Rear sway bar necessary??
Discussion in '1st Gen Tundras (2000-2006)' started by AWilliams, Nov 1, 2021.
  1. Nov 1, 2021 at 5:01 PM
    AWilliams
    AWilliams [OP] New Member
    When does a rear sway bar become a needed add on? I bought one and really don't think I need it now. Does it hurt you in any other areas...ie: offroad, towing etc??
  2. Nov 1, 2021 at 5:09 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    If you off road most guys remove the sway bar to have more flex. If you tow or just simply driving and turning fast it helps with body roll. What did you purchase?
  3. Nov 1, 2021 at 5:12 PM
    AWilliams
    Adecco?? model 2181? Not sure if I should install it. I don't offroad or tow.....yet.
    Might get a tiny trailer in the future. I have a 17' fiberglass bass boat.
    Dave8699 likes this.
  4. Nov 1, 2021 at 6:20 PM
    TTund16
    TTund16 New Member
    iirc, rear sway bar doesn't help much with towing. Only if you have a heavy load in the bed, it can help when cornering fast(er) and it reduces the body roll.
    For off-road rear sway bar is not a good idea either. even with the city bumpy roads and potholes, it will transfers the jolt from one wheel to the other ... not a good idea. I think you get a smoother ride without one.
    Also if you already have stiffer shocks like TRD off-road models, the benefits of the sway bar won't be as significant.
    do a search , lots of threads about it but that's kind of my conclusion based on my research but I've been wrong before :D I have a trd off-road and decided not to get the rear sway bar. I don't corner super fast either and don't carry heavy loads on a regular basis and so far have had no issues without rear sway bar. The car came without one so Toyota must know what's going on. it's a trd off-road may be that's why it came with no sway bar. Off road means no rear sway bar.
  5. Nov 1, 2021 at 6:40 PM
    Xwwh587
    Xwwh587 New Member
    ‘21 Limited Crew Nightshade Wind Chill Pearl
    Stock
    I just installed the TRD Rear sway bar. I’m not in to off-roadn the Tundra, that’s what my Taco is for, but I definitely like how it now handles lane changes and curves. Still has some body roll, but not as bad. I would not have installed it if I was going to off road, would really be concerned it would catch something and rip something smooth off.
    TTund16 likes this.
  6. Nov 1, 2021 at 6:41 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    If rock crawling and you need maximum articulation it will hurt.
    On road it helps keep the truck much more stable. Especially through turns, but it also feels better even when changing lanes at freeway speeds. Towing it may also keep the rear more planted.
    On some of the mid year TRD models, the rear sway bar was an add on factory option. They just didn't do it for most to keep cost down most likely. They also sold bolt on kits.
    I added one and am happy I did so. Ymmv, depending on driving style and road conditions.
    Tslyjr and Lil Steve like this.
  7. Nov 1, 2021 at 6:55 PM
    AWilliams
    This is for a 1st gen. I know alot of guys chime in with their new style Tundras and sometimes it's apples to oranges. The 1st gen isn't anywhere near the current gen.
    KarmaKannon and FrenchToasty like this.
  8. Nov 1, 2021 at 8:54 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    It should improve on road driving. If you already got it why not give it a try?
  9. Nov 1, 2021 at 9:07 PM
    AWilliams
    It means drilling holes in the frame...
  10. Nov 1, 2021 at 9:16 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    If you don't use it are you selling it?
  11. Nov 1, 2021 at 11:22 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Rear sway bar application applies to any generation.
    It reduces body roll on turns and cornering.
    It isn't rocket science..
    Drilling holes in the frame?
    WTF..?
    I installed a Hellwig rear sway bar on my 2005.
    No drilling required..
    I have an OEM TRD RSB on my 2014, same results.
    The rear sway bar will reduce body roll on cornering and highway ramps.
    Nothing more, nothing less.
    I'd sell that drilling required shit and buy a Hellwig before I started drilling holes in my frame...YMMV
    Hellwig Products Search - Hellwig Products
