Warn Winch Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by IgotSR5onit, Nov 1, 2021.
  1. Nov 1, 2021 at 6:40 PM
    IgotSR5onit
    IgotSR5onit [OP] New Member
    I just picked up this Warn winch off of a Ram Power Wagon for next to nothing. From what I gather it is just a m12000 thats motor has been swapped to the opposite side. I was curious if anyone more knowledgeable about winches than myself might know of a bumper mount that this would work in? warn.jpg
  2. Nov 1, 2021 at 7:07 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That’s a universal layout for winches of that size for almost every winch manufacturer. You can measure the spacing of those holes and check the specifications on the winch bumper you are looking at for confirmation
    Kratos and Saltyhero13 like this.
  3. Nov 1, 2021 at 7:18 PM
    IgotSR5onit
    the clutch lever is what I would assume would give me issues. It being on the opposite side and it looks oversized from the M12000. That being said, I have never mounted one so I dont know where they usually sit in original configuration. The mounting holes are common from what I can tell at 10x4.5
  4. Nov 1, 2021 at 8:05 PM
    Those are some spendy winches.
    They also rotate in the opposite direction of most standard winches, and have a low voltage shutoff…FYI.
    gosolo likes this.
  5. Nov 1, 2021 at 8:06 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I would think that if you can access and operate the clutch lever, it wouldn’t matter where it’s located, guess I’m not really helping you here
  6. Nov 1, 2021 at 8:29 PM
    IgotSR5onit
    Im not really sure how the clutch is accessed in the bumper/hidden mounts.
    gosolo[QUOTED] likes this.
  7. Nov 1, 2021 at 8:39 PM
    IgotSR5onit
    Im guessing that is just because the motor is reversed? I figured I could swap the bottom (spool containing rods?) to the front, flip the winch around, flip the wiring box(as its just held in place with band clamps), and then it would be feeding from the bottom?
  8. Nov 1, 2021 at 9:29 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    With several models of hidden winch bumpers, the guys have made small cutouts in the grill for access. My situation doesn’t apply to your problem since I have the fully wireless remote controlled warn winch
    IgotSR5onit[OP] and Mater like this.
  9. Nov 1, 2021 at 9:29 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Yup, looks to be a m12000 or one specifically made for dodge. Had one myself and sold it due to impracticality. Those are what are considered large frame winches and you will have a very difficult time finding a bumper for the tundra that’ll fit it. The road armor bumper claims that one will fit but I just don’t see it happening. You can rotate the clutch leveler by unbolting the planetary housing and rotating to wherever you need it to be and then reassemble. Nice thing about those winches is you can upgrade to the 6hp motor off of the 9.5xp and it’ll give you right around 15000 lb winch. Way overkill for a tundra application but still pretty sweet.
    gosolo likes this.
  10. Nov 1, 2021 at 10:15 PM
    IgotSR5onit
    I was wondering how they got that big sob in the bumper. I was suprised at the size when I picked it up. As I just paid 350$ for it I may just throw it on a hitch mount and have it available. May weld a a receiver on my trailer so I can just interchange it. Or may sell it and get the Zeon I been eyeing. Just felt like I shouldnt pass it up for that price.
    Mater[QUOTED] and gosolo like this.
  11. Nov 1, 2021 at 10:24 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I think you made a good purchase and have some good options.
    On past trucks I have fabricated reciever mounts for my winch. There’s pros and cons to this.
    Mater likes this.
  12. Nov 2, 2021 at 7:12 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Yup, you’re on the right track. I was planning on putting it on a hitch mount too. Use it in the front/back/trailer but the thing is freaking heavy; even with synthetic line.
  13. Nov 2, 2021 at 2:35 PM
    IgotSR5onit
    Do you happen to know if this one can be ran on a jump box without issue?
  14. Nov 2, 2021 at 3:18 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    That I don’t know that answer for sure as I don’t know the jump pack specs, but these winches draw a ton of current so it’d have to be pretty powerful jump box. A standard m12000 can draw up to 440 amps
