Low tire pressure light
Discussion in 'Wheels & Tires' started by 2Tundras, Nov 4, 2021.
  1. Nov 4, 2021 at 8:25 PM
    2Tundras
    2Tundras [OP] New Member
    Jeff
    2015 1794 Edition
    New tires a month ago. Light won't go off. Tire shop wasn't able to fix it when I came in a week later. Manual points to a reset button on panel that doesn't exist.
  2. Nov 4, 2021 at 8:32 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    You should have the reset button, its kind of hard to see, but its near your right knee on the lower dash panel.
  3. Nov 4, 2021 at 8:33 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    It does exist. Just dive down there man.
    AZBoatHauler likes this.
  4. Nov 4, 2021 at 8:55 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    And that is how man discovered the mythical female g-spot...
  5. Nov 6, 2021 at 9:43 AM
    2Tundras
    Jeff
    2015 1794 Edition
    Thanks for the ideas. Me no find. Manual says it's right next to the tachometer, though the tire pressure warning light is. Not near my knee on r.s. or l.s. The only protruding reset button is for the odometer. Also -- the Mainenance App on the Video Display Terminal has a data entry section to enter date of new tire install, won't let me enter it w/o resetting to zero. It is a 2015; 3rd owner. Maybe there are truck-specific manuals that are correct on every detail -- or maybe they just printed one for the dozens of component combinations that's more generic.
    Ran into a similar problem wnen I started pulling heavy loads & thought I had heavy-duty towing package because of the receiver hitch, tow Haul Button, and factory trailer light receptacles, and found there was no trailer braking at all. Had to get an aftermarket trailer brake controller. The manual showed a built-in controller unit on the Instrument panel, which was a "Gone Johnson".
  6. Nov 6, 2021 at 9:47 AM
    AZBoatHauler
    So.Arizona
    Should be right here.
    D5E220D1-EE5A-4D74-A062-EAC19DD5CAC4.jpg 80188208-9DA9-4A02-AA0E-39F9CB740C02.jpg
    AZTundra, 1lowlife and GODZILLA like this.
  7. Nov 6, 2021 at 9:48 AM
    18" TRD Off Road Wheels
    The button is not in the instrument panel.
    1lowlife likes this.
  8. Nov 7, 2021 at 8:21 PM
    TILLY
    Massachusetts
    Any luck Jeff?
  9. Nov 7, 2021 at 8:51 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Jeezus Christ...
  10. Nov 9, 2021 at 5:44 PM
    2Tundras
    Jeff
    2015 1794 Edition
    Nope. Appreciate the detailed photos -- but my truck may have fallen through the cracks between supposed to and equipped as. Would the fact it was ordered new in Alberta affect things? I heard that there's a mandatory Canadian mud flap thing with Tundras(mine has them).
  11. Nov 9, 2021 at 6:50 PM
    TILLY
    Massachusetts
    Very strange. :monocle:
