Throttle Body Cleaning
Discussion in '2nd Gen Tundras (2007-2013)' started by AZToyotaMan, Nov 3, 2021.
  1. Nov 3, 2021 at 5:47 PM
    AZToyotaMan
    AZToyotaMan [OP] New Member
    Roger
    2007 Tundra
    level kit, rear air bags
    Just wanted to give a shout out to all of those who suggested cleaning my throttle body after replacing my alternator - just like everyone else who experienced this issue - truck wouldn't idle properly (too low) - after trying numerous other remedies, I cleaned the throttle body and the thing runs like a top (Toyota). Thanks to all for the good advice and this forum.
  2. Nov 3, 2021 at 6:01 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    I would be interested in more information on just what you did and what chemical you used.
    Greg
  3. Nov 3, 2021 at 7:01 PM
    AZToyotaMan
    Roger
    2007 Tundra
    Got a can of "throttle body cleaner" at Autozone. I guess it is specifically made for this purpose. Lot's of cautions advising not to use anything else. I was able to remove the throttle body so I could get to both sides of the butterfly without disconnecting the coolant lines. There are a couple of good videos for this online.
