FS: 3 switch panel insert plate
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by CorpsTundra, Aug 24, 2021.
Thread Status:
Not open for further replies.
  1. Nov 2, 2021 at 6:04 PM
    #211
    Anytimebackupcamera.com ?
  2. Nov 2, 2021 at 6:37 PM
    #212
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    It’s my best choice right now. Was hoping to find a Canadian supplier so I don’t get hit with extra fees.
    abomb60 likes this.
  3. Nov 3, 2021 at 10:52 AM
    #213
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
  4. Nov 3, 2021 at 11:26 AM
    #214
    1794TX
    Steven
    N.TX
    '20 1794
    For the rear window switch, did any of y'all get the Accessorides harness, or is there someone on the forum making something similar? Also did the 44" have room to spare? I'm going to put the switch against the vertical surface just under the console door latch, so it'll need a few more inches in length. TIA.
    Hightide likes this.
  5. Nov 3, 2021 at 11:28 AM
    #215
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    accessorides is only one.
    It’s long enough but it route it carefully.
    1794TX[QUOTED] likes this.
  6. Nov 3, 2021 at 11:30 AM
    #216
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    12volt.solutions offers one as well: https://www.12volt.solutions/produc...a-power-rear-window-switch-relocation-harness
    I DIY'd mine but would not recommend going that route. The stock harness location and the size of the wires are both a bitch to deal with.
  7. Nov 3, 2021 at 11:33 AM
    #217
    Hightide
    Abalama
    Magic School Bus
  8. Nov 3, 2021 at 11:36 AM
    #218
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Lol, they're both good - Tech12volts is James' company that was (still is?) active on here. 12volt.solutions does more of the remote start-type stuff, not really audio. I think they're located nearby James' shop and he says they work together sometimes and are good people.
    1794TX likes this.
  9. Nov 3, 2021 at 11:40 AM
    #219
    Hightide
    Abalama
    Magic School Bus
    James at
    Cool.
    I’ve always used, James.
    He has all the remote stuff as well and is a vendor on the site.
    https://shop.tech12volts.com/
    I thought he was in Georgia though.
    1794TX likes this.
  10. Nov 3, 2021 at 11:48 AM
    #220
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah, he definitely is. I know he said he's dealt with them before and I'm probably misremembering the shop location part. Just looked at their site and they are in Tulsa. Definitely not near James' shop lol.
    1794TX and Hightide[QUOTED] like this.
  11. Nov 3, 2021 at 11:49 AM
    #221
    Hightide
    Abalama
    Magic School Bus
    It’s really all according to how you fold the map.
  12. Nov 3, 2021 at 11:51 AM
    #222
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Instructions unclear, snapped phone in half.
    Hightide[QUOTED] and 1794TX like this.
  13. Nov 3, 2021 at 11:59 AM
    #223
    1794TX
    Steven
    N.TX
    '20 1794
    Thanks, gents.
    TRDFerguson and Hightide like this.
  14. Nov 3, 2021 at 12:00 PM
    #224
    Hightide
    Abalama
    Magic School Bus
    Flip-fone
    TRDFerguson[QUOTED] likes this.
  15. Nov 3, 2021 at 12:03 PM
    #225
    Hightide
    Abalama
    Magic School Bus
    Ambiguous center thingy pic for posterity.
  16. Nov 3, 2021 at 4:22 PM
    #226
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I'd call or email them and ask them to custom you up a few extra inches...
    1794TX[QUOTED] and Hightide like this.
  17. Nov 3, 2021 at 4:30 PM
    #227
    biebs96
    PA
    All of the switches I moved I made my own harnesses. I figured there would be a hole in the console now, so going back to stock wouldn’t happen. This is one of those mods that would be passed on upon selling.
    For most of my “custom” wiring in cars I use Ethernet cable. I contains 8 pairs of wire which are similar in gauge to the factory gauge. And for the slightly thicker wires I pair up a set of wires in the cable. Use of this style wire is nice because they are all contained in a single sealed loom.
  18. Nov 3, 2021 at 4:32 PM
    #228
    abomb60
    Massachusetts
    That's a great idea!
    1794TX, biebs96[QUOTED] and Hightide like this.
  19. Nov 3, 2021 at 5:40 PM
    #229
    1794TX
    Steven
    N.TX
    '20 1794
    See, I don't think to do shit like that - - I guess I've been fully drowned in the idea that we're in a throw-away economy so much that I can't ask for something different than what's on the (virtual) shelf. tys.
  20. Nov 3, 2021 at 5:52 PM
    #230
    biebs96
    PA
    saw your earlier posts.. you may want to pull apart the console and see if you will even have room to mount the switch where you are considering. The depth of the rear window switch is slightly over 3" plus the harness sticking out the back. there may simply not be enough room to mount it in the count just below the lid like you were wanting to do.
  21. Nov 3, 2021 at 6:11 PM
    #231
    1794TX
    Steven
    N.TX
    '20 1794
    I know at best I'll need to cut up the inside of the console. The safe is one of those that only takes up half the space in the console box, and I really don't use the rest of that space for much. There may be other structural or wiring problems back there that foil the plan, but hopefully the window switch, a FRAC switch, and maybe a switch for nukyaler power / nannies-off could go in that spot, in the 3-gang switch panel @RainMan_PNW pointed me toward a few weeks ago. I kinda want to hide the HU input USB inside there, too, to get it out of the way and cleaner looking for the AAWireless dongle or a USB with music on it. We'll see. We're out of 90° days in Texas, and I'm flush with PTO I can't sell back to the company, so if I can't get it done by Christmast it's my own damned fault.
    Hightide and RainMan_PNW like this.
  22. Nov 3, 2021 at 6:33 PM
    #232
    RainMan_PNW
    Casey
    Clark County, WA
    Sure thing.
    I know that they are on this forum occasionally and have actually said to reach out if you want or need something custom.
  23. Nov 3, 2021 at 6:42 PM
    #233
    biebs96
    PA
    just a piece of advice before you start cutting the console, measure again. These factory switches are deep.
    it might be worth it for you to purchase the shifter surround with the business card tray (like the SR5) and the printed panel from @abomb60 to ensure a less frustrating install.
  24. Nov 3, 2021 at 6:44 PM
    #234
    Hightide
    Abalama
    Magic School Bus
    Dremel for the win.
    It’ll fit.
  25. Nov 3, 2021 at 6:49 PM
    #235
    RainMan_PNW
    Casey
    Clark County, WA
  26. Nov 3, 2021 at 6:51 PM
    #236
    Hightide
    Abalama
    Magic School Bus
    Drinking is highly recommended before applying dremel.
  27. Nov 4, 2021 at 6:08 AM
    #237
    1794TX
    Steven
    N.TX
    '20 1794
    I also haven't really measured the little 3-gang panel properly to see if it'll even fit in the space. I don't think I'd like the looks of it if I have to cut it in a way that's visible. It might fit, but it likely has snaps on the back that hold it in its normal place in the dash, and the snap supports are obviously missing from the console, so I'll have to jury rig some way to hold it in place solid enough to support the switches. Lots could go wrong. A new shifter bezel and @abomb60 's panel is plan B, for sure.
  28. Nov 7, 2021 at 6:06 AM
    #238
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Second attempt at this went much better than the first. No runaway Dremel accidents lol.
    Ended up getting another console piece from McGeorge and was able to get a clean cut and install. Thanks again for all the help in this thread!
  29. Nov 7, 2021 at 12:10 PM
    #239
    abomb60
    Massachusetts
  30. Nov 8, 2021 at 6:03 AM
    #240
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
Thread Status:
