  1. Oct 31, 2021 at 6:03 PM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    Got my windows tinted. 5% all around.
    Blang805, MS22, oscardog86 and 8 others like this.
  2. Oct 31, 2021 at 6:14 PM
    Those wheels really pair nicely with that truck. ^^^
  3. Oct 31, 2021 at 6:34 PM
    0h6SR5
    0h6SR5 New Member
    thanks! I agree. Took me a while to decide on wheels. Scs was my original choice but since it seems like they make 5 sets per month I started looking elsewhere. I’m happy with the results
  4. Oct 31, 2021 at 6:42 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    The simplest but kinda half ass way would be figuring out which wire on the clock harness controls the dimmer circuit for just the clock and cutting it or wiring it to a switch.
  5. Oct 31, 2021 at 7:02 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    ‘04
  6. Oct 31, 2021 at 7:07 PM
    Openbaffle
    Openbaffle New Member
    Had a decent chunk of time today so worked through my list.
    • Started by taking off the passenger side mirror to fix the play. Just like the driver's side, I put a small washer to allow the torx to tighten back up better when it was re-assembled. A couple drops of super glue to keep the washer from moving around while it was being reassembled.
    • Cleaned up my TPMS bypass wiring so you can't see it when the glove box is open. It's hidden well now. Also double sided foam taped the TPMS box to one of the other plastic boxes in the cavity (previously was duct taped). I think this was causing one of my rattles.
    • Went through the arduous and tedious task of removing the wood grain trim from the HVAC/radio bezel and the three remaining driver side switch bezels. Heat gun. Remove plastic piece. Goo gone. Heat gun. Remove adhesive. Goo gone. Heat gun. Remove residue. Clean everything up with alcohol after. It came out really nice however and was worth the labor.
    • While I was doing that, I added LEDs to the HVAC/radio bezel. 194s and 74s to replace the green-gelled OEMs. I didn't have enough extra 194s, so I pulled them from the door and ordered another 10 that will be here Tuesday.
    • Same procedure for the switch bezels. Same tedious work. They used a different adhesive on the ash tray cover. The heat gun doesn't work with that so well. That is more easily removed with soap and very hot water. Heating up the glue and rolling it off the surface slowly. Also the door switch trim pieces are painted. Don't use acetone. Ask me how I know. Alcohol works ok. Goo Gone works ok. Also all of my switch assemblies were gross. Good time to clean up everything.
    Deciding if I should paint the bezels or wrap them satin black to match the rest of the trim? I think so. There is still too much different grays going on at the door. Also thinking of getting black Weathertech mats all around to darken up the interior a bit more. All and all a productive day. Got everything reassembled, everything back working again. Driveway solo stove fire to close out the weekend. Some pictures:
    IMG_6809.jpg IMG_6810.jpg IMG_6813.jpg IMG_6820.jpg IMG_6821.jpg \
    tacoguybill, Voss, Darkness and 8 others like this.
  7. Oct 31, 2021 at 9:36 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Messed with the radio a bit more today. I’m stumped. Until I get ahold of someone at corporate I know the anytime unit is working properly, the receiver is getting reverse signal, but no image. The screen just stays on the Home Screen. So until I can access the debug menu (that isn’t listed on how you get to for this radio on TIS) I can’t do much.
    Multiple people have upgraded 2017 Toyota 86s and had operational backup cameras. So it’s capable. But I just can’t figure out how.
  8. Nov 1, 2021 at 3:15 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Pops hit a deer in my V6 this am... he says there is minor damage. Dash Cam footage should be available soon...
    Voss, KarmaKannon, NWPirate and 3 others like this.
  9. Nov 1, 2021 at 3:24 AM
    Venison for dinner?
    Voss, KingSequioa007 and Tundra2 like this.
  10. Nov 1, 2021 at 3:25 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Note to self: dont dress as a deer in w.ky for halloween.
    tacoguybill, Voss, RUSTYNUTS and 7 others like this.
  11. Nov 1, 2021 at 4:35 AM
    Damn man. Do y'all not have any hunters around there? There seems to be an unusually high number of deer there.
  12. Nov 1, 2021 at 4:52 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Plenty of hunters here. It's just a family curse. I inherited it, but I know my truck, and how how use all my lights.
    No pictures sent in yet, but he said the brush guard was pushed in, and a fog light was broken. Thinks he can pull it out for me...
    Voss and bmf4069[QUOTED] like this.
  13. Nov 1, 2021 at 5:05 AM
    Him and one of your brothers;)
    Darkness and Tundra2[QUOTED] like this.
  14. Nov 1, 2021 at 5:38 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well yall know I love that truck. He said he was rolling 55 when he smooshered it. Still waiting on pics.
  15. Nov 1, 2021 at 5:57 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    And still waaaaaaaaaaiting makes you think how bad it is:monocle:
    NWPirate and Darkness like this.
  16. Nov 1, 2021 at 6:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes... because I know how he "fixed" the last three vehicles he smooshered deers with. He's planning on fixing the Nissan...
  17. Nov 1, 2021 at 7:58 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Looks stick, can't even tell you have that Suspension set up without peeking inside the fenders.
  18. Nov 1, 2021 at 8:00 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    ? I think its cummins3500 that has suspension. Mine is bone stock and worn out.
    KingSequioa007 and FrenchToasty like this.
  19. Nov 1, 2021 at 9:03 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I replaced my driver's window motor a few weeks ago the auto up didn't work work. It would roll up, then bump back down. I tried resetting it with the roll it down and hold the button for 5 seconds, roll it up and hold it for 5 seconds, but that didn't work. So I took off the motor and ran it both ways for 10 seconds, then tried resetting it still no dice.
    Anyone know the correct way to reset the auto up down switch?
  20. Nov 1, 2021 at 9:06 AM
    empty_lord
    05 rollover special
    Roll down, hold for 5 seconds, roll up hold for 5 seconds. Hold timer starts when windows fully down and fully up
  21. Nov 1, 2021 at 2:20 PM
    Uh. Your dad is, like, the last person on earth I'd ever loan a vehicle to. I've missed my fair share of Bambi and Ronno over the years, but only because I watch the damn road like a hawk and apply high beams, horn liberally.
  22. Nov 1, 2021 at 2:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yea...
    received_909650353262272.jpg received_2930560267273400.jpg received_236544031793744.jpg received_468834051125569.jpg
    My $200 grille guard saved a lot of damage, but not all of it.
  23. Nov 1, 2021 at 2:41 PM
    empty_lord
    05 rollover special
    Time to cal up brute force fab and get the full bash bar too
  24. Nov 1, 2021 at 2:48 PM
    Yeah, uh, no thanks. I'd be pissed. Even if it's the dude whose swimmers put me on this planet. Wouldn't grate me so bad if this hadn't happened multiple times in recent history. It's one thing if someone does it with their shit. When they borrow your shit and do it though.
  25. Nov 1, 2021 at 2:56 PM
    Oh. Totally forgot to post what I got done over the weekend. Other than helping another 1st Gen'er out with some stuff.
    Before I realized it was only for 2WD trucks, I checked my truck for TSB-0067-09 (attached). When I noticed things looked a little different, that's when I noticed "2WD" at the top.
    While I was under there, I wiped in some grease sling, then looked around at stuff. Meant to snap pics of front suspension so I could zoom in (I've can't see for shit close-up) to see if anything was torn up. These were the only pics that turned out, head lamp was too bright with new batteries I guess. Meh.
  26. Nov 1, 2021 at 3:08 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Took out the Tundra for little one on one time and found some Gravel road, mud puddles, and Mushrooms today on Mt Hood. Unfortunately the forecast changed and got pissed on by rain whole time. Hopefully can get back out if we get few nicer days after this storm.
    Voss, oscardog86, KarmaKannon and 4 others like this.
  27. Nov 1, 2021 at 3:27 PM
    Is that big orange bastard a Lobster (H. lactifluorum)? At first I thought O. illudens (forget common name for it) but shape doesn't seem right. Too big for Cinnabars.
  28. Nov 1, 2021 at 3:49 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Eh, even the best of drivers can hit deer.
    I had one hit me in my old Jeep and never saw it. Face hit the fender, butt hit the door, and apparently kept running.
    Friend of mine has tagged about a dozen in the last 20 years.
    thunder100 and FrenchToasty like this.
  29. Nov 1, 2021 at 3:54 PM
    Yeah I believe Noah’s mom got hit by a deer, same thing in the fender if I recall, playing chicken with traffic!
    NWPirate likes this.
  30. Nov 1, 2021 at 4:07 PM
    Siebler
    CJ
    Eastern Oregon
    That it is. Found 2 smaller Lobsters as well that didnt make the pic.
    shifty`[QUOTED] likes this.
