2021 misaligned rear axle???
Discussion in '2.5 Gen Tundras (2014-2021)' started by Railroad 07, Nov 5, 2021.
  1. Nov 5, 2021 at 12:23 PM
    Railroad 07
    Railroad 07 [OP] New Member
    Georgia
    White 2021 trd pro
    2021 trd pro
    Truck has 1500 miles
    Noticed the tires stick out further on the passengers side. Is this normal, its pretty noticeable in person just looking from one side to the other. Tried to get a good reference picture. Any have this issue? 20211105_151517.jpg 20211105_151434.jpg 20211105_151757.jpg 20211105_151700.jpg
  2. Nov 5, 2021 at 12:28 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes that’s normal.
  3. Nov 5, 2021 at 12:29 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    Mines the same . Same color and trim
    Railroad 07[OP] likes this.
  4. Nov 5, 2021 at 12:39 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Curious to what causes this? I've never noticed it on mine. Now i'm going to have to look...
    IsaiahCanada and Railroad 07[OP] like this.
  5. Nov 5, 2021 at 12:40 PM
    DrZoidberg
    Dave
    Tesla MYP
    Don’t. Cause now I can’t unsee it
    2mchfun, Railroad 07[OP] and GODZILLA like this.
  6. Nov 5, 2021 at 12:41 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
  7. Nov 5, 2021 at 12:43 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Probably just tolerance stack up and that's the most extreme area. Body relative to mounts relative to chassis relative to leafs relative to axle. The front is probably less noticeable since there's probably less allowable tolerance, where as the rear axle position doesn't matter much as long as the thrust angle (perpendicularity to motion direction) is low. If it's left or right it doesn't affect the truck, so why make manufacturing and assembly harder. All guesses though.
    Railroad 07[OP] and Jaypown like this.
  8. Nov 5, 2021 at 12:43 PM
    timsp8
    NY
    I didn’t notice mine until I got slightly wider wheels with less offset. But I have it too.
  9. Nov 5, 2021 at 12:47 PM
    18" TRD Off Road Wheels
    Normal. The trucks aren't square. If you go measuring the body panel alignments you'll start twitching if you are OCD. I read somewhere on the forum that it had to do with counteracting axle wrap or some such, but IDK if that's true. Never really cared, and I don't check the measurements on the body panels because my damn OCD makes my eye twitch enough without me agitating it unnecessarily! o_O
  10. Nov 5, 2021 at 12:56 PM
    Railroad 07
    Georgia
    White 2021 trd pro
    Well shit! I was hoping for a common problem with a fix. I wish I never noticed this
  11. Nov 5, 2021 at 1:00 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Don’t worry. You’ll forget all about it in 2 to 3 years. :D
  12. Nov 5, 2021 at 1:17 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    My Tacoma had this, though way worse than I've seen on any Tundra. The bed/box was misaligned on my Tacoma. Very common on Tacomas.
  13. Nov 5, 2021 at 1:45 PM
    timsp8
    NY
    Once I knew about it I noticed it for awhile and then forgot all about it too. Now I remember again.
  14. Nov 5, 2021 at 1:50 PM
    Yup. I noticed it, and then I looked where the cab and the bed meet, and it's off center, and then I looked at my rear bumper's black top plates and they aren't matched side to side, and and and....
  15. Nov 5, 2021 at 6:16 PM
    Redpill
    Redpill New Member
    2015 Tundra DC Limited 4x4
    Leveling kit, airbags on rear axle, led light bar with cattle pusher.
    For the love of everything right in the world, please put "trigger warning" at the start of a thread like this! :facepalm:
  16. Nov 5, 2021 at 6:56 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Wonder if you could get it jacked up on the frame drooping the rear tires, loosen the U-bolts, give everything a little shimmy then torque everything back down and see if it changes? Just thinking out loud, not sure if something could have been bound up a little when tightened causing a shift. Do the leafs look aligned on the axle perches, then from there following everything up (shackles etc.)? I looked closely when I put my wheel spacers on at the tire poke and I never noticed any big difference from one side to the other. Like others said it might be normal, but maybe some do have a fixable cause.
  17. Nov 5, 2021 at 7:20 PM
    2mchfun
    Fwiw, everything about it flexes and shifts while driving, so being anal about it is silly.
  18. Nov 5, 2021 at 10:10 PM
    rugerm44
    rugerm44 New Member
    2021 Tundra
    The only perfect symmetrical car I own.lol and yes the tires stick out the same all around.
    HighDesertSurfer and GODZILLA like this.
  19. Nov 5, 2021 at 10:16 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    @Railroad 07 now go look in the mirror - I bet one of your eyes is lower.
    Mike59 likes this.
  20. Nov 6, 2021 at 5:42 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    I found another post on another forum that said the rear end is “offset” from the factory on our trucks. It’s most noticeable when you lower a tundra , I recently slammed mine.
    Alignment place said it was fine front and rear , post went on to say the offset axle is due to the weight on the driver side. Battery, fuel tank, driver, etc.
  21. Nov 7, 2021 at 9:43 AM
    Ryan Mc.
    Ryan Mc. New Member
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    Can confirm...I have a 2015 dbl cab...same issue.
