Seeking. Armrest latch
Discussion in '1st Gen Tundras (2000-2006)' started by Retrac, Nov 5, 2021.
  1. Nov 5, 2021 at 2:31 AM
    Retrac
    Retrac [OP] New Member
    Tony
    Hey y’all. New to tundra world. My dad just gave me his 03 access cab.
    I’m looking for the latch for the console lid. Hoping y’all can help me out.
    Thanks in advance
  2. Nov 5, 2021 at 8:11 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I got a replacement for my 06’ at the dealer. A little different than yours though.
    The dealer has a pretty good stock of old parts.
  3. Nov 5, 2021 at 9:00 AM
    I believe one of the two pics below is the exploded diagram for your '03 AC truck.
    You can search this page showing the '03 AC console using the 5-7 digit numbers showing in the pics below to find the official part numbers you need for your console. Like, the latch in the exploded pic below is 58908A and if you search that page I linked, you'll find the latch part for $12.76. You can use the same website to add to cart for pickup at your local dealership, and they'll add in a special discount ordering online which you won't get with a direct walk-in to the dealership.
    If a part cost is too rich for your blood at the site - like a new console lid which is $227 - consider taking the part number and searching fleabay for it. Note that most parts are 10-digits in length, but some parts use a hyphen interchangeably, if the part number is listed as XXXXX-XXXXX format, and you find nothing online using that part, remove the hyphen and search for XXXXXXXXXX instead. For example, using the page I linked above, the part number for a new console lid for you is 589050C010XX where XX is the color code (E1, B2, B0 etc.) and when I search fleabay for 589050C010 I see at least one OEM unit in charcoal for $111 from a dealer. 58905-0C010 also returns similar results.
    Anyway, welcome to the best generation of Tundra! CHECK YOUR TIMING BELT!
