Protective film
Discussion in 'General Tundra Discussion' started by ziggy04, Nov 2, 2021.
  1. Nov 2, 2021 at 10:42 AM
    ziggy04
    ziggy04 [OP] New Member
    Eric
    2021 Tundra
    What have you guys seen with the protective film? I have a 21 Tundra TRD Pro coming in (which I worked super hard to get!) and it has it on it. Once you start get chips does the film look like crap? How hard is it to remove? I have a friend who does ceramic coating and I was thinking about doing that to the truck. Should I remove the film first?
  2. Nov 2, 2021 at 10:50 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    PPF can be good or not so good depending on the color of your truck. Lighter colors, especially white, will eventually start showing a yellowish hue as the PPF ages. This is not noticeable on darker colors. If you're going to remove it, it's much better to remove it sooner rather than later. I recommend a good ceramic coating, which can be applied over the PPF.
    BTW, Welcome from LA (Lower Alabama)!
    NewImprovedRon likes this.
  3. Nov 2, 2021 at 10:50 AM
    ziggy04
    Eric
    2021 Tundra
    Thanks! I’ve never done ceramic coating but like I said, my friend does it and swears by it. I’m getting black so I will probably do it. I had a black truck previously and it was tough to keep scratch fee.
  4. Nov 2, 2021 at 10:51 AM
    RobertD
    Robert
    DFW, Texas
    The film needs to be replaced every 4-6 years before the adhesive dries and shrivels. There are many posts from people with old PPF that has dried and damaged the underlying paint. I'd probably have the film removed for ceramic coating if you are getting one with a lifespan longer than 5 years.
    frichco228 likes this.
  5. Nov 2, 2021 at 10:55 AM
    ziggy04
    Eric
    2021 Tundra
    Thank you! Love LA! Spent a lot of time working in Montgomery and Lower LA (lower Louisiana)!
  6. Nov 2, 2021 at 11:31 AM
    justcuz
    justcuz 2.5 Gen Member
    has anyone heard of a graphene coating? apparently there is one that is called "self healing" if you get a little rub or scratch it can be taken out with a blow dryer.
    how does this compare to the ceramic coating?
