021 at 12:19 PM
    Totherion
    Thanks to all for the great replies.
    If my SR5 comes with Duellers I'll be heading to Costco afterwards to get the Defender LTX
    Oey12 likes this.
  23. Nov 7, 2021 at 12:59 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    "Can we discuss tires yet?"...NO
    Next question?
