2020 tundra won’t stay aligned….
Discussion in 'Suspension' started by Dapperdan1313, Nov 2, 2021.
  1. Nov 2, 2021 at 4:36 PM
    Dapperdan1313
    Dapperdan1313 [OP] New Member
    I have a 2020 tundra that will not stop pulling Right. It pulled right from the day I bought it. Dealership did an alignment on it but steering wheel wasn’t straight and still pulled slightly right. Have tried 3 times to get an alignment and still can’t get it set. I recently did Bullstien 6100 2.5” suspension lift with 1/2” spacer in front and 5160 suspension in rear with 1” shackle. Put JBA uca in the front as well.
    place that usually does my alignment spent 3 hours on it today. Every time they set it to spec and test drive it the truck pulled right. They put in on the rack and the alignment was out again. Driver side toe seemed to be what was moving. At this point I’m taking it back to the dealership I suppose bc I have no freaking idea what’s going on. This has been the main issue with every tundra I’ve owned (3 of them). Front end alignments are near impossible to get set on any I’ve owned and they do not stay. Any advice would be greatly appreciated.
    The attached photo was one of the last specs they set it at and still pulled right enough that within 4 seconds you were on the shoulder.
  2. Nov 2, 2021 at 4:45 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Bring it back to dealer- until they fix it!
  3. Nov 2, 2021 at 5:06 PM
    timsp8
    NY
    Since you have a lift be prepared for the dealer to blame it on that.
  4. Nov 2, 2021 at 5:19 PM
    Burdturger
    Burdturger New Member
    I have a similar set up but camburg ucas. In my research several other people have had the same exact issue and I believe the fix is actually getting the SPC ucas for more adjustability to compensate for the alignment issue
  5. Nov 2, 2021 at 5:28 PM
    Dapperdan1313
    Already preparing for it.
  6. Nov 2, 2021 at 5:34 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The problem is you can’t “set to spec” on the alignment on a lifted truck. You need to find a competent shop that actually knows how to do an alignment.
    frichco228 and Terndrerrr like this.
  7. Nov 2, 2021 at 5:39 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Those caster readings will cause a pull/drift to the right. Right side should have more caster. Around 3.5 right and 3.0 left if you like seeing green.
    biebs96 likes this.
  8. Nov 2, 2021 at 5:40 PM
    2mchfun
    Sounds to me like there might be an issue with the owner/operator and or the tires. Maybe let someone else drive it a bit and get a few other opinions before you get in too deep with the dealer.
    boostedtrdpro likes this.
  9. Nov 2, 2021 at 5:52 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Had this exact issue until on a lifted Tundra until I took it to an alignment shop where the owner was a lifted Jeep guy. They set it to where they thought, I got in it and it still pulled to the right. The shop owner test drove it down the street, brought it back into a service bay and did some adjustments, then took it back out. On the third adjustment, was spot on...and I haven't toughed it since then. My numbers say it is out of whack, but I have straight tracking and no tire wear (except normal) in 40K miles. So "spec" and getting the number in the green for a lifted truck in no way worked for me.
  10. Nov 2, 2021 at 6:10 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Exactly. The dealer is just trying to get it "in the green". But once you change things with a lift, the machine doesn't know that the proper specs are no longer the same. Totally agreed that OP needs to take it to someone who actually knows what they're doing.
  11. Nov 2, 2021 at 6:27 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I have JBAs and had alignment set to as what they recommended....it's perfect
  12. Nov 2, 2021 at 6:43 PM
    Dapperdan1313
    I get that lifted trucks have different specs. When I said specs, I was referring to specs off this forum for my lifted truck. When set to those specs, found here, if pulled right. When they tried to make adjustments it still pulled right and when put back on the rack, the specs had changed. I watched it myself. The driver side toe was never the same when they put it back on the rack. I’m talking a few degrees off not just .1 0r .2. The toe rods were inspected by myself and the shop for any slack or slip and none was found. So, can anyone explain how a truck can be set on alignment and yet be out of alignment after a mile drive? The alignment on this truck seems to get more and more difficult every time I try to get it done. The tires were just rotated prior to the alignment. So it’s not poorly worn tires on the truck. And the tires have about 5k miles on them. They are brand new bf Goodrich ko2’s. I’m looking for solutions on what to do/try. Bc I’m dumbfounded. They put the truck back to the same specs it was at when the lift was put on 5k miles ago and it pulls right. Here is the info I used to set my truck to. I know another person with a lifted tundra that sets it to the same. He has zero issues
  13. Nov 2, 2021 at 6:48 PM
    Dapperdan1313
    Also, just for grins, they set both toes to the left. Like several degrees to the left. Just to see if it would make any difference. It did not. Truck still pulled hard right.
  14. Nov 3, 2021 at 3:40 AM
    timsp8
    NY
    Did they check the rear axle?
    After I got my lift, I got an alignment at a couple of different places, including 5 times at Goodyear under a 3 year plan. Finally the local ford dealer did it and got it right. Mine was pulling to the left.
    Maybe try a different shop and see what they say.
  15. Nov 3, 2021 at 6:59 AM
    Dapperdan1313
    Sitting at duggys garage in houston Texas right now. They specialize in Toyota 4x4 vehicles. So if anyone would know what the issue is, these would be the guys. We will see what they have to say.
    2mchfun likes this.
  16. Nov 3, 2021 at 8:04 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    A good alignment shop should be able to improve drivability. Alignment with a lift requires some experience, most of the shops just do a toe n go!
    However, you are at 3 inches of lift, so adjustable UCAs may be required for your truck to get better alignment and handling.
  17. Nov 3, 2021 at 8:13 AM
    Dapperdan1313
    I assumed the JBA’s would be sufficient uca’s. They seemed to have gotten great reviews on everything I’ve read with tundras
  18. Nov 3, 2021 at 8:17 AM
    frichco228
    Frank
    Virginia
    ah, thought you were running stock, you should be good to go. Just need a shop that knows what they are doing
  19. Nov 6, 2021 at 9:00 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    So how'd they do??
    Care to share thoughts or copies of your numbers?
  20. Nov 6, 2021 at 9:14 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    From the specs above your caster is backward. You want +/- .5* more caster on the right than on the left. Your toe is too high also though not main problem.
  21. Nov 24, 2021 at 7:24 AM
    Dapperdan1313
    I’ll have that for you soon.
