Anyone experiencing a clunk noise when you put truck into drive?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mr. Wolf, Nov 1, 2021.
  1. Nov 1, 2021 at 6:12 PM
    Mr. Wolf
    Mr. Wolf [OP] New Member
    I have a 2021 Crew Max Limited and recently starting hearing a clunk noise, definitely coming from the front end. It happens when I back up, then put into drive and drive away. Happens pretty much every time, every day.
    Anyone else experiencing this?
    cowboyjack likes this.
  2. Nov 1, 2021 at 6:44 PM
    rugerm44
    rugerm44 New Member
    2021 Tundra
    You aint alone.I thought it might have something to do with abs.It only dose it after backing up and putting in drive.
  3. Nov 1, 2021 at 6:47 PM
    IgotSR5onit
    IgotSR5onit New Member
    More than likely the ABS self check. Mine does it at 6 or 7 mph.
  4. Nov 1, 2021 at 6:54 PM
    Xwwh587
    Xwwh587 New Member
    ‘21 Limited Crew Nightshade Wind Chill Pearl
    Stock
    Yep mine at 5 mph. I read somewhere on here that it is the ABS.
    Terndrerrr likes this.
  5. Nov 1, 2021 at 6:58 PM
    chiz44
    chiz44 New Member
    Austin
    2018 MGM SR5 TRD Off Road
    I've also heard the noise, only when beginning to move, at the same time/speed/distance from my normal parking spots. I looked around on here and heard that it is completely normal. The ABS system doing a self check after start up, is what I believe was explained.
  6. Nov 1, 2021 at 7:08 PM
    Blueknights75
    Ron
    Clayton, NC
    ABS self check…your fine. Use the search icon and you will see many threads on the subject.
  7. Nov 1, 2021 at 7:13 PM
    biebs96
    PA
    If just going forward from initial start, it is the ABS self check at 15mph.
    If reversing from initial start then proceeding forward, it is most likely the pins inside the brake calipers clicking; followed by the ABS self check.
  8. Nov 1, 2021 at 10:02 PM
    Mr. Wolf
    I dunno folks. It wasn’t doing it when I first got the truck. And if it is the abs then literally every single Tundra would do it and I don’t think that’s the case.
  9. Nov 1, 2021 at 10:07 PM
    cowboyjack
    cowboyjack New Member
    Mine does it too. Doesn’t seem right to me on a brand new 2021 truck, but everyone says it’s okay….
  10. Nov 1, 2021 at 10:40 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    mahmer09 likes this.
  11. Nov 2, 2021 at 2:46 AM
    Adam New Member
    Literally every single Tundra does do this. It is the ABS self check.
  12. Nov 2, 2021 at 2:53 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Freaked me out too. Its normal.
  13. Nov 2, 2021 at 5:15 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Not just tundras, but every modern vehicle with abs. Some are just more prounounced than others.
  14. Nov 2, 2021 at 5:24 AM
    timsp8
    NY
    Yep. Mine does it.
  15. Nov 2, 2021 at 5:45 AM
    Kevmo
    Kevmo _________
    20 MGM TRD Limited DC
    Normal, ABS self check.
  16. Nov 2, 2021 at 5:55 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Yes it was and yes it is.
  17. Nov 2, 2021 at 6:21 AM
    mschein1
    mschein1 New Member
    2006 Tundra Dbl Cab 2021 Cement CM - Sold
    It almost sounds like tire rub when you start going. Thanks, I didn't suspect anything to be wrong but had definitely heard it.
  18. Nov 2, 2021 at 8:10 AM
    Mr. Wolf
    Hmmm. Ok, then let me ask if there are any of you out there that are NOT experiencing this?
  19. Nov 2, 2021 at 8:14 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Still not convinced despite everyone telling you it's normal?
    Adam likes this.
  20. Nov 2, 2021 at 8:20 AM
    mahmer09
    mahmer09 SR5 4x4
    Plus the evidence of the video. These are the times we live in. I guess it could be something different, but every Tundra makes a clunk upon start up. If that is what OP is referring to, they all do it. It is a little shocking when you first notice it.
    farnsrocket likes this.
  21. Nov 2, 2021 at 8:28 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I always noticed it but never thought it was loud or anything.
    OP can always go to the dealer though in case of the one off situation that it could be something else. Especially since he's skeptical of it.
  22. Nov 2, 2021 at 8:36 AM
    Mr. Wolf
    Only because I don’t recall hearing it in the first few months of owning it. For me, it only happens when I put in reverse and then into drive. Doesn’t happen when parked and then simply drive forward so it’s inconsistent in that manner, hence the question.
  23. Nov 2, 2021 at 8:38 AM
    timsp8
    NY
    Not sure if you are still under warranty, but if you have time and it’s reproducible then go by a dealer and ask them to look at it real quick. A tech should be able to do it in the parking lot. Just make sure they don’t want to charge a diagnostic fee. Sometimes they will want an appt though.
    Jaypown likes this.
  24. Nov 2, 2021 at 2:14 PM
    Adam New Member
    So if you start up and drive forward (no reverse) it doesn't do the sound? That is a problem that it isn't doing the ABS self check. Start it up, turn your bad ass music down, turn off the heat/ac, then put it in drive and accelerate slowly while listening really hard. If it isn't doing the noise then....then that is a issue. I shit my pants the first time I "heard" it after having it a couple days. Then I heard it every day. Now it is tuned out.
