Alignment in spec but truck pulls to the right still
Discussion in 'Suspension' started by tundraoverland1, May 9, 2018.
  1. Nov 3, 2021 at 6:55 PM
    #121
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    For every inch of spacer height you gain 2 inches of lift. You may have closer to 4 inches which would explain the alignment issues
    boostedtrdpro likes this.
  2. Nov 3, 2021 at 6:56 PM
    #122
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Geometry changes this, if it’s a 2” spacer that’s more like a 4” lift my friend!
  3. Nov 3, 2021 at 6:56 PM
    #123
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
  4. Nov 3, 2021 at 7:06 PM
    #124
    gph04
    gph04 New Member
    Pearce
    2018 Tundra 4x4
    2” lift. 275x65xr20 BFG AT.
  5. Nov 3, 2021 at 7:07 PM
    #125
    gph04
    gph04 New Member
    Pearce
    2018 Tundra 4x4
    did not know that! Thanks.
  6. Nov 3, 2021 at 7:07 PM
    #126
    gph04
    gph04 New Member
    Pearce
    2018 Tundra 4x4
    Did not know that! Thanks.
    This is what I have. 2.25” measured.
  7. Nov 3, 2021 at 7:08 PM
    #127
    Blang805
    Blang805 New Member
    Build in Signature
    Looks like 2.25" to me. Should be a bit nose high with that then. I almost went with this lift myself but ended up having bad dreams and got the Eibach Coilover. Should be just fine for running around the streets though. :D
  8. Nov 3, 2021 at 7:11 PM
    #128
    gph04
    gph04 New Member
    Pearce
    2018 Tundra 4x4
    Yea, it does look like it has two spacers in there, I was thinking that top piece wasn’t a spacer. Starting to make more sense now.
    Blang805[QUOTED] likes this.
