Toyomafia - The Clubhouse. 151.880
  1. Nov 1, 2021 at 1:45 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I see it.
    But what is that one underneath it?
    :spy:
  2. Nov 1, 2021 at 1:45 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That’s about right, I had knee replacement surgery and seem to remember it went like that
  3. Nov 1, 2021 at 1:48 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I imagine that's how it went when my dad had the rod removed from his leg after being hit by a tree when I was little. He came out of that with one leg 1" shorter than the other.
  4. Nov 1, 2021 at 1:54 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Watching this makes me remember when I had the screws taken out of my leg while I was awake.
  5. Nov 1, 2021 at 2:03 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  6. Nov 1, 2021 at 2:09 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Doing work!
  7. Nov 1, 2021 at 2:10 PM
    ToyoMafia
    Magic carpet.
    Hunter orange beanies would be epic. I’ll work on it.
  8. Nov 1, 2021 at 2:28 PM
    So is any color that a person wears while hunting considered “hunter xyz”
    Hunter orange, Hunter green, Hunter blue?
  9. Nov 1, 2021 at 2:38 PM
    1794TX
    Steven
    N.TX
    '20 1794
    I like what you're doing there. If I have a glass of whisky, I'm going to declare my shirt drinker green.
  10. Nov 1, 2021 at 2:39 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Fat guy in a little shirt!!! What’s wrong Richard?????:)
  11. Nov 1, 2021 at 2:41 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I wish.
    Unfortunately (or fortunately, depending on the situation), it's a specific requirement. Orange or pink are the requirements.
  12. Nov 1, 2021 at 2:42 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    No. Only posers would do that. Hunters call anything orange enough to be visible during hunt hunters orange. Lots of variations.
  13. Nov 1, 2021 at 2:44 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Each state is different though on the amount. And some states require a name card, with identification on the back for legal purposes.
  14. Nov 1, 2021 at 2:52 PM
    ToyoMafia
    Magic carpet.
    When I placed the order I told them I want it Hunter green and the brightest orange Pantone does. Hunter green is actually a color but they would have had no clue what Hunter Orange was.
  15. Nov 1, 2021 at 2:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yes. I hunted deer in WI for several years during college. Nothing like having a number on your back the size of a license plate so the F&W warden could set up at the access road with a spotting scope and glass people's "ID" while they sat in their stands watching the same clearcut.
    It was like WW3 out there.
  16. Nov 1, 2021 at 2:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    some sort of day-glo-ish flourescent orange will do.
  17. Nov 1, 2021 at 2:56 PM
    They did.:rant:
  18. Nov 1, 2021 at 2:59 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    https://colorcodes.io/orange/hunter-orange-color-codes/
    Just tell them any variation of these will do.
  19. Nov 1, 2021 at 3:05 PM
    :taco:
  20. Nov 1, 2021 at 3:10 PM
    Azblue
    The Dirty T ( ^_^)_且
    That's probably exactly what happened with the pin in my leg when I was 17. I posted a pic of it a while back, you can see the marks from them using pliers or something when they took it out.
  21. Nov 1, 2021 at 3:27 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    We always called it "blaze orange" in Illinois... could be a great double entendre for this group... anyway, there's a color code for that, also called "Hunter Blaze Orange" apparently: https://colorcodes.io/orange/hunter-orange-color-codes/
    jewsNbrews, gosolo, Hightide and 4 others like this.
  22. Nov 1, 2021 at 3:28 PM
    That kinda shit gives me the willys. One time I made the mistake of asking why the needle was so long when they did my ingrown toenail; I got pale AF when they told me it was that long because they reach the inside of your toe from the outside edge!!!!!
  23. Nov 1, 2021 at 3:29 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Got that visual in my brain now. Thanks, I hate it.
    Hightide, jewsNbrews, gosolo and 8 others like this.
  24. Nov 1, 2021 at 3:31 PM
    RainMan_PNW
    Casey
    Clark County, WA
  25. Nov 1, 2021 at 3:33 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    @jewsNbrews beat me to it lol. I thought I read them all before posting.
    Hightide, jewsNbrews, gosolo and 3 others like this.
  26. Nov 1, 2021 at 3:34 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  27. Nov 1, 2021 at 3:42 PM
    Azblue
    You can see the threads on the inside of the pin I have where I assume that they would screw on puller or something like used in that gif. Probably tried to twist it with pliers when it wouldn't come out and mangled the end.
    Fotnot, Hightide, jewsNbrews and 5 others like this.
  28. Nov 1, 2021 at 3:42 PM
    Black@Blue19
    Ken
    SE Texas
    OH MY!!!!:)
    Hightide, jewsNbrews and gosolo like this.
  29. Nov 1, 2021 at 3:43 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    That’s pretty poor form. And to keep whackin like that after it’s loose is even poorer form. They can be pretty stuck sometimes but he’s being dramatic. The marks on yours are probably from vice grips, just like the ones in your tool box, but sterile and way more expensive. Usually they can just put that attachment on that it goes in with and a couple taps and it’s loose.
    Hightide, jewsNbrews, gosolo and 4 others like this.
  30. Nov 1, 2021 at 3:44 PM
    Do you have a shadow box full of cool shit, with the fang in the middle highlighting all the coolness?
    Hightide, jewsNbrews, gosolo and 5 others like this.
